1 |
2 | // Includes
3 | #include "stm32f10x.h"
4 | #include "STM32vldiscovery.h"
5 | #include "stdio.h"
6 | #include "stdlib.h"
7 | #include "string.h"
8 | #include "stm32f10x_i2c.h"
9 |
10 |
11 | // Private define
12 | //I2C
13 | #define I2C1_SLAVE_ADDRESS7 0x38 // I2C Adresse Sensor
14 | #define I2C1_Own_ADDRESS7 0x30 // I2C Adresse µC
15 | #define ClockSpeed 200000 // 200 KHz
16 |
17 | // Private variables
18 | I2C_InitTypeDef I2C_InitStructure;
19 | GPIO_InitTypeDef GPIO_InitStructure;
20 |
21 | // Private function prototypes
22 | //I2C Protokoll
23 | void I2C_Initialisieren(void);
24 | void I2C_Write(uint8_t Register_Adress, uint8_t Data);
25 | uint8_t I2C_Read(uint8_t Register_Adress);
26 | void I2C_Demo(void);
27 |
28 | /* Hauptprogramm -------------------------------------------------------------*/
29 |
30 | int main(void) //S.936
31 |
32 | {
33 | // uint8_t i=0; //Zählvariable for Schleife
34 |
35 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
36 | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
37 | RCC_APB2Periph_GPIOE | RCC_APB2Periph_USART1|
38 | RCC_APB2Periph_AFIO | RCC_APB2ENR_AFIOEN ,
39 | ENABLE)
40 |
41 |
42 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
43 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
44 | GPIO_Init(GPIOA, &GPIO_InitStructure);
45 | GPIO_Init(GPIOB, &GPIO_InitStructure);
46 | GPIO_Init(GPIOC, &GPIO_InitStructure);
47 | GPIO_Init(GPIOD, &GPIO_InitStructure);
48 | GPIO_Init(GPIOE, &GPIO_InitStructure);
49 |
50 | I2C_Initialisieren();
51 | I2C_Demo();
52 |
53 | while(1){ }
54 | }
55 |
56 |
57 |
58 |
59 | //%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%____I2C Bus_____%%%%%%%%%%%%%%%%%%%
60 | void I2C_Initialisieren(void){
61 |
62 | //Pins konfigurieren
63 | GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_6) | (GPIO_Pin_7);
64 | //SCL (PB6),SDA (PB7): Alternate Function, Open Drain
65 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
66 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
67 | // Open Drain, I2C bus pulled high externally
68 |
69 | GPIO_Init(GPIOB, &GPIO_InitStructure);
70 |
71 | I2C_Cmd(I2C1, ENABLE); //Enable I2C1
72 |
73 | //Register I2C ->Seite 539
74 | I2C_InitStructure.I2C_ClockSpeed=ClockSpeed;
75 | I2C_InitStructure.I2C_Mode=I2C_Mode_I2C;
76 | I2C_InitStructure.I2C_DutyCycle=I2C_DutyCycle_2;
77 | I2C_InitStructure.I2C_OwnAddress1=I2C1_Own_ADDRESS7;
78 | I2C_InitStructure.I2C_Ack=I2C_Ack_Enable;
79 | I2C_InitStructure.I2C_AcknowledgedAddress=I2C_AcknowledgedAddress_7bit;
80 |
81 | I2C_Init(I2C1, &I2C_InitStructure);
82 |
83 | }
84 |
85 | void I2C_Write(uint8_t Register_Adress, uint8_t Data){
86 |
87 | while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
88 |
89 | /* Send I2C1 START condition */
90 | I2C_GenerateSTART(I2C1, ENABLE);
91 |
92 | /* Test on I2C1 EV5 and clear it */
93 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
94 |
95 | /* Send slave Address for write */
96 | I2C_Send7bitAddress(I2C1, I2C1_SLAVE_ADDRESS7, I2C_Direction_Transmitter);
97 |
98 | /* Test on I2C1 EV6 and clear it */
99 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
100 |
101 | /* Send I2C1 slave register address */
102 | I2C_SendData(I2C1, Register_Adress);
103 |
104 | /* Test on I2C1 EV8_2 and clear it */
105 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
106 |
107 | /* Send I2C1 slave Register data */
108 | I2C_SendData(I2C1, Data);
109 |
110 | /* Test on I2C1 EV8_8 and clear it */
111 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
112 |
113 | /* Send I2C1 STOP Condition */
114 | I2C_GenerateSTOP(I2C1, ENABLE);
115 | }
116 |
117 | uint8_t I2C_Read(uint8_t Register_Adress){
118 |
119 | uint8_t I2C_ReceivedData=0;
120 | /*!< While the bus is busy */
121 | while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)) ;
122 |
123 | /*!< Send START condition */
124 | I2C_GenerateSTART(I2C1, ENABLE);
125 |
126 | /*!< Test on EV5 and clear it */
127 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
128 |
129 | /*!< Send EEPROM address for write */
130 | I2C_Send7bitAddress(I2C1, I2C1_SLAVE_ADDRESS7, I2C_Direction_Transmitter);
131 |
132 | /*!< Test on EV6 and clear it */
133 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
134 |
135 | //send the reg select COMMAND byte
136 | I2C_SendData(I2C1, Register_Adress);
137 |
138 | /*!< Test on EV8 and clear it */
139 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
140 |
141 | //send START condition a second time
142 | I2C_GenerateSTART(I2C1, ENABLE);
143 |
144 | /*!< Test on EV5 and clear it */
145 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
146 |
147 | /*!< Send EEPROM address for read */
148 | I2C_Send7bitAddress(I2C1, I2C1_SLAVE_ADDRESS7, I2C_Direction_Receiver);
149 |
150 | /*!< Test on EV6 and clear it */
151 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
152 |
153 | // /*!< Test on EV7 and clear it */
154 | if(I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
155 | {
156 | /*!< Read a byte from the EEPROM */
157 | I2C_ReceivedData = I2C_ReceiveData(I2C1);
158 | }
159 |
160 | /*!< Disable Acknowledgement */
161 | I2C_AcknowledgeConfig(I2C1, DISABLE);
162 |
163 | /*!< Send STOP Condition */
164 | I2C_GenerateSTOP(I2C1, ENABLE);
165 |
166 | /*!< Enable Acknowledgement to be ready for another reception */
167 | I2C_AcknowledgeConfig(I2C1, ENABLE);
168 |
169 | return I2C_ReceivedData;
170 | }
171 |
172 | void I2C_Demo(void){
173 |
174 | uint8_t I2C_Data=0x00;
175 | uint8_t I2C_Register_Adress=0x0b;
176 |
177 | I2C_Data=I2C_Read(I2C_Register_Adress);
178 | }
