1 | # Hey Emacs, this is a -*- makefile -*-
2 | #----------------------------------------------------------------------------
3 | # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
4 | #
5 | # Released to the Public Domain
6 | #
7 | # Additional material for this makefile was written by:
8 | # Peter Fleury
9 | # Tim Henigan
10 | # Colin O'Flynn
11 | # Reiner Patommel
12 | # Markus Pfaff
13 | # Sander Pool
14 | # Frederik Rouleau
15 | # Carlos Lamas
16 | #
17 | #----------------------------------------------------------------------------
18 | # On command line:
19 | #
20 | # make all = Make software.
21 | #
22 | # make clean = Clean out built project files.
23 | #
24 | # make coff = Convert ELF to AVR COFF.
25 | #
26 | # make extcoff = Convert ELF to AVR Extended COFF.
27 | #
28 | # make program = Download the hex file to the device, using avrdude.
29 | # Please customize the avrdude settings below first!
30 | #
31 | # make debug = Start either simulavr or avarice as specified for debugging,
32 | # with avr-gdb or avr-insight as the front end for debugging.
33 | #
34 | # make filename.s = Just compile filename.c into the assembler code only.
35 | #
36 | # make filename.i = Create a preprocessed source file for use in submitting
37 | # bug reports to the GCC project.
38 | #
39 | # To rebuild project do "make clean" then "make all".
40 | #----------------------------------------------------------------------------
41 |
42 |
43 | # MCU name
44 | MCU = atmega8
45 |
46 |
47 | # Processor frequency.
48 | # This will define a symbol, F_CPU, in all source code files equal to the
49 | # processor frequency. You can then use this symbol in your source code to
50 | # calculate timings. Do NOT tack on a 'UL' at the end, this will be done
51 | # automatically to create a 32-bit value in your source code.
52 | # Typical values are:
53 | # F_CPU = 1000000
54 | # F_CPU = 1843200
55 | # F_CPU = 2000000
56 | # F_CPU = 3686400
57 | # F_CPU = 4000000
58 | # F_CPU = 7372800
59 | # F_CPU = 8000000
60 | # F_CPU = 11059200
61 | # F_CPU = 14745600
62 | # F_CPU = 16000000
63 | # F_CPU = 18432000
64 | # F_CPU = 20000000
65 | F_CPU = 8000000
66 |
67 |
68 | # Output format. (can be srec, ihex, binary)
69 | FORMAT = ihex
70 |
71 |
72 | # Target file name (without extension).
73 | TARGET = main
74 |
75 |
76 | # Object files directory
77 | # To put object files in current directory, use a dot (.), do NOT make
78 | # this an empty or blank macro!
79 | OBJDIR = .
80 |
81 |
82 | # List C source files here. (C dependencies are automatically generated.)
83 | SRC = $(TARGET).c
84 |
85 |
86 | # List C++ source files here. (C dependencies are automatically generated.)
87 | CPPSRC =
88 |
89 |
90 | # List Assembler source files here.
91 | # Make them always end in a capital .S. Files ending in a lowercase .s
92 | # will not be considered source files but generated files (assembler
93 | # output from the compiler), and will be deleted upon "make clean"!
94 | # Even though the DOS/Win* filesystem matches both .s and .S the same,
95 | # it will preserve the spelling of the filenames, and gcc itself does
96 | # care about how the name is spelled on its command-line.
97 | ASRC =
98 |
99 |
100 | # Optimization level, can be [0, 1, 2, 3, s].
101 | # 0 = turn off optimization. s = optimize for size.
102 | # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
103 | OPT = s
104 |
105 |
106 | # Debugging format.
107 | # Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
108 | # AVR Studio 4.10 requires dwarf-2.
109 | # AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
110 | DEBUG = dwarf-2
111 |
112 |
113 | # List any extra directories to look for include files here.
114 | # Each directory must be seperated by a space.
115 | # Use forward slashes for directory separators.
116 | # For a directory that has spaces, enclose it in quotes.
117 | EXTRAINCDIRS =
118 |
119 |
120 | # Compiler flag to set the C Standard level.
121 | # c89 = "ANSI" C
122 | # gnu89 = c89 plus GCC extensions
123 | # c99 = ISO C99 standard (not yet fully implemented)
124 | # gnu99 = c99 plus GCC extensions
125 | CSTANDARD = -std=gnu99
126 |
127 |
128 | # Place -D or -U options here for C sources
129 | CDEFS = -DF_CPU=$(F_CPU)UL
130 |
131 |
132 | # Place -D or -U options here for ASM sources
133 | ADEFS = -DF_CPU=$(F_CPU)
134 |
135 |
136 | # Place -D or -U options here for C++ sources
137 | CPPDEFS = -DF_CPU=$(F_CPU)UL
138 | #CPPDEFS += -D__STDC_LIMIT_MACROS
139 | #CPPDEFS += -D__STDC_CONSTANT_MACROS
140 |
141 |
142 |
143 | #---------------- Compiler Options C ----------------
144 | # -g*: generate debugging information
145 | # -O*: optimization level
146 | # -f...: tuning, see GCC manual and avr-libc documentation
147 | # -Wall...: warning level
148 | # -Wa,...: tell GCC to pass this to the assembler.
149 | # -adhlns...: create assembler listing
150 | CFLAGS = -g$(DEBUG)
151 | CFLAGS += $(CDEFS)
152 | CFLAGS += -O$(OPT)
153 | CFLAGS += -funsigned-char
154 | CFLAGS += -funsigned-bitfields
155 | CFLAGS += -fpack-struct
156 | CFLAGS += -fshort-enums
157 | CFLAGS += -Wall
158 | CFLAGS += -Wstrict-prototypes
159 | #CFLAGS += -mshort-calls
160 | #CFLAGS += -fno-unit-at-a-time
161 | #CFLAGS += -Wundef
162 | #CFLAGS += -Wunreachable-code
163 | #CFLAGS += -Wsign-compare
164 | CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
165 | CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
166 | CFLAGS += $(CSTANDARD)
167 |
168 |
169 | #---------------- Compiler Options C++ ----------------
170 | # -g*: generate debugging information
171 | # -O*: optimization level
172 | # -f...: tuning, see GCC manual and avr-libc documentation
173 | # -Wall...: warning level
174 | # -Wa,...: tell GCC to pass this to the assembler.
175 | # -adhlns...: create assembler listing
176 | CPPFLAGS = -g$(DEBUG)
177 | CPPFLAGS += $(CPPDEFS)
178 | CPPFLAGS += -O$(OPT)
179 | CPPFLAGS += -funsigned-char
180 | CPPFLAGS += -funsigned-bitfields
181 | CPPFLAGS += -fpack-struct
182 | CPPFLAGS += -fshort-enums
183 | CPPFLAGS += -fno-exceptions
184 | CPPFLAGS += -Wall
185 | CPPFLAGS += -Wundef
186 | #CPPFLAGS += -mshort-calls
187 | #CPPFLAGS += -fno-unit-at-a-time
188 | #CPPFLAGS += -Wstrict-prototypes
189 | #CPPFLAGS += -Wunreachable-code
190 | #CPPFLAGS += -Wsign-compare
191 | CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
192 | CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
193 | #CPPFLAGS += $(CSTANDARD)
194 |
195 |
196 | #---------------- Assembler Options ----------------
197 | # -Wa,...: tell GCC to pass this to the assembler.
198 | # -adhlns: create listing
199 | # -gstabs: have the assembler create line number information; note that
200 | # for use in COFF files, additional information about filenames
201 | # and function names needs to be present in the assembler source
202 | # files -- see avr-libc docs [FIXME: not yet described there]
203 | # -listing-cont-lines: Sets the maximum number of continuation lines of hex
204 | # dump that will be displayed for a given single line of source input.
205 | ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
206 |
207 |
208 | #---------------- Library Options ----------------
209 | # Minimalistic printf version
210 | PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
211 |
212 | # Floating point printf version (requires MATH_LIB = -lm below)
213 | PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
214 |
215 | # If this is left blank, then it will use the Standard printf version.
216 | PRINTF_LIB =
217 | #PRINTF_LIB = $(PRINTF_LIB_MIN)
218 | #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
219 |
220 |
221 | # Minimalistic scanf version
222 | SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
223 |
224 | # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
225 | SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
226 |
227 | # If this is left blank, then it will use the Standard scanf version.
228 | SCANF_LIB =
229 | #SCANF_LIB = $(SCANF_LIB_MIN)
230 | #SCANF_LIB = $(SCANF_LIB_FLOAT)
231 |
232 |
233 | MATH_LIB = -lm
234 |
235 |
236 | # List any extra directories to look for libraries here.
237 | # Each directory must be seperated by a space.
238 | # Use forward slashes for directory separators.
239 | # For a directory that has spaces, enclose it in quotes.
240 | EXTRALIBDIRS =
241 |
242 |
243 |
244 | #---------------- External Memory Options ----------------
245 |
246 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
247 | # used for variables (.data/.bss) and heap (malloc()).
248 | #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
249 |
250 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
251 | # only used for heap (malloc()).
252 | #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
253 |
254 | EXTMEMOPTS =
255 |
256 |
257 |
258 | #---------------- Linker Options ----------------
259 | # -Wl,...: tell GCC to pass this to linker.
260 | # -Map: create map file
261 | # --cref: add cross reference to map file
262 | LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
263 | LDFLAGS += $(EXTMEMOPTS)
264 | LDFLAGS += $(patsubst %,-L%,$(EXTRALIBDIRS))
265 | LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
266 | #LDFLAGS += -T linker_script.x
267 |
268 |
269 |
270 | #---------------- Programming Options (avrdude) ----------------
271 |
272 | # Programming hardware
273 | # Type: avrdude -c ?
274 | # to get a full listing.
275 | #
276 | AVRDUDE_PROGRAMMER = ponyser#stk500v2
277 |
278 | # com1 = serial port. Use lpt1 to connect to parallel port.
279 | AVRDUDE_PORT = com1 # programmer connected to serial device
280 |
281 | AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
282 | #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
283 |
284 |
285 | # Uncomment the following if you want avrdude's erase cycle counter.
286 | # Note that this counter needs to be initialized first using -Yn,
287 | # see avrdude manual.
288 | #AVRDUDE_ERASE_COUNTER = -y
289 |
290 | # Uncomment the following if you do /not/ wish a verification to be
291 | # performed after programming the device.
292 | #AVRDUDE_NO_VERIFY = -V
293 |
294 | # Increase verbosity level. Please use this when submitting bug
295 | # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
296 | # to submit bug reports.
297 | #AVRDUDE_VERBOSE = -v -v
298 |
299 | AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
300 | AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
301 | AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
302 | AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
303 |
304 |
305 |
306 | #---------------- Debugging Options ----------------
307 |
308 | # For simulavr only - target MCU frequency.
309 | DEBUG_MFREQ = $(F_CPU)
310 |
311 | # Set the DEBUG_UI to either gdb or insight.
312 | # DEBUG_UI = gdb
313 | DEBUG_UI = insight
314 |
315 | # Set the debugging back-end to either avarice, simulavr.
316 | DEBUG_BACKEND = avarice
317 | #DEBUG_BACKEND = simulavr
318 |
319 | # GDB Init Filename.
320 | GDBINIT_FILE = __avr_gdbinit
321 |
322 | # When using avarice settings for the JTAG
323 | JTAG_DEV = /dev/com1
324 |
325 | # Debugging port used to communicate between GDB / avarice / simulavr.
326 | DEBUG_PORT = 4242
327 |
328 | # Debugging host used to communicate between GDB / avarice / simulavr, normally
329 | # just set to localhost unless doing some sort of crazy debugging when
330 | # avarice is running on a different computer.
331 | DEBUG_HOST = localhost
332 |
333 |
334 |
335 | #============================================================================
336 |
337 |
338 | # Define programs and commands.
339 | SHELL = sh
340 | CC = avr-gcc
341 | OBJCOPY = avr-objcopy
342 | OBJDUMP = avr-objdump
343 | SIZE = avr-size
344 | AR = avr-ar rcs
345 | NM = avr-nm
346 | AVRDUDE = avrdude
347 | REMOVE = rm -f
348 | REMOVEDIR = rm -rf
349 | COPY = cp
350 | WINSHELL = cmd
351 |
352 |
353 | # Define Messages
354 | # English
355 | MSG_ERRORS_NONE = Errors: none
356 | MSG_BEGIN = -------- begin --------
357 | MSG_END = -------- end --------
358 | MSG_SIZE_BEFORE = Size before:
359 | MSG_SIZE_AFTER = Size after:
360 | MSG_COFF = Converting to AVR COFF:
361 | MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
362 | MSG_FLASH = Creating load file for Flash:
363 | MSG_EEPROM = Creating load file for EEPROM:
364 | MSG_EXTENDED_LISTING = Creating Extended Listing:
365 | MSG_SYMBOL_TABLE = Creating Symbol Table:
366 | MSG_LINKING = Linking:
367 | MSG_COMPILING = Compiling C:
368 | MSG_COMPILING_CPP = Compiling C++:
369 | MSG_ASSEMBLING = Assembling:
370 | MSG_CLEANING = Cleaning project:
371 | MSG_CREATING_LIBRARY = Creating library:
372 |
373 |
374 |
375 |
376 | # Define all object files.
377 | OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
378 |
379 | # Define all listing files.
380 | LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
381 |
382 |
383 | # Compiler flags to generate dependency files.
384 | GENDEPFLAGS = -MMD -MP -MF .dep/$(@F).d
385 |
386 |
387 | # Combine all necessary flags and optional flags.
388 | # Add target processor to flags.
389 | ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
390 | ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
391 | ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
392 |
393 |
394 |
395 |
396 |
397 | # Default target.
398 | all: begin gccversion sizebefore build sizeafter end
399 |
400 | # Change the build target to build a HEX file or a library.
401 | build: elf hex eep lss sym
402 | #build: lib
403 |
404 |
405 | elf: $(TARGET).elf
406 | hex: $(TARGET).hex
407 | eep: $(TARGET).eep
408 | lss: $(TARGET).lss
409 | sym: $(TARGET).sym
410 | LIBNAME=lib$(TARGET).a
411 | lib: $(LIBNAME)
412 |
413 |
414 |
415 | # Eye candy.
416 | # AVR Studio 3.x does not check make's exit code but relies on
417 | # the following magic strings to be generated by the compile job.
418 | begin:
419 | @echo
420 | @echo $(MSG_BEGIN)
421 |
422 | end:
423 | @echo $(MSG_END)
424 | @echo
425 |
426 |
427 | # Display size of file.
428 | HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
429 | ELFSIZE = $(SIZE) --mcu=$(MCU) --format=avr $(TARGET).elf
430 |
431 | sizebefore:
432 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
433 | 2>/dev/null; echo; fi
434 |
435 | sizeafter:
436 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
437 | 2>/dev/null; echo; fi
438 |
439 |
440 |
441 | # Display compiler version information.
442 | gccversion :
443 | @$(CC) --version
444 |
445 |
446 |
447 | # Program the device.
448 | program: $(TARGET).hex $(TARGET).eep
449 | $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
450 |
451 |
452 | # Generate avr-gdb config/init file which does the following:
453 | # define the reset signal, load the target file, connect to target, and set
454 | # a breakpoint at main().
455 | gdb-config:
456 | @$(REMOVE) $(GDBINIT_FILE)
457 | @echo define reset >> $(GDBINIT_FILE)
458 | @echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
459 | @echo end >> $(GDBINIT_FILE)
460 | @echo file $(TARGET).elf >> $(GDBINIT_FILE)
461 | @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE)
462 | ifeq ($(DEBUG_BACKEND),simulavr)
463 | @echo load >> $(GDBINIT_FILE)
464 | endif
465 | @echo break main >> $(GDBINIT_FILE)
466 |
467 | debug: gdb-config $(TARGET).elf
468 | ifeq ($(DEBUG_BACKEND), avarice)
469 | @echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
470 | @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
471 | $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
472 | @$(WINSHELL) /c pause
473 |
474 | else
475 | @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
476 | $(DEBUG_MFREQ) --port $(DEBUG_PORT)
477 | endif
478 | @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
479 |
480 |
481 |
482 |
483 | # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
484 | COFFCONVERT = $(OBJCOPY) --debugging
485 | COFFCONVERT += --change-section-address .data-0x800000
486 | COFFCONVERT += --change-section-address .bss-0x800000
487 | COFFCONVERT += --change-section-address .noinit-0x800000
488 | COFFCONVERT += --change-section-address .eeprom-0x810000
489 |
490 |
491 |
492 | coff: $(TARGET).elf
493 | @echo
494 | @echo $(MSG_COFF) $(TARGET).cof
495 | $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
496 |
497 |
498 | extcoff: $(TARGET).elf
499 | @echo
500 | @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
501 | $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
502 |
503 |
504 |
505 | # Create final output files (.hex, .eep) from ELF output file.
506 | %.hex: %.elf
507 | @echo
508 | @echo $(MSG_FLASH) $@
509 | $(OBJCOPY) -O $(FORMAT) -R .eeprom -R .fuse -R .lock $< $@
510 |
511 | %.eep: %.elf
512 | @echo
513 | @echo $(MSG_EEPROM) $@
514 | -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
515 | --change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
516 |
517 | # Create extended listing file from ELF output file.
518 | %.lss: %.elf
519 | @echo
520 | @echo $(MSG_EXTENDED_LISTING) $@
521 | $(OBJDUMP) -h -S -z $< > $@
522 |
523 | # Create a symbol table from ELF output file.
524 | %.sym: %.elf
525 | @echo
526 | @echo $(MSG_SYMBOL_TABLE) $@
527 | $(NM) -n $< > $@
528 |
529 |
530 |
531 | # Create library from object files.
532 | .SECONDARY : $(TARGET).a
533 | .PRECIOUS : $(OBJ)
534 | %.a: $(OBJ)
535 | @echo
536 | @echo $(MSG_CREATING_LIBRARY) $@
537 | $(AR) $@ $(OBJ)
538 |
539 |
540 | # Link: create ELF output file from object files.
541 | .SECONDARY : $(TARGET).elf
542 | .PRECIOUS : $(OBJ)
543 | %.elf: $(OBJ)
544 | @echo
545 | @echo $(MSG_LINKING) $@
546 | $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
547 |
548 |
549 | # Compile: create object files from C source files.
550 | $(OBJDIR)/%.o : %.c
551 | @echo
552 | @echo $(MSG_COMPILING) $<
553 | $(CC) -c $(ALL_CFLAGS) $< -o $@
554 |
555 |
556 | # Compile: create object files from C++ source files.
557 | $(OBJDIR)/%.o : %.cpp
558 | @echo
559 | @echo $(MSG_COMPILING_CPP) $<
560 | $(CC) -c $(ALL_CPPFLAGS) $< -o $@
561 |
562 |
563 | # Compile: create assembler files from C source files.
564 | %.s : %.c
565 | $(CC) -S $(ALL_CFLAGS) $< -o $@
566 |
567 |
568 | # Compile: create assembler files from C++ source files.
569 | %.s : %.cpp
570 | $(CC) -S $(ALL_CPPFLAGS) $< -o $@
571 |
572 |
573 | # Assemble: create object files from assembler source files.
574 | $(OBJDIR)/%.o : %.S
575 | @echo
576 | @echo $(MSG_ASSEMBLING) $<
577 | $(CC) -c $(ALL_ASFLAGS) $< -o $@
578 |
579 |
580 | # Create preprocessed source for use in sending a bug report.
581 | %.i : %.c
582 | $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
583 |
584 |
585 | # Target: clean project.
586 | clean: begin clean_list end
587 |
588 | clean_list :
589 | @echo
590 | @echo $(MSG_CLEANING)
591 | $(REMOVE) $(TARGET).hex
592 | $(REMOVE) $(TARGET).eep
593 | $(REMOVE) $(TARGET).cof
594 | $(REMOVE) $(TARGET).elf
595 | $(REMOVE) $(TARGET).map
596 | $(REMOVE) $(TARGET).sym
597 | $(REMOVE) $(TARGET).lss
598 | $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o)
599 | $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst)
600 | $(REMOVE) $(SRC:.c=.s)
601 | $(REMOVE) $(SRC:.c=.d)
602 | $(REMOVE) $(SRC:.c=.i)
603 | $(REMOVEDIR) .dep
604 |
605 |
606 | # Create object files directory
607 | $(shell mkdir $(OBJDIR) 2>/dev/null)
608 |
609 |
610 | # Include the dependency files.
611 | -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
612 |
613 |
614 | # Listing of phony targets.
615 | .PHONY : all begin finish end sizebefore sizeafter gccversion \
616 | build elf hex eep lss sym coff extcoff \
617 | clean clean_list program debug gdb-config
