ich verwende das AT91SAM7S64 Board von Olimex zusammen mit dem
ARM-Tiny-USB und der mitgelieferten OpenOCD-Yagarto-Toolchain-Eclipse.
Ich möchte den Befehl sprintf() verwenden. Dazu habe ich stdio.h
eingebunden. Trotzdem kommt die Fehlermeldung: undefined reference to
sprintf
Woran kann dies liegen?
Hier ein Auszug aus dem Makefile:
1 | NAME = demo_at91sam7_h256_blink_flash
2 |
3 | # variables
4 | CC = arm-elf-gcc
5 | LD = arm-elf-ld -v -lc
6 | AR = arm-elf-ar
7 | AS = arm-elf-as
8 | CP = arm-elf-objcopy
9 | OD = arm-elf-objdump
10 |
11 | CFLAGS = -I./ -c -fno-common -O0 -g
12 | AFLAGS = -ahls -mapcs-32 -o crt.o
13 | LFLAGS = -Map main.map -Tdemo_at91sam7_h256_blink_flash.cmd
14 | CPFLAGS = --output-target=binary
15 | ODFLAGS = -x --syms
16 |
17 | OBJECTS = crt.o main.o timerisr.o timersetup.o isrsupport.o lowlevelinit.o blinker.o
18 |
19 |
20 | # make target called by Eclipse (Project -> Clean ...)
21 | clean:
22 | -rm -f $(OBJECTS) crt.lst main.lst main.out main.bin main.hex main.map main.dmp
23 |
24 |
25 | #make target called by Eclipse (Project -> Build Project)
26 | all: main.out
27 | @ echo "...copying"
28 | $(CP) $(CPFLAGS) main.out main.bin
29 | $(OD) $(ODFLAGS) main.out > main.dmp
30 |
31 | main.out: $(OBJECTS) demo_at91sam7_h256_blink_flash.cmd
32 | @ echo "..linking"
33 | $(LD) $(LFLAGS) -o main.out $(OBJECTS) libgcc.a
34 |
35 | crt.o: crt.s
36 | @ echo ".assembling crt.s"
37 | $(AS) $(AFLAGS) crt.s > crt.lst
Und hier ein Auszug aus main.c
1 | #include <stdio.h>
2 | #include <string.h>
3 | #include "AT91SAM7S256.h"
4 | #include "board.h"
5 |
6 |
7 | // *******************************************************
8 | // Global Variables
9 | // *******************************************************
10 | unsigned int FiqCount = 0; // global uninitialized variable
11 |
12 |
13 | // *******************************************************
14 | // MAIN
15 | // ******************************************************/
16 | int main (void) {
17 | unsigned long j; // loop counter (stack variable)
18 | unsigned long IdleCount = 0; // idle loop blink counter (2x)
19 |
20 | char buff_send[50];
21 | unsigned int status;
22 |
23 | // Initialize the Atmel AT91SAM7S256 (watchdog, PLL clock, default interrupts, etc.)
24 | // ---------------------------------------------------------------------------------
25 | LowLevelInit();
26 |
27 |
28 | // Turn on the peripheral clock for Timer0
29 | // ---------------------------------------
30 |
31 | // pointer to PMC data structure
32 | volatile AT91PS_PMC pPMC = AT91C_BASE_PMC;
33 |
34 |
35 | sprintf((char*)buff_send, "Status: %i\r\n", status);
Kann mir da jemand helfen?
Schönen Gruß,
Johannes
