Integer Array
Gast #2169074
Hallo
Ne kurze Frage, warum das hier funktioniert...
TYPE word_ROM is array (0 to 19) of integer;
variable Word : Word_ROM := (1,0,2,0,3,0,4,0,0,0,0,0,0,0,0,0,0,0,1,2);
Pixel := ascii(Word(Word_x))(Char_y)(Char_x);
zur Erklärung:
Pixel := ascii-Package(Zeichennummer im package(Position im
Word_ROM)(y-Position im Zeichen) (x-Position im Zeichen)
klappt alles bestens...mir wir das auf dem Bildschirm angezeigt was
soll.
...hier jedoch der Fehler kommt.
Error (10383): VHDL error at OSD.vhd(126): object cannot be indexed
because it has integer type rather than array type
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 1
warning
  Error: Peak virtual memory: 182 megabytes
  Error: Processing ended: Tue May 03 15:35:49 2011
  Error: Elapsed time: 00:00:02
  Error: Total CPU time (on all processors): 00:00:02
TYPE word_type is array (0 to 19) of integer;
TYPE word_ROM is array (0 to 15) of word_type;
variable Word : Word_ROM := (               (1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1),           (2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2),           (3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3),           (4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4),           (1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1),           (2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2),           (3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3),           (4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4),           (1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1),           (2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2),           (3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3),           (4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4),           (1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1),           (2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2),           (3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3),           (4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4)           );
Pixel := ascii(Word(Word_y )(Word_x))(Char_y)(Char_x);
Hier habe ich das Array erweitert, um mehr Zeichen ausgeben zu können.
Moderator (Firma: Titel) Persönliche Seite #2169101
Funktioniert die Simulation? Falls ja: sieh mal nach, ob dein
Synthesizer vierdimensionale Arrays überhaupt umsetzen kann...
XST z.B. kann nur drei Dimensionen...  :-/
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity MultidimArray is
    Port ( clk  : in  STD_LOGIC;
           dout : out STD_LOGIC_VECTOR (3 downto 0));
end MultidimArray;
-- 5-dimensionales Array: Sim OK, Synthese NOK, weil XST nur bis 3 Array-Ebenen zulässt
architecture BehavioralA of MultidimArray is
subtype BasisTyp is std_logic_vector(3 downto 0);
type SmallArrayTyp is array (0 to 3, 0 to 1) of BasisTyp;
type BigArrayTyp is array (0 to 3, 0 to 1) of SmallArrayTyp;
signal MeinArray : BigArrayTyp := (
    (((x"8",x"9"),(x"a",x"b"),(x"c",x"d"),(x"e",x"f")) , ((x"1",x"2"),(x"3",x"4"),(x"5",x"6"),(x"7",x"8"))),
    (((x"1",x"3"),(x"5",x"7"),(x"9",x"b"),(x"d",x"f")) , ((x"2",x"4"),(x"6",x"8"),(x"a",x"c"),(x"e",x"0"))),
    (((x"d",x"e"),(x"a",x"d"),(x"b",x"e"),(x"e",x"f")) , ((x"b",x"a"),(x"d",x"c"),(x"a",x"b"),(x"1",x"e"))),
    (((x"5",x"5"),(x"a",x"a"),(x"a",x"5"),(x"5",x"a")) , ((x"b",x"a"),(x"d",x"c"),(x"0",x"f"),(x"f",x"e")))  );
signal cnt : unsigned (7 downto 0) := (others => '0');
begin
  process
23
  variable ol,oc,il,ic : integer;
24
  begin
25
     wait until rising_edge(clk);
26
     cnt <= cnt+1;
27
     oc := to_integer(cnt(5 downto 4));
28
     ol := to_integer(cnt(3 downto 3));
29
     ic := to_integer(cnt(2 downto 1));
30
     il := to_integer(cnt(0 downto 0));
31
     dout <= MeinArray(oc,ol)(ic,il);
32
  end process;
33
34
end BehavioralA;
35
36
-- 4-dimenisionales Array: Sim OK, Synthese NOK, weil XST nur bis 3 Array-Ebenen zulässt
37
architecture BehavioralB of MultidimArray is
38
39
40
type BigArrayTyp is array (0 to 1) of SmallArrayTyp;
41
signal MeinArray : BigArrayTyp := ( ((x"8",x"9"),(x"a",x"b"),(x"c",x"d"),(x"e",x"f")) ,
42
                                    ((x"1",x"2"),(x"3",x"4"),(x"5",x"6"),(x"7",x"8")) );
43
44
begin
45
  process
46
47
  begin
48
49
     cnt <= cnt+1;
50
     oc := to_integer(cnt(4 downto 3));
51
52
53
54
     dout <= MeinArray(ol)(ic,il);
55
  end process;
56
57
end BehavioralB;
58
59
-- 3-dimensionales Array: Sim OK, Synthese OK
60
architecture BehavioralC of MultidimArray is
61
62
63
signal MeinArray : SmallArrayTyp := ( ((x"8",x"9"),(x"a",x"b"),(x"c",x"d"),(x"e",x"f")) );
64
65
begin
66
  process
67
68
  begin
69
70
     cnt <= cnt+1;
71
72
73
74
75
     dout <= MeinArray(ic,il);
76
  end process;
77
78
end BehavioralC;
Gast #2169876
...also sim geht und synthese auch, sofern ich
kommentiere.
Also scheint entweder meine Syntax der Array-Ansteuerung flasch zu sein
oder doch ein Synthese Problem?
Das Array selber wir aber synthetisiert.
Gast #2170283
....ist ja das selbe wie bei mir...komischerweise gehts jetzt auch bei
mir.
mal ne andere Frage.
Kann ich in einem std_logic_vector andere werte wie 0 und 1 unterbringen
die man auch auswerten kann?
Gast #2170345
würde auch erkannt werden was kommt? sagen wir mal hier.
if signal = '1' then
a
elsif signal = '0' then
b
elsif signal = '-' then
c
End if;
ich habs mit L und H probiert da regiert er auf die bedingungen wie wenn
1 oder 0 kommt.
Gast #2170440
also ich habe ja einen Ascii-Zeichensatz. der besteht aus einem 3
Dim-Array
TYPE font_type is array (0 to 15) of std_logic_vector (0 to 15);
TYPE font_ROM is array (0 to 15) of font_type;
und ist gefüllt mit 0 und 1. Bei 0 macher nix bei 1 "wird" das Pixel im
Bild schwarz.
hier rufe ich es dann auf.
Geht auch alles wunderbar. Jetzt wollte ich um die Zeichen noch einen
andersfarbigen (weißen) Rand machen. Da die Zeichen ja schwarz sind und
bei schwarzen Hintergrund ja nix zu sehen ist.
Also wollte ich im Zeichen Array noch einen dritten Zustand machen. Ich
habe probiert das Array statt mit std_logic_vektor mit integer
aufzubauen so wie oben. dann könnte ich ja beliebig viele Zustände
eintragen. Nur dann hab ich ein 5-Dim Array als Zeichensatz.
müsste dann so aussehen:
TYPE font_type is array (0 to 15) of integer;
TYPE font_type1 is array (0 to 15) of integer;
TYPE font_ROM is array (0 to 15) of font_type1;
nur der Aufruf klappt dann nicht mehr.
Gast #2171434
...kann es sein, dass ich beim Zeichensatz mit integer Array noch in die
z-Ebene muss
TYPE font_type is array (0 to 15) of integer;   #1
TYPE font_type1 is array (0 to 15) of font_type;  #2
TYPE font_ROM is array (0 to 15) of font_type1; #3
CONSTANT ascii : font_ROM := ...
variable Word : Word_ROM := ...
Aber mit word müsste ich ins Ascii array springen nach #3, mit Char_y
nach #2 und Chra_x nach #1...also habe ich doch eindeutige Adressierung.
Gast #2171568
...hab den Fehler gefunden. Ich hatte vergessen eine deklaration zu
ändern. die stsnd noch auf std_logic und konnte mit den integer werten
logischerweise nix anfangen.
Jetzt funzt alles auch mit dem Zeichensatz aus den integer array's.
jetzt muss ich nur noch geruasfinden, wie ich diese array hier.
                     (2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2),
                     (3,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3),
                     (4,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4),
                     (1,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1),
                     (2,0,0,0,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,2),
                     (3,0,0,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,3),
                     (4,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,4),
                     (1,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,1),
                     (2,0,0,0,0,0,0,0,0,2,0,0,0,0,0,0,0,0,0,2),
                     (3,0,0,0,0,0,0,0,0,0,3,0,0,0,0,0,0,0,0,3),
                     (4,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,4),
                     (1,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,1),
                     (2,0,0,0,0,0,0,0,0,0,0,0,0,2,0,0,0,0,0,2),
                     (3,0,0,0,0,0,0,0,0,0,0,0,0,0,3,0,0,0,0,3),
                     (4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,4)
...mit JTAG verändern kann. Also im laufenden Betrieb des FPGA den
Inhalt ändern kann.
