1 | #include "msp430x24x.h"
2 |
3 | unsigned char lichtsteuerung = 84;
4 | unsigned char lichtmax = 85;
5 | unsigned char lichtmin = 10;
6 | unsigned char volatile auswahl;
7 | unsigned char volatile auswahlaktiv;
8 |
9 |
10 | void setON()
11 | {
12 |
13 | if(auswahl == 98){
14 | P1SEL &= ~BIT2; // P5.0 is I/O
15 | P1DIR |= BIT2; // P5.0 is Output
16 | P1DIR &= ~ BIT0; // P5.0 is Output
17 | P1OUT |= BIT2; //Output auf High
18 | }else{}
19 |
20 | }
21 |
22 | void setOFF(){
23 |
24 | if(auswahl == 99){
25 | P1SEL &= ~BIT2; // P5.0 is I/O
26 | P1DIR |= BIT2; // P5.0 is Output
27 | P1DIR &= ~ BIT0; // P5.0 is Output
28 | P1OUT &= ~ BIT2; //Output auf Low
29 | }else{}
30 |
31 |
32 | }
33 |
34 | void initTimer(){
35 |
36 | //Timer B
37 |
38 | P5DIR |= BIT7; // Set P1.0 to output direction
39 | TBCCTL0 = CCIE; // TRCCR0 interrupt enabled
40 | TBCCR0 = 8000-1;
41 | TBCTL |= TBSSEL_1 + MC_1; // ACLK, upmode, clear TBR
42 |
43 |
44 |
45 | }
46 |
47 | void initPWM(){
48 |
49 | P1DIR |= BIT3; // P1.2 and P1.3 output
50 | P1SEL |= BIT3; // P1.2 and P1.3 TA1/2 otions
51 | CCR0 = 128; // PWM Period/2
52 | CCTL2 = OUTMOD_6; // CCR2 toggle/set
53 | CCR2 = 86; // CCR2 PWM duty cycle
54 |
55 | //The value in CCR0, 128, defines the
56 | //PWM period/2 and the values in CCR1 and CCR2 the PWM duty cycles
57 | TACTL = TASSEL_2 + MC_3; // SMCLK, up-down mode
58 |
59 |
60 | }
61 |
62 |
63 | void initRS232(){
64 |
65 | WDTCTL = WDTPW + WDTHOLD; // Stop WDT
66 | BCSCTL1 = CALBC1_1MHZ; // Set DCO
67 | DCOCTL = CALDCO_1MHZ;
68 |
69 |
70 | P3SEL = 0xf0; // P3.4,5,6,7 = USCI_A0 A1 TXD/RXD
71 | UCA0CTL1 |= UCSSEL_2; // SMCLK
72 | UCA0BR0 = 6; // 1MHz 9600
73 | UCA0BR1 = 0; // 1MHz 9600
74 | UCA0MCTL = UCBRF3 + UCOS16; // Modln UCBRSx=1, over sampling
75 | UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
76 | IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
77 |
78 | /////////////////////////////////////////////////////////////////////////////
79 |
80 | UCA1CTL1 |= UCSSEL_2; // SMCLK
81 | UCA1BR0 = 6; // 1MHz 9600
82 | UCA1BR1 = 0; // 1MHz 9600
83 | UCA1MCTL = UCBRF3 + UCOS16; // Modln UCBRSx=1, over sampling
84 | UCA1CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
85 | UC1IE |= UCA1RXIE; // Enable USCI_A1 RX interrupt
86 |
87 |
88 |
89 | }
90 |
91 |
92 |
93 | void setPWM(char val){
94 |
95 | if(val >= lichtmax)
96 | {
97 | val = 84;
98 | lichtsteuerung = val;
99 | }
100 | if(val <= lichtmin)
101 | {
102 | val = 11;
103 | lichtsteuerung = val;
104 | }
105 |
106 | CCR2 = val;
107 |
108 | }
109 |
110 |
111 |
112 | void main(void)
113 | {
114 | WDTCTL = WDTPW + WDTHOLD; // Stop WDT
115 |
116 | initPWM(); //Init PWM
117 | initTimer(); //Init Timer B bei ca. 1 sec
118 |
119 | initRS232(); //Init RS232 9600 Baud
120 | setON(); //Beim Reset Lampe einschalten danach
121 |
122 | _BIS_SR(GIE); // Enter LPM3 w/ interrupt
123 |
124 |
125 | while(1){
126 |
127 |
128 | switch(auswahl) {
129 | case 10: //Licht Heller
130 | auswahlaktiv = 0;
131 | lichtsteuerung -= 8;
132 | setPWM(lichtsteuerung);
133 | auswahl = 100;
134 | break;
135 |
136 | case 20: //Licht Dunkler
137 | auswahlaktiv = 0;
138 | lichtsteuerung += 8;
139 | setPWM(lichtsteuerung);
140 | auswahl = 100;
141 | break;
142 |
143 | case 40: //Dunkel
144 | auswahlaktiv = 0;
145 | lichtsteuerung = 8;
146 | setPWM(lichtsteuerung);
147 | auswahl = 100;
148 | break;
149 |
150 | case 50: //Licht Dunkler
151 | auswahlaktiv = 0;
152 | lichtsteuerung = 83;
153 | setPWM(lichtsteuerung);
154 | auswahl = 100;
155 | break;
156 |
157 | case 30: //lichtmodus Dimmung
158 | setPWM(lichtsteuerung); //machts solange bis case nicht mehr 30 ist!!
159 | auswahlaktiv = 30;
160 | auswahl = 100;
161 | break;
162 |
163 | case 99: //Licht Aus
164 | setOFF(); //EVG OFF
165 | auswahl = 100;
166 | break;
167 |
168 | case 98: //Licht ein
169 | setON(); //EVG ON
170 | auswahl = 100;
171 | break;
172 |
173 | }
174 | }
175 |
176 |
177 | }
178 |
179 | //Für TX Interrupt RS232
180 |
181 | #pragma vector=USCIAB0RX_VECTOR
182 | __interrupt void USCI0RX_ISR(void)
183 | {
184 | UCA0TXBUF = UCA0RXBUF;
185 | }
186 |
187 | //Für RX Interrupt RS232
188 |
189 | #pragma vector=USCIAB1RX_VECTOR
190 | __interrupt void USCI1RX_ISR(void)
191 | {
192 | //UCA1TXBUF = UCA1RXBUF; // TX -> RXed character
193 | auswahl = UCA1RXBUF;
194 | }
195 |
196 | //Für Timer Dimmingmodus
197 |
198 |
199 | // Timer B0 interrupt service routine
200 | #pragma vector=TIMERB0_VECTOR
201 | __interrupt void Timer_B (void)
202 | {
203 | if(auswahlaktiv == 30){
204 | lichtsteuerung = lichtsteuerung - 5;
205 | setPWM(lichtsteuerung);
206 | if(lichtsteuerung <= 4){
207 | lichtsteuerung = 84;
208 | CCR2 = lichtsteuerung;
209 | auswahlaktiv = 100;
210 |
211 | }
212 | }
213 |
214 | P5OUT ^= BIT7; // Toggle P5.7
215 |
216 | }
