1 | library IEEE;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_arith.all;
4 |
5 | entity spi is
6 | port ( spi_Tx : out std_logic; -- SPI-lines
7 | spi_clk : out std_logic;
8 | spi_cs : out std_logic;
9 | spi_Rx : in std_logic;
10 |
11 | new_data : in std_logic; -- sign
12 |
13 | TxData : in std_logic_vector(7 downto 0);
14 | RxData : out std_logic_vector(7 downto 0);
15 |
16 | reset : in std_logic;
17 | clk : in std_logic);
18 | end spi;
19 |
20 | -------------------------------------------------------------------------------
21 | -- ARCHITECTURE
22 | -------------------------------------------------------------------------------
23 | architecture rtl of spi is
24 |
25 | signal s_TxBuf : std_logic_vector(7 downto 0);
26 | signal s_RxBuf : std_logic_vector(7 downto 0);
27 | signal s_cnt : std_logic_vector(4 downto 0);
28 | signal s_busy : std_logic;
29 |
30 | begin
31 |
32 | p_spi_master : process(clk,reset)
33 | begin
34 | if(reset = '1')then
35 | s_TxBuf <= (others => '0');
36 | s_RxBuf <= (others => '0');
37 | s_cnt <= (others => '0');
38 | s_busy <= '0';
39 | spi_cs <= '1';
40 | spi_clk <= '1';
41 | spi_Tx <= '1';
42 | elsif(clk = '1' and clk'event) then
43 | if(new_data = '1' and s_busy = '0')then
44 | s_TxBuf <= TxData;
45 | s_busy <= '1';
46 | s_cnt <= (others => '0');
47 | spi_cs <= '0';
48 | end if;
49 |
50 | if(s_busy = '1')then -- shifting is enabled
51 | s_cnt <= unsigned(s_cnt) + conv_unsigned(1,1);
52 | if(s_cnt(4) /= '1')then -- are 16 ticks over?
53 | if(s_cnt(0) = '0')then -- shift out data on every "even" LSB
54 | s_TxBuf <= s_TxBuf(6 downto 0) & '0'; -- shift operation
55 | spi_Tx <= s_TxBuf(7); -- data out
56 | spi_clk <= '0'; -- toggle sclk
57 | else -- s_cnt is "odd": rising sclk
58 | s_RxBuf <= s_RxBuf(6 downto 0) & spi_Rx; -- read RxLine
59 | spi_clk <= '1';
60 | end if;
61 | else -- 16th tick is reached
62 | -- bring module in 'idle'-state
63 | s_busy <= '0';
64 | spi_cs <= '1';
65 | spi_Tx <= '1';
66 | spi_clk <= '1';
67 | RxData <= s_RxBuf;
68 | s_TxBuf <= (others => '0');
69 | s_RxBuf <= (others => '0');
70 | s_cnt <= (others => '0');
71 | end if;
72 | end if;
73 | end if;
74 | end process p_spi_master;
75 | end rtl;
