1 | /******************************************************
2 | * Font 7x11(English) *
3 | * *
4 | * -ASCII fonts from 0x20 ~ 0x7F(DEC 32 ~ 126) *
5 | * composed of following characters *
6 | * *
7 | * -XSize : 7 pixcels *
8 | * -YSize : 11 pixcels *
9 | * *
10 | * ....... <- b0, Blank, Not used *
11 | * ....... <- b1, Blank, Not used *
12 | * ....... <- b2, Blank, Not used *
13 | * ....... <- b3, Blank, Not used *
14 | * ....... <- b4, Blank, Not used *
15 | * ..End.. <- b5(2nd byte) *
16 | * ..OO... <- b6(2nd byte) *
17 | * ..OO... <- b7(2nd byte) *
18 | * ..OO... <- b0(1st byte) *
19 | * ..OO... <- b1(1st byte) *
20 | * ..OO... <- b2(1st byte) *
21 | * ..OO... <- b3(1st byte) *
22 | * ..OO... <- b4(1st byte) *
23 | * ..OO... <- b5(1st byte) *
24 | * ..OO... <- b6(1st byte) *
25 | * .Start..<- b7(1st byte) *
26 | * *
27 | ******************************************************/
28 |
29 | //7x11 ascii font, each character takes 14 bytes, total 1330 bytes, draw from left bottom to left top
30 | prog_char ascii_7x11[95][14] = {
31 | {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f}, //0x20 space
32 | {0x00, 0x00, 0x07, 0xc0, 0xdf, 0xe0, 0xdf, 0xe0, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x1f}, //0x21 !
33 | .
34 | .
35 | .
36 | {0x00, 0x00, 0x80, 0x20, 0xe0, 0xe0, 0x7f, 0xc0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x5f}, //0x7d }
37 | {0x00, 0x60, 0x00, 0x20, 0x00, 0x60, 0x00, 0xc0, 0x00, 0x80, 0x00, 0xc0, 0x00, 0x5f} //0x7e ~
38 | };
39 |
40 | //********************************************************************************
41 | //** Function Print Text 1 Charecter size 7x11 **
42 | //********************************************************************************
43 | //** Parameter : **
44 | //** row = Ascii Code (Position buffer keep text) **
45 | //** adx,ady = Position X,Y for begin plot text by will **
46 | //** begin plot from bottom left to top left **
47 | //** fg_clr = Color of text **
48 | //** bg_clr = Color background of text(if bg_clr = no_bg or 1= **
49 | //** non color background) **
50 | //********************************************************************************
51 |
52 |
53 | void text_7x11(unsigned char row,int adx,int ady,unsigned int fg_clr,unsigned int bg_clr)
54 | {
55 | int ax,ay ;
56 | unsigned char m,n,tx ;
57 |
58 | ax = adx ;
59 | ay = ady ;
60 |
61 | row = row-0x20 ;
62 |
63 | //------- Print Text 1 Charecter(data 14 Byte) -------------
64 |
65 | for(m=0;m<14;m++)
66 | {
67 | //---Sent data byte1=8 bit----
68 |
69 | tx = pgm_read_byte(&ascii_7x11[row][m]) ; //Read data Ascii
70 |
71 | for(n=0;n<8;n++) //Loop Sent data 1 byte(8bit)
72 | {
73 | if(tx & 0x80) //if data bit7 = 1 ,Plot Color area Charecter
74 | {
75 | gp_wr_cmm(0x20) ; //Command Set Adddress Hor(X)
76 | gp_wr_data(ay) ; //Sent X_Address CGRAM
77 | gp_wr_cmm(0x21) ; //Command Set Address Ver(Y)
78 | gp_wr_data(ax) ; //Sent Y_Address CGRAM
79 | gp_wr_cmm(0x22) ; //Command Write data
80 | gp_wr_data(fg_clr) ;
81 |
82 | }
83 | else //if data bit7 = 0 ,Plot Color area back ground Charecter
84 | {
85 | if(bg_clr != 1)
86 | {
87 | gp_wr_cmm(0x20) ; //Command Set Adddress Hor(X)
88 | gp_wr_data(ay) ; //Sent X_Address CGRAM
89 | gp_wr_cmm(0x21) ; //Command Set Adddress Ver(Y)
90 | gp_wr_data(ax) ; //Sent Y_Address CGRAM
91 | gp_wr_cmm(0x22) ; //Command Write data
92 | gp_wr_data(bg_clr) ; //Sent Data
93 | }
94 | }
95 |
96 | tx <<= 1 ; //Shift Right data 1 bit
97 | ay = ay+1 ; //Increment Y-address
98 | }
99 |
100 | m++ ; //Increment Next pointter byte Data
101 |
102 |
103 | //------- Sent data byte2=3 bit -----
104 |
105 | tx = pgm_read_byte(&ascii_7x11[row][m]) ; //Read data byte2
106 |
107 | for(n=0;n<3;n++) //Loop sent data byte2 = 3 bit
108 | { ;
109 | if(tx & 0x80) //if data bit7 = 1 ,Plot Color area Charecter
110 | {
111 | gp_wr_cmm(0x20) ; //Command Set Adddress Hor(X)
112 | gp_wr_data(ay) ; //Sent X_Address CGRAM
113 | gp_wr_cmm(0x21) ; //Command Set Adddress Ver(Y)
114 | gp_wr_data(ax) ; //Sent Y_Address CGRAM
115 | gp_wr_cmm(0x22) ; //Command Write data
116 | gp_wr_data(fg_clr) ;
117 |
118 | }
119 | else //if data bit7 = 0 ,Plot Color area back ground Charecter
120 | {
121 | if(bg_clr != 1)
122 | {
123 | gp_wr_cmm(0x20) ; //Command Set Adddress Hor(X)
124 | gp_wr_data(ay) ; //Sent X_Address CGRAM
125 | gp_wr_cmm(0x21) ; //Command Set Adddress Ver(Y)
126 | gp_wr_data(ax) ; //Sent Y_Address CGRAM
127 | gp_wr_cmm(0x22) ; //Command Write data
128 | gp_wr_data(bg_clr) ;
129 | }
130 | }
131 |
132 | tx <<= 1 ; //Shift Right data 1 bit
133 | ay = ay+1 ; //Increment Y-address
134 | }
135 |
136 | ax = ax+1 ; //Complet sent data 2 byte(11bit) Increment X-Address
137 | ay = ady ; //Set Position Y-address old
138 |
139 | }
140 |
141 |
142 | //----Fill Back ground Color Position space between Charecter 1 Colum -------
143 |
144 | if(bg_clr != 1)
145 | {
146 | for(n=0;n<11;n++)
147 | {
148 | gp_wr_cmm(0x20) ; //Command Set Adddress Hor(X)
149 | gp_wr_data(ay) ; //Sent X_Address CGRAM
150 | gp_wr_cmm(0x21) ; //Command Set Adddress Ver(Y)
151 | gp_wr_data(ax) ; //Sent Y_Address CGRAM
152 | gp_wr_cmm(0x22) ; //Command Write data
153 | gp_wr_data(bg_clr) ;
154 | ay = ay+1 ; //Increment Y-Address
155 | }
156 | }
157 | }
