1 | .NOLIST
2 | .INCLUDE "m32def.inc" ; Header fuer ATMEGA32
3 | .LIST
4 |
5 |
6 | .equ BAUD = 250000 ; Baudrate
7 |
8 | .equ F_CPU = 16000000 ; Systemtakt in Hz
9 |
10 | .equ UBRR_VAL = ((F_CPU+BAUD*8)/(BAUD*16)-1) ; clever runden
11 | .equ BAUD_REAL = (F_CPU/(16*(UBRR_VAL+1))) ; Reale Baudrate
12 | .equ BAUD_ERROR = ((BAUD_REAL*1000)/BAUD-1000) ; Fehler in Promille
13 |
14 | .if ((BAUD_ERROR>1) || (BAUD_ERROR<-1)) ; max. +/-1 Promille Fehler
15 | .error "Systematischer Fehler der Baudrate grösser 1 Promille und damit zu hoch!"
16 | .endif
17 |
18 |
19 |
20 | ; ============================================
21 | ; R E G I S T E R D E F I N I T I O N E N
22 | ; ============================================
23 | .DEF MehrZweckRegister = R16
24 |
25 | ; ============================================
26 | ; R E S E T U N D I N T V E K T O R E N
27 | ; ============================================
28 | ;
29 | .CSEG
30 | .ORG $0000
31 | jmp Main ; Reset Vektor
32 |
33 | reti ; Int Vektor 2
34 | nop
35 |
36 | reti ; Int Vektor 3
37 | nop
38 |
39 | reti ; Int Vektor 4
40 | nop
41 |
42 | reti ; Int Vektor 5
43 | nop
44 |
45 | reti ; Int Vektor 6
46 | nop
47 |
48 | reti ; Int Vektor 7
49 | nop
50 |
51 | reti ; Int Vektor 8
52 | nop
53 |
54 | reti ; Int Vektor 9
55 | nop
56 |
57 | reti ; Int Vektor 10
58 | nop
59 |
60 | reti ; Int Vektor 11
61 | nop
62 |
63 | reti ; Int Vektor 12
64 | nop
65 |
66 | rjmp int_SPI ; Int Vektor 13 Serial Transfer Complete
67 | nop
68 |
69 | reti ; Int Vektor 14
70 | nop
71 |
72 | reti ; Int Vektor 15
73 | nop
74 |
75 | reti ; Int Vektor 16
76 | nop
77 |
78 | reti ; Int Vektor 17
79 | nop
80 |
81 | reti ; Int Vektor 18
82 | nop
83 |
84 | reti ; Int Vektor 19
85 | nop
86 |
87 | reti ; Int Vektor 20
88 | nop
89 |
90 | reti ; Int Vektor 21
91 | nop
92 |
93 | ;
94 | ; ============================================
95 | ; I N T E R R U P T S E R V I C E
96 | ; ============================================
97 | int_SPI:
98 |
99 | push MehrZweckRegister
100 | in MehrZweckRegister, SREG
101 | push MehrZweckRegister
102 |
103 | ldi MehrZweckRegister, 170
104 | out SPDR, MehrZweckRegister
105 |
106 | pop MehrZweckRegister
107 | out SREG, MehrZweckRegister
108 | pop MehrZweckRegister
109 | reti
110 | ;
111 | ; ============================================
112 | ; U N T E R F U N K T I O N E N
113 | ; ============================================
114 | InitRegister:
115 | clr MehrZweckRegister
116 | ret
117 |
118 |
119 | InitSPI:
120 |
121 | ; PB4 SS, PB5 MOSI, PB6 MISO, PB7 SCLK
122 | ldi MehrZweckRegister, (1<<DDB4)|(1<<DDB5)|(1<<DDB7)
123 | out DDRB,MehrZweckRegister
124 | ; Enable SPI, Master, set clock rate fck/16, cpol=1, cpha=1
125 | ldi MehrZweckRegister, (1<<SPIE)|(1<<SPE)|(1<<MSTR)|(1<<SPR0)|(1<<CPOL)|(1<<CPHA)
126 | out SPCR,MehrZweckRegister
127 |
128 | ret
129 |
130 |
131 | ; ============================================
132 | ; H A U P T - P R O G R A M M I N I T
133 | ; ============================================
134 | Main:
135 |
136 | ldi MehrZweckRegister,high(RAMEND) ; Main program start
137 | ldi MehrZweckRegister,high(RAMEND) ; Main program start
138 | out SPH,MehrZweckRegister ; Set Stack Pointer to top of RAM
139 | ldi MehrZweckRegister,low(RAMEND)
140 | out SPL,MehrZweckRegister
141 |
142 | RCall InitRegister
143 | Rcall InitSPI
144 |
145 |
146 | ldi MehrZweckRegister,1<<SE ; Enable sleep mode
147 | out MCUCR,MehrZweckRegister
148 |
149 | sei ; schalte Ints ein;
150 |
151 | ldi MehrZweckRegister,1<<SPIF ;Enable SPI
152 | out SPSR, MehrZweckRegister
153 |
154 |
155 | ; ============================================
156 | ; P R O G R A M M – S C H L E I F E
157 | ; ============================================
158 | ;
159 | Loop:
160 | sleep ; schlafen legen
161 | nop ; Dummy fuer Aufwachen
162 |
163 | rjmp loop ; zurueck in die Schlafposition
