Warum optimiert ISE 10.1SP3 diese signale weg
Gast #2176375
ich wollte die RS232 Schnittstelle von Lothar Millers HP in Betrieb
nehmen. Jedoch synthetisiert er mir ein Haufen Signale weg und ich
verstehe nicht warum:
WARNING:Xst:1426 - The value init of the FF/Latch txbitcnt_1 hinder the
constant cleaning in the block RS232.
   You should achieve better results by setting this init to 0.
WARNING:Xst:1426 - The value init of the FF/Latch txsr_0 hinder the
WARNING:Xst:2677 - Node <txbitcnt_0> of sequential type is unconnected
in block <RS232>.
WARNING:Xst:2677 - Node <txsr_1> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_2> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_3> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_4> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_5> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_6> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_7> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_8> of sequential type is unconnected in
block <RS232>.
WARNING:Xst:2677 - Node <txsr_9> of sequential type is unconnected in
block <RS232>.
INFO:Xst:2261 - The FF/Latch <txbitcnt_1> in Unit <RS232> is equivalent
to the following FF/Latch, which will be removed : <txsr_0>
WARNING:Xst:2677 - Node <tx_data_reg_0> of sequential type is
unconnected in block <top>.
WARNING:Xst:2677 - Node <tx_data_reg_1> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_2> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_3> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_4> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_5> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_6> of sequential type is
WARNING:Xst:2677 - Node <tx_data_reg_7> of sequential type is
WARNING:Xst:2677 - Node <rxsr_0> of sequential type is unconnected in
block <RS232_instance>.
WARNING:Xst:2677 - Node <rxsr_1> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_2> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_3> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_4> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_5> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_6> of sequential type is unconnected in
WARNING:Xst:2677 - Node <rxsr_7> of sequential type is unconnected in
Optimizing unit <RS232> ...
Moderator (Firma: Titel) Persönliche Seite #2176451
Auf dem Schlauch schrieb:
> Oh mannsen ich hab den Fehler entdeckt gerade nochmal in der Sim:
Doch gut, so eine Simulation... ;-)
> Beim Copypasten die Zeile
>   txcnt <= txcnt+1;
> verhunzt.
"Verhunzt" ist gut...
Die fehlt komplett:
      if(txcnt<(Quarz_Taktfrequenz/Baudrate)-1) then
          -- hier fehlt was  :-o
      else  -- nächstes Bit ausgeben
