1 | #define __TIM4_PERIOD 0x003E8 // 48
2 | #define __TIM4_PSC 0x1C1F // 49
3 | #define __TIM4_ARR 0x270F // 50
4 | #define __TIM4_CR1 0x0004 // 51
5 | #define __TIM4_CR2 0x0000 // 52
6 | #define __TIM4_SMCR 0x0000 // 53
7 | #define __TIM4_CCMR1 0x0000 // 54
8 | #define __TIM4_CCMR2 0x6060 // 55
9 | #define __TIM4_CCER 0x1100 // 56
10 | #define __TIM4_CCR1 0x0000 // 57
11 | #define __TIM4_CCR2 0x0000 // 58
12 | #define __TIM4_CCR3 0x1388 // 59
13 | #define __TIM4_CCR4 0x09C4 // 60
14 | #define __TIM4_DIER 0x0018 // 61
15 | #define __CLOCK_SETUP 1
16 | #define __RCC_CR_VAL 0x01010082
17 | #define __RCC_CFGR_VAL 0x001D8402
18 | #define __HSE
19 |
20 |
21 |
22 |
23 | void init(void)
24 | {
25 |
26 | RCC->CFGR = __RCC_CFGR_VAL; // set clock configuration register
27 | RCC->CR = __RCC_CR_VAL; // set clock control register
28 |
29 | if (__RCC_CR_VAL & RCC_CR_HSION) { // if HSI enabled
30 | while ((RCC->CR & RCC_CR_HSIRDY) == 0); //Wait HSIRDY=1 (HSI is ready)
31 | }
32 |
33 | if (__RCC_CR_VAL & RCC_CR_HSEON) { // if HSE enabled
34 | while ((RCC->CR & RCC_CR_HSERDY) == 0); //Wait HSERDY=1 (HSE is ready)
35 | }
36 |
37 | if (__RCC_CR_VAL & RCC_CR_PLLON) { // if PLL enabled
38 | while ((RCC->CR & RCC_CR_PLLRDY) == 0); //Wait PLLRDY=1 (PLL is ready)
39 | }
40 |
41 | /* Wait till SYSCLK is stabilized (depending on selected clock) */
42 | while ((RCC->CFGR & RCC_CFGR_SWS) != ((__RCC_CFGR_VAL<<2) & RCC_CFGR_SWS));
43 |
44 |
45 |
46 |
47 | RCC->APB1ENR |= RCC_APB1ENR_TIM4EN; // enable clock for TIM4
48 |
49 |
50 | TIM4->CR1 = 0; // reset command register 1
51 | TIM4->CR2 = 0; // reset command register 2
52 | // detailed settings used
53 | TIM4->PSC = __TIM4_PSC; // set prescaler
54 | TIM4->ARR = __TIM4_ARR; // set auto-reload
55 |
56 | TIM4->CCR1 = __TIM4_CCR1; //
57 | TIM4->CCR2 = __TIM4_CCR2; //
58 | TIM4->CCR3 = __TIM4_CCR3; //
59 | TIM4->CCR4 = __TIM4_CCR4; //
60 | TIM4->CCMR1 = __TIM4_CCMR1; //
61 | TIM4->CCMR2 = __TIM4_CCMR2; //
62 | TIM4->CCER = __TIM4_CCER; // set capture/compare enable register
63 | TIM4->SMCR = __TIM4_SMCR; // set slave mode control register
64 |
65 | TIM4->CR1 = __TIM4_CR1; // set command register 1
66 | TIM4->CR2 = __TIM4_CR2;
67 |
68 | }
