1 | # Start of default section
2 | #
3 |
4 | TRGT = arm-none-eabi-
5 | CC = $(TRGT)gcc
6 | CP = $(TRGT)objcopy
7 | AS = $(TRGT)gcc -x assembler-with-cpp
8 | BIN = $(CP) -O ihex
9 |
10 | MCU = arm7tdmi
11 |
12 | # List all default C defines here, like -D_DEBUG=1
13 | DDEFS =
14 |
15 | # List all default ASM defines here, like -D_DEBUG=1
16 | DADEFS =
17 |
18 | # List all default directories to look for include files here
19 | DINCDIR = ./../../../yagarto/arm-none-eabi/include \
20 | ./../../../yagarto/lib/gcc/arm-none-eabi/4.6.0/include \
21 | ./../../../yagarto/lib/gcc/arm-none-eabi/4.6.0/include-fixed \
22 |
23 |
24 | # List the default directory to look for the libraries here
25 | DLIBDIR =
26 |
27 | # List all default libraries here
28 | DLIBS =
29 |
30 | #
31 | # End of default section
32 | ##############################################################################################
33 |
34 | ##############################################################################################
35 | # Start of user section
36 | #
37 |
38 | # Define project name here
39 | PROJECT = Start_LPC2468
40 |
41 | # Define linker script file here
42 | LDSCRIPT_RAM = ./Setup/LPC2468_RAM.ld
43 | LDSCRIPT_FLASH = ./Setup/LPC2468_FLASH.ld
44 |
45 | # List all user C define here, like -D_DEBUG=1
46 | UDEFS = -DDEBUG=1
47 |
48 | # Define ASM defines here
49 | UADEFS =
50 |
51 | # List C source files here
52 | SRC = \
53 | ./Application/Main.c \
54 | ./Application/LED.c \
55 |
56 | # List ASM source files here
57 | ASRC = \
58 | ./Setup/LPC2468_Startup.S \
59 | ./Setup/JLINKDCC_HandleDataAbort.S \
60 | ./Setup/JLINKDCC_Process_ASM.S
61 |
62 | # List all user directories here
63 | UINCDIR = ./../../Inc \
64 | ./Inc \
65 |
66 | # List the user directory to look for the libraries here
67 | ULIBDIR =
68 |
69 | # List all user libraries here
70 | ULIBS = ./../../Lib/libosA4LNDP.a
71 |
72 | # Define optimisation level here
73 | OPT = -O1
74 |
75 | #
76 | # End of user defines
77 | ##############################################################################################
78 |
79 |
80 | INCDIR = $(patsubst %,-I%,$(DINCDIR) $(UINCDIR))
81 | LIBDIR = $(patsubst %,-L%,$(DLIBDIR) $(ULIBDIR))
82 | DEFS = $(DDEFS) $(UDEFS)
83 | ADEFS = $(DADEFS) $(UADEFS)
84 | OBJS = $(ASRC:.S=.o) $(SRC:.c=.o)
85 | LIBS = $(DLIBS) $(ULIBS)
86 | MCFLAGS = -mcpu=$(MCU)
87 |
88 | ASFLAGS = $(MCFLAGS) -gdwarf-2 $(ADEFS)
89 | CPFLAGS = $(MCFLAGS) $(OPT) -gdwarf-2 -fomit-frame-pointer -Wall -Wstrict-prototypes -fverbose-asm -Wa,-ahlms=$(<:.c=.lst) $(DEFS)
90 | LDFLAGS_RAM = $(MCFLAGS) -nostartfiles -T$(LDSCRIPT_RAM) -Wl,-Map=$(PROJECT)_RAM.map,--cref,--no-warn-mismatch $(LIBDIR)
91 | LDFLAGS_FLASH = $(MCFLAGS) -nostartfiles -T$(LDSCRIPT_FLASH) -Wl,-Map=$(PROJECT)_FLASH.map,--cref,--no-warn-mismatch $(LIBDIR)
92 |
93 |
94 | # Generate dependency information
95 | CPFLAGS += -MD -MP -MF .dep/$(@F).d
96 |
97 | #
98 | # makefile rules
99 | #
100 |
101 | all: FLASH
102 |
103 |
104 | RAM: $(OBJS) $(PROJECT)_RAM.elf $(PROJECT)_RAM.hex
105 |
106 | FLASH: $(OBJS) $(PROJECT)_FLASH.elf $(PROJECT)_FLASH.hex
107 |
108 | %o : %c
109 | @echo "Compiling $<"
110 | @$(CC) -c $(CPFLAGS) -I . $(INCDIR) $< -o $@
111 |
112 | %o : %s
113 | @echo "Assembling $<"
114 | @$(AS) -c $(ASFLAGS) $< -o $@
115 |
116 | %RAM.elf: $(OBJS)
117 | @echo "Linking $@"
118 | @$(CC) $(OBJS) $(LDFLAGS_RAM) $(LIBS) -o $@
119 |
120 | %FLASH.elf: $(OBJS)
121 | @echo "Linking $@"
122 | @$(CC) $(OBJS) $(LDFLAGS_FLASH) $(LIBS) -o $@
123 |
124 | %hex: %elf
125 | @echo "Create $@ from $<"
126 | @$(BIN) $< $@
127 |
128 | clean:
129 | -rm -f $(OBJS)
130 | -rm -f $(PROJECT)_RAM.elf
131 | -rm -f $(PROJECT)_RAM.map
132 | -rm -f $(PROJECT)_RAM.hex
133 | -rm -f $(PROJECT)_FLASH.elf
134 | -rm -f $(PROJECT)_FLASH.map
135 | -rm -f $(PROJECT)_FLASH.hex
136 | -rm -f $(SRC:.c=.c.bak)
137 | -rm -f $(SRC:.c=.lst)
138 | -rm -f $(SRC:.c=.o)
139 | -rm -f $(ASRC:.S=.S.bak)
140 | -rm -f $(ASRC:.S=.lst)
141 | -rm -f $(ASRC:.S=.o)
142 | -rm -fR .dep
143 |
144 | #
145 | # Include the dependency files, should be the last of the makefile
146 | #
147 | -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
148 |
149 | # *** EOF ***
