habe hier ein Phänomen welches ich so noch nicht kenne.
Erstmal Code:
1 | uint8_t Encoder_Query_v2()
2 | {
3 | encoder_neu = 0;
4 | encoder_neu |= (((ENCODER_PIN & (1<<ENCODER_PIN_UP))>>ENCODER_PIN_UP) << 1);
5 | encoder_neu |= (((ENCODER_PIN & (1<<ENCODER_PIN_DOWN))>>ENCODER_PIN_DOWN) << 0);
6 |
7 |
8 | if (encoder_neu != encoder_old)
9 | {
10 | if ((encoder_neu == 0b00000010) && (encoder_old == 0b00000000)) ret=1; // RIGHT
11 | if ((encoder_neu == 0b00000011) && (encoder_old == 0b00000010)) ret=1; // RIGHT
12 | if ((encoder_neu == 0b00000001) && (encoder_old == 0b00000011)) ret=1; // RIGHT
13 | if ((encoder_neu == 0b00000000) && (encoder_old == 0b00000001)) ret=1; // RIGHT
14 |
15 | if ((encoder_neu == 0b00000001) && (encoder_old == 0b00000000)) ret=2; // LEFT
16 | if ((encoder_neu == 0b00000011) && (encoder_old == 0b00000001)) ret=2; // LEFT
17 | if ((encoder_neu == 0b00000010) && (encoder_old == 0b00000011)) ret=2; // LEFT
18 | if ((encoder_neu == 0b00000000) && (encoder_old == 0b00000010)) ret=2; // LEFT
19 |
20 | }
21 | encoder_old = encoder_neu;
22 |
23 | return ret;
24 | }
25 |
26 | void TogglePIN(uint8_t inPin)
27 | {
28 | PORTD ^= (1<<inPin);
29 | }
30 |
31 |
32 | int main(void)
33 | {
34 | /*
35 |
36 | */
37 | DDRD |= (1<<0);
38 |
39 | while (1) // 2.4MHz on 8MHz Quarz
40 | {
41 | TogglePIN(0);
42 |
43 | // BLOCK1
44 | uint8_t ret=0;
45 | ret=Encoder_Query_v2();
46 |
47 |
48 |
49 | // BLOCK2
50 | /*
51 | uint8_t ret=0;
52 | uint8_t encoder_old=0;
53 | uint8_t encoder_neu=0;
54 |
55 | encoder_neu = 0;
56 | encoder_neu |= (((ENCODER_PIN & (1<<ENCODER_PIN_UP))>>ENCODER_PIN_UP) << 1);
57 | encoder_neu |= (((ENCODER_PIN & (1<<ENCODER_PIN_DOWN))>>ENCODER_PIN_DOWN) << 0);
58 |
59 | if (encoder_neu != encoder_old)
60 | {
61 | if ((encoder_neu == 0b00000010) && (encoder_old == 0b00000000)) ret=1; // RIGHT
62 | if ((encoder_neu == 0b00000011) && (encoder_old == 0b00000010)) ret=1; // RIGHT
63 | if ((encoder_neu == 0b00000001) && (encoder_old == 0b00000011)) ret=1; // RIGHT
64 | if ((encoder_neu == 0b00000000) && (encoder_old == 0b00000001)) ret=1; // RIGHT
65 |
66 | if ((encoder_neu == 0b00000001) && (encoder_old == 0b00000000)) ret=2; // LEFT
67 | if ((encoder_neu == 0b00000011) && (encoder_old == 0b00000001)) ret=2; // LEFT
68 | if ((encoder_neu == 0b00000010) && (encoder_old == 0b00000011)) ret=2; // LEFT
69 | if ((encoder_neu == 0b00000000) && (encoder_old == 0b00000010)) ret=2; // LEFT
70 | }
71 | encoder_old = encoder_neu;
72 | */
73 | }
74 |
75 | return 0;
76 | }
Die Funktion TogglePIN invertiert ständig einen PIN am PORTD, an diesem
wiederum ein Frequenzzähler hängt.
Bei auskommentiertem BLOCK2, zeigt der Zähler 158kHz.
Wird hingegen BLOCK1 kommentiert und BLOCK2 verwendet, dann komme ich
auf 1.5MHz! Also der Faktor 10.
Verwendet wird AVRStudio 4.18.
Was mache ich falsch?
LG
Günter
