C Speicherzugriffsfehler
OP #2153976
ich habe ein kleines Problem mit folgendem Code:
int main(int n, char *params[])
if (!(n==2))
{   printf("ERROR.  Usage ./array input_file\n");
else
FILE *fi = fopen(params[1],"rb+");
if(!fi) printf("not opened");
int xdim=getparameter(fi, "Grid dim=\"");
int ydim=getparameter(fi, " x ");
int numparam=getparameter(fi, "Parameters (4 byte)=");
int expsize=getparameter(fi, "Experiment size (bytes)=");
int points=getparameter(fi, "Points=");
fpos_t fpos=getstreampos(fi, ":HEADER_END:");
int numofexp=expsize/4/points;
unsigned char b[4*numparam+expsize];
unsigned char a[4*numparam+expsize];
fsetpos (fi, &fpos);
23
fseek (fi,2,SEEK_CUR);
24
fgetpos(fi, &fpos);
25
fseek (fi, 0, SEEK_END);
26
long size=ftell(fi);
27
28
float biasdiff;
29
float bias[points-1];
30
float *out = (float *)a;
31
int end;
32
int i;
33
int j;
34
int k;
35
36
float ****value = (float ****)malloc(xdim * sizeof(float ***));
37
  for(i = 0; i < xdim; i++) {
38
    value[i] = (float ***)malloc(ydim * sizeof(float **));
39
    for(j = 0; j < ydim; j++){
40
      value[i][j] = (float **)malloc(numparam * sizeof(float *));
41
      for(k = 0; k < numparam; k++)
42
        value[i][j][k] = (float *)malloc(points+numparam * sizeof(float ));
43
44
45
46
fread(b,4,2,fi);
47
for (j=0;j<=7;j=j+4) {
48
49
for (i = 0; i < 4; i++) {
50
                a[i+j] = b[3-i+j];
51
52
53
54
biasdiff=(out[1]>out[0])? (out[1]-out[0]): (out[0]-out[1]);
55
56
if (out[1]>out[0]){
57
for (i=0;i<points;i++){
58
bias[i]=out[0]+i*biasdiff/(points-1);
59
60
61
else{
62
63
bias[i]=out[1]+i*biasdiff/(points-1);
64
65
66
67
68
69
70
int n=1;
71
int x=1;
72
int y=1;
73
74
do {
75
do {
76
  do {
77
78
79
      fread(b,4,points,fi);
80
      fgetpos(fi, &fpos);
81
      end=ftell(fi);
82
      for (j=0; j<=(expsize/numofexp+4*numparam);j=j+4)
83
84
85
                a[i+j] = b[3-i+j];
86
87
88
      for (k=1; k<(points+numparam); k++){
89
      value[x][y][n][k]=out[k];
90
91
92
93
  n++;} while (n<=numofexp&&end<size);n=1;
94
x++;} while (x<=xdim&&end<size);x=1;
95
y++;} while (y<=ydim&&end<size);
96
97
printf("Value is %e\n", value[1][1][1][1]);
98
99
100
fclose(fi);
101
return 0;
102
103
104
Compilieren tut er Problemlos aber sobald ich es dann ausführe gibt es
einen Speicherzugriffsfehler. Hat jemand eine Idee warum?
Wenn ich den Code ein wenig ändere und die Werte nicht in ein Array
schreibe sondern in ein paar hundert Dateien klappt alles prima. Ich
will aber mit den Werte noch rechnen alse wäre ein Array ziemlich
wichtig für mich. Achja und es wäre nett wenn wir noch jmd. sagen könnte
wie ich den Speicher hinterher wieder ordentlich frei mache.
Vielen Dank für eure Hilfe.
Gast #2153979
Ganz wichtig: Formatier deinen Code vernünftig!!!
    if (!(n==2))
    else
        if (!fi) printf("not opened");
23
24
25
        fgetpos(fi, &fpos);
26
27
28
29
        float biasdiff;
30
31
32
        int end;
33
        int i;
34
        int j;
35
        int k;
36
37
38
        for (i = 0; i < xdim; i++)
39
40
41
            for (j = 0; j < ydim; j++)
42
43
44
                for (k = 0; k < numparam; k++)
45
46
47
48
49
        fread(b,4,2,fi);
50
51
52
53
54
55
                a[i+j] = b[3-i+j];
56
57
58
59
60
61
        if (out[1]>out[0])
62
63
64
65
66
67
68
        else
69
70
71
72
73
74
75
76
77
78
79
        int n=1;
80
        int x=1;
81
        int y=1;
82
83
        do
84
85
            do
86
87
                do
88
89
90
91
92
                    fgetpos(fi, &fpos);
93
                    end=ftell(fi);
94
95
96
97
98
                            a[i+j] = b[3-i+j];
99
100
101
102
103
104
105
106
107
                    n++;
108
109
110
                n=1;
111
                x++;
112
113
114
            x=1;
115
            y++;
116
117
118
119
120
121
122
        fclose(fi);
123
        return 0;
124
125
126
(Danke an Code::Blocks)
Was das eigentliche Problem betrifft:
Wenn ich solche Zeilen sehe verliere ich ganz schnell die Lust mich mit
dem Code respektive Problem zu beschäftigen, das geht bestimmt deutlich
einfacher. Und getparameter() kenne ich auch nicht...
Das hier
wäre so
if(!fi)
    fprintf(stderr, "...");
    exit(1); //Programm beenden, ohne Datei gehts nicht weiter!
übrigens deutlich besser.
Also: Was genau soll der Code machen? Alle nötigen Informationen angeben
bitte!
OP #2153981
Hi das mit der Formatierung tut mir Leid. Ich gebe zu das das Programm
vielleicht nicht besonders toll und effektiv ist. Aber es ist auch nur
für mich gedacht.
Was es machen soll:
Ich habe eine Binär-Datei mit Ascii Header. Die Binärdaten geben jeweils
eine Reihe von Spannungswerte an die an einem Punkt X/Y aus
verschiedenen DACs bei verschiedenen Spannungen werden ausgelesen
werden. Ich will die Daten dann in einem 4-Dim Array haben
value[X][Y][DACNummer][Spannung]=2.1V. Wenn ich das habe, will ich dann
Maps bei Fixer Spannung erstellen oder Mittelewerte über verschiedene
X/Y Punkte berechnen.
Hier die fehlenden Zeilen.
int check(char *search, char p[]){ /* */
 int l=strlen(search);
 int i=0;
 int k=0;
 for (i=0;i<l;i++){
 if (p[i]==search[i] && k==0) k=0; else {k=1;}
return k;
fpos_t getstreampos(FILE *pFile, char *search){
  fseek(pFile, 0, SEEK_SET);
  char p[l-1];
  int n = 0;
  fpos_t spos;
  do {
     for (n=0;n<=l-1;n++)
  { p[n] = fgetc (pFile);}
  fseek(pFile, -(l-1), SEEK_CUR);
23
   } while ((check(search, p)!=0)&&(p[l-1]!=EOF)) ;
24
25
26
   fseek(pFile, l-1, SEEK_CUR);
27
   fgetpos(pFile,&spos);
28
29
  return spos;
30
31
32
33
int getparameter(FILE *pFile, char *search){
34
35
36
  int c[10];
37
  char p[l-1];
38
  int n = 0; int i=0;
39
  int num=0;
40
41
42
   do {
43
44
45
46
47
48
49
50
   n=0;
51
  do {
52
    c[n] = fgetc (pFile);
53
        n++;
54
55
      } while(((c[n-1]>='0')&&(c[n-1]<='9'))&&(c[n-1] != EOF));
56
57
for(i=0;i<n-1;i++){
58
num = num+ (c[i]-48)*pow(10,(n-2-i));
59
60
61
62
  return num;
63
OP #2153991
So nochmal den Fehlenden Code in hübscher.
int check(char *search, char p[])  /* */
    int i=0;
    int k=0;
    for (i=0;i<l;i++)
        else
            k=1;
    return k;
    char p[l-1];
    int n = 0;
23
24
    fpos_t spos;
25
26
    do
27
28
29
30
31
32
33
34
35
36
37
38
39
40
    return spos;
41
42
43
44
45
46
47
48
    int c[10];
49
    char p[l-1];
50
    int n = 0;
51
    int i=0;
52
    int num=0;
53
54
55
    do
56
57
58
59
60
61
62
63
64
65
66
67
    n=0;
68
    do
69
70
71
        n++;
72
73
74
    while (((c[n-1]>='0')&&(c[n-1]<='9'))&&(c[n-1] != EOF));
75
76
    for (i=0;i<n-1;i++)
77
78
79
80
81
82
    return num;
83
Gast #2153998
Mal etwas OT:
Sehr schön. ;-)
Nur um Missverständnisse zu vermeiden: Es gibt verschiedene Arten seinen
Code zu formatieren, diese Frage dürfte ähnlich wie der Vergleich
AVR<->PC eine religiöse Angelegenheit sein. Wichtig ist aber: Egal wie
man es macht, es muss durchgängig so gemacht sein und einigermaßen
übersichtlich.
Ob man nun
void foo(void)
   for() {
void foo(void)
   for()
schreibt ist egal (mir gefällt die 2. Version deutlich besser), sowas
void foo(void)
for() {
ist aber definitiv unbrauchbar. Der Code-Formatter von C::B sollte nur
ein Behelfswerkzeug sein um fremdem Code überhaupt irgendeine Struktur
zu verpassen oder seinen persönlichen Vorlieben anzupassen. Seine
eigenen Programme sollte man bereits beim Tippen vernünftig formatieren,
in C ist das extrem wichtig und kann einige Fehler aufdecken.
Falls du mit "Editor" notepad.exe meinst, das ist in der Tat nicht
besonders bequem. C::B ist aber eine komplette IDE, zum Tippen reicht
Programmer's Notepad o.ä.
BTT:
Puh, vierdimensionale Arrays und malloc()...
Poste mal ein Beispiel wie die Dateien die du verarbeiten willst
genau(!) aufgebaut sind und verpasse deinem Code ein paar sinnvolle
Kommentare (welcher Block macht was, wozu sind die "Magic Numbers" = im
Quellcode vorhandene Zahlen wie in "...+4" gut usw).
Ich muss zugeben ich bin zu faul aus dem vorhandenen Code die Struktur
der Daten zu ermittlen um dann zu versuchen den Code zu verstehen.
OP #2154007
Die Daten kommen aus einem SPM-Controller von Nanonis. Das geben sie als
Datei Beschreibung an.
header:
Grid dim="24 x 24"
Grid settings=0.000000E+0;0.000000E+0;6.880776E-9;6.880776E-9;-
2.244028E+1
Sweep Signal="Bias (V)"
Fixed parameters="Sweep Start;Sweep End"
Experiment parameters="X (m);Y (m);Z (m);Z Offset (m);Settling time
(s);Integration time (s)"
# Parameters (4 byte)=8
Experiment size (bytes)=2048
Points=256
Channels="Current (A);Current [bwd] (A)"
Experiment="Grid Spectroscopy"
Date="30.08.2006 14:52:45"
User=user1
:HEADER_END:
continued by, in hexadecimal representation:
0d
00
31
79
0a c0 00 00 00 40 00 00 00 b0 f6 18 55 b1 94 18 42 b0 84 7c 66
00 00 00 39 51 b7 17 38 d1 b7 17 ae ca c3 f0 ae c6 60 e3 ae c2
bf ae bf 5a a3 ae c5 af f1 ae be e8 94 ae ba 8e 31 ae b7 d9
where 0d 0a is the end of line after the :HEADER_END:. Then, c0 00 00 00
(= -2) is the first fixed
parameter (Sweep Start) and so on. 38 d1 b7 17 (=1E-4) corresponds to
the last paramter
(Integration time (s)). After that 256 values of the first data channel
(Current (A)) will follow,
starting with ae ca c3 f0 (= -9.2207E-11). Next will be 256 values of
the second data channel
(Current [bwd] (A)). As no more channels were acquired this will
finalize the first experiment and
the data will continue with the parameters of the 2nd experiment.
Die Sache mit den +4 und umdrehen ist ein Problem von endian floats oder
halt nicht auf den unterschiedlichen Rechnern. Was ich am Schluß machen
will ist: ein Rechteck X mal Y auswählen und die Daten mitteln. Dann
Ableiten und dann Normieren. Details hab ich mir noch nicht überlegt.
Ich habe das früher alles als bash-script machen können weil die alte
Hardware alles hübsch in Ascii ausgespuckt hat. Nun ist die Hardware
modern und auch die Datenmenge ist explodiert. Nachdem ich alles in
Ascii hab sind die Bash Sachen einfach super langsam und ich dachte das
müßte mit C viel schneller gehen.
Gast #2154033
Hast du mal ein paar printf dazwischen gemacht, damit du siehst WO das
Proramm aussteigt.
Hast du auch daran gedacht das die Indizes von 0 bis max-1 gehen.
Also wenn dein 'Grid dim="24 x 24" ' gehen die Inizes von 0 bis 23 oder
von 0 bis 24?
#2154135
Achso:
ich würde mir nicht die Mühe machen, 4 dimensionale Arrays zu bauen.
Alloziiere den Speicher en bloc und überlege dir wie du die Indizes auf
das lineare Array mapst.
Das erspart einem die fehglerträchtigen malloc und free schleifen
Auserdem würde ich das ganze ein wenig besser kapseln
 * Structure that holds the data from an measurement file
typedef struct Data{
  uint32_t xCount;    /**<  number of x Coordinates           */
  uint32_t yCount;    /**<  number of < Coordinates           */
  uint32_t dacCount;  /**<  number of used DACs               */
  uint32_t vCount;    /**<  number of measurements per DAC    */
  float* data;        /**<  array that holds the measurements */
}Data;
/** reads a file and creates Data object.
 *  @return pointer to initialized Data structure\n
 *          Has to be freed witch Data_delete
Data* Data_readFromFile(const char* i_file)
  Data* data = malloc(sizeof(Data));
  uint32_t i;
  uint32_t dataCount;
  //header lesen und o_data befüllen
23
24
  dataCount = data->xCount
25
            * data->yCount
26
            * data->dacCount
27
            * data->vCount;
28
29
30
  data->data = malloc( dataCount  * sizeof(*data->data));
31
32
  // Nicht vergessen: bei lesefehler bisher geholten Speicher wieder freigeben!!!
33
34
  // datenbereich einlesen und in o_data->data schreiben.
35
  //for
36
  //  *Data_getPtr(...) = eingelesener wert
37
38
39
40
/** frees the given Data object */
41
void Data_delete(Data** data)
42
43
  free((*data)->data);
44
  free(*data);
45
  *data = NULL;
46
47
48
49
/** returns a pointer to the data defined by the adress parameters*/
50
float* Data_getPtr(const Data* data, uint32_t x, uint32_t y, uint32_t dac, uint32_t v)
51
52
  uint32_t ind =  (y*data->xCount*data->dacCount*data->vCount)
53
                + (x*data->dacCount*data->vCount)
54
                + (dac * data->vCount)
55
                + v;
56
  return &data->data[ind];
57
58
59
60
// beispiel
61
62
main
63
64
65
  uint32 v;
66
  Data* data = Data_readFromFile("bla.txt");
67
68
  for(v = 0; v < data->vCount; ++v)
69
70
    printf("%f\n", *Data_getPtr(data, 0,0,0,v));
71
72
73
  Data_Delete(&data);
74
OP #2154190
> Proramm aussteigt.
> von 0 bis 24?
Man man bin ich doof!
Na klar bekommt man einen Speichzugriffsfehler wenn man das Array von 0
bis 23 initalisiert und dann auf nummer 24 zugreifen will!
Danke das hat mir sehr geholfen.
Auch an Vlad Tepesch vielen Dank. Leider sind meine Kentnisse in C++
noch schlechter als in C. Deinen anderen Vorschlag werde ich mir mal
annschauen.
Gast #2154330
Bei derart vielen verschachtelten malloc solltest Du auch prüfen ob Dir
malloc überhaupt noch Speicher liefert, sonst knallts auch irgendwann.
Ganz einfach in der umgekehrten Reihenfolge, z.B.
    for(j = 0; j < ydim; j++) {
      for(k = 0; k < numparam; k++) {
        free(value[i][j][k]);
      free(value[i][j]);
    free(value[i]);
  free(value);
OP #2155308
Danke für den Tip mit dem prüfen vom Speicher hab ich mal so gemacht,
ich denke das sollte es tun?
if ( value==NULL )
            fprintf(stderr, "Out of Memory\n");
            exit(1);
Auf der anderen Seite funktioniert das freigeben nicht. Weiss aber nich
wieso. Mal schauen was ich flasch gemacht habe.
