1 | #include <avr/io.h>
2 | #include "util/delay.h"
3 | #include <avr/interrupt.h>
4 |
5 |
6 | uint8_t reset_oben0 = 0;
7 | uint8_t reset_unten0 = 0;
8 | volatile uint8_t on_oben0 = 0;
9 | volatile uint8_t on_unten0 = 0;
10 | uint8_t reset_oben1 = 0;
11 | uint8_t reset_unten1 = 0;
12 | volatile uint8_t on_oben1 = 0;
13 | volatile uint8_t on_unten1 = 0;
14 | uint8_t blinker_an = 0;
15 | volatile uint8_t schaltkanal_an = 0;
16 |
17 | int schaltkanal(void)
18 | {
19 | //Schaltkanal
20 | if(PIND & (1 << PD0))
21 | {
22 | PORTB |= (1 << PB3) | (1 << PB2);
23 | schaltkanal_an = 1;
24 | }
25 | else
26 | {
27 | PORTB &= ~((1 << PB3) | (1 << PB2)); //Abblendlicht Ein- & Ausschalten
28 | schaltkanal_an = 0;
29 | }
30 |
31 | }
32 |
33 | int bremse(void)
34 | {
35 |
36 | if(PIND & (1 << PD1)) //Bremsleuchten bei Signal an PD1
37 | {
38 | PORTB &= ~(1 << PB4);
39 | PORTB &= ~(1 << PB5); //Bremslicht hinten aus
40 | if (schaltkanal_an == 1) PORTB |= (1 << PB3); //Normales Licht hinten an
41 |
42 |
43 |
44 | }
45 | else
46 | {
47 | PORTB |= (1 << PB4);
48 | if (schaltkanal_an == 1) PORTB &= ~(1 << PB3); //Normales Licht hinten aus
49 | PORTB |= (1 << PB5);
50 |
51 |
52 |
53 | }
54 |
55 |
56 | }
57 |
58 |
59 | int main()
60 | {
61 |
62 | DDRB = (1 << DDB2) | (1 << DDB3) | (1 << DDB4) | (1 << DDB5);
63 | PORTB = (0 << PB2) | (0 << PB3) | (1 << PB4) | (1 << PB5); //PB2 = Licht vorne, PB3 = Licht hinten, PB4 = Bremslicht, PB5 = Licht hinten - Bremse
64 | DDRD = (0 << DDD0) | (0 << DDD3) | (1 << DDD7) | (0 << DDD1) | (0 << DDD2); //PD0 = Schaltkanal, PD3 = Interrupt, PD7 = Blinker Ausgang, PD1 = Motorsignal
65 | DDRC = (1 << DDC4) | (1 << DDC5);
66 | PORTC = (0 << PC4) | (0 << PC5);
67 |
68 | GICR = (1 << INT0) | (1 << INT1); //INT1/0-Interrupt aktivieren
69 |
70 | MCUCR = (1 << ISC01)|(1 << ISC00)|(1 << ISC11)|(1 << ISC10); //Aktiviere Sensitivität auf steigende Flanke
71 |
72 | sei(); //Generell Interrupts aktivieren
73 |
74 |
75 | while (1) //Hauptschleife
76 | {
77 | start:
78 | //Immer dafür sorgen, dass Blaulicht und Blinker aus sind.
79 | PORTC = (0 << PC4) | (0 << PC5);
80 | PORTD = (1 << PD7);
81 |
82 | //Schaltkanal
83 | schaltkanal();
84 | bremse();
85 |
86 | //NUR Blaulicht an?
87 | while(on_oben1==1 && on_unten1==0)
88 | {
89 |
90 |
91 | //Links
92 | PORTC = (1 << PC4) | (0 << PC5);
93 | _delay_ms(130);
94 | PORTC = (0 << PC4) | (0 << PC5);
95 | _delay_ms(50);
96 | PORTC = (1 << PC4) | (0 << PC5);
97 | _delay_ms(30);
98 | PORTC = (0 << PC4) | (0 << PC5);
99 | _delay_ms(50);
100 | PORTC = (1 << PC4) | (0 << PC5);
101 | _delay_ms(30);
102 | PORTC = (0 << PC4) | (0 << PC5);
103 | _delay_ms(50); //340ms
104 |
105 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
106 | //Schaltkanal
107 | schaltkanal();
108 |
109 | //Rechts
110 | PORTC = (0 << PC4) | (1 << PC5);
111 | _delay_ms(135);
112 | //Blinker
113 | PORTC = (0 << PC4) | (0 << PC5);
114 | _delay_ms(50);
115 | PORTC = (0 << PC4) | (1 << PC5);
116 | _delay_ms(30);
117 | PORTC = (0 << PC4) | (0 << PC5);
118 | _delay_ms(50);
119 | PORTC = (0 << PC4) | (1 << PC5);
120 | _delay_ms(30);
121 | PORTC = (0 << PC4) | (0 << PC5);
122 | _delay_ms(160); //455ms
123 |
124 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
125 | //Schaltkanal
126 | schaltkanal();
127 |
128 | //Links
129 | PORTC = (1 << PC4) | (0 << PC5);
130 | _delay_ms(130);
131 | PORTC = (0 << PC4) | (0 << PC5);
132 | _delay_ms(25);
133 | //Blinker
134 | _delay_ms(25);
135 | PORTC = (1 << PC4) | (0 << PC5);
136 | _delay_ms(30);
137 | PORTC = (0 << PC4) | (0 << PC5);
138 | _delay_ms(50);
139 | PORTC = (1 << PC4) | (0 << PC5);
140 | _delay_ms(30);
141 | PORTC = (0 << PC4) | (0 << PC5);
142 | _delay_ms(20); //310ms
143 |
144 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
145 | //Schaltkanal
146 | schaltkanal();
147 |
148 | //Rechts
149 | PORTC = (0 << PC4) | (1 << PC5);
150 | _delay_ms(130);
151 | PORTC = (0 << PC4) | (0 << PC5);
152 | _delay_ms(50);
153 | PORTC = (0 << PC4) | (1 << PC5);
154 | _delay_ms(30);
155 | PORTC = (0 << PC4) | (0 << PC5);
156 | _delay_ms(50);
157 | PORTC = (0 << PC4) | (1 << PC5);
158 | _delay_ms(30);
159 | PORTC = (0 << PC4) | (0 << PC5);
160 | _delay_ms(30);
161 | //Blinker
162 | _delay_ms(100); //420ms
163 |
164 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
165 | //Schaltkanal
166 | schaltkanal();
167 |
168 | //-------------------------------------------------
169 |
170 | PORTC = (1 << PC4) | (0 << PC5);
171 | _delay_ms(130);
172 | PORTC = (0 << PC4) | (0 << PC5);
173 | _delay_ms(50);
174 | PORTC = (1 << PC4) | (0 << PC5);
175 | _delay_ms(30);
176 | PORTC = (0 << PC4) | (0 << PC5);
177 | _delay_ms(50);
178 | PORTC = (1 << PC4) | (1 << PC5);
179 | _delay_ms(30);
180 | PORTC = (0 << PC4) | (0 << PC5);
181 | _delay_ms(50); //290ms
182 |
183 | PORTC = (0 << PC4) | (1 << PC5);
184 | _delay_ms(35);
185 | //Blinker
186 | _delay_ms(95);
187 | PORTC = (0 << PC4) | (0 << PC5);
188 | _delay_ms(50);
189 | PORTC = (0 << PC4) | (1 << PC5);
190 | _delay_ms(30);
191 | PORTC = (0 << PC4) | (0 << PC5);
192 | _delay_ms(50);
193 | PORTC = (0 << PC4) | (1 << PC5);
194 | _delay_ms(30);
195 | PORTC = (1 << PC4) | (0 << PC5);
196 | _delay_ms(50);
197 | PORTC = (1 << PC4) | (1 << PC5);
198 | _delay_ms(30);
199 | PORTC = (0 << PC4) | (0 << PC5);
200 | _delay_ms(50);
201 | PORTC = (0 << PC4) | (0 << PC5);
202 | _delay_ms(30); //450ms
203 |
204 |
205 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
206 | //Schaltkanal
207 | schaltkanal();
208 |
209 | //-------------------------------------------------
210 |
211 | PORTC = (1 << PC4) | (0 << PC5);
212 | _delay_ms(60);
213 | //Blinker
214 | _delay_ms(70);
215 | PORTC = (0 << PC4) | (0 << PC5);
216 | _delay_ms(50);
217 | PORTC = (1 << PC4) | (0 << PC5);
218 | _delay_ms(30);
219 | PORTC = (0 << PC4) | (0 << PC5);
220 | _delay_ms(50);
221 | PORTC = (1 << PC4) | (0 << PC5);
222 | _delay_ms(30);
223 | PORTC = (0 << PC4) | (0 << PC5);
224 | _delay_ms(50); //340ms
225 |
226 | if(on_oben1==0 || on_unten1==1) goto start;//Abbruch
227 | //Schaltkanal
228 | schaltkanal();
229 |
230 | PORTC = (0 << PC4) | (1 << PC5);
231 | _delay_ms(130);
232 | PORTC = (0 << PC4) | (0 << PC5);
233 | _delay_ms(50);
234 | PORTC = (0 << PC4) | (1 << PC5);
235 | _delay_ms(15);
236 | //Blinker
237 | _delay_ms(15);
238 | PORTC = (0 << PC4) | (0 << PC5);
239 | _delay_ms(50);
240 | PORTC = (0 << PC4) | (1 << PC5);
241 | _delay_ms(30);
242 | PORTC = (0 << PC4) | (0 << PC5);
243 | _delay_ms(50);
244 | PORTC = (0 << PC4) | (1 << PC5);
245 | _delay_ms(30);
246 | PORTC = (0 << PC4) | (0 << PC5);
247 | _delay_ms(50);
248 | PORTC = (0 << PC4) | (1 << PC5);
249 | _delay_ms(30);
250 | PORTC = (0 << PC4) | (0 << PC5);
251 | _delay_ms(50);
252 | PORTC = (1 << PC4) | (1 << PC5);
253 | _delay_ms(20);
254 | PORTC = (0 << PC4) | (0 << PC5);
255 | _delay_ms(150); //520ms
256 | //Blinker
257 |
258 |
259 |
260 |
261 | }
262 |
263 |
264 |
265 | //NUR Blinker an?
266 | while(on_unten1==1 && on_oben1==0)
267 | {
268 |
269 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}
270 | _delay_ms(475);
271 | //Schaltkanal
272 | schaltkanal();
273 |
274 |
275 | }
276 |
277 |
278 |
279 | //Blinker und Blaulicht an?
280 | while(on_unten1==1 && on_oben1==1)
281 | {
282 |
283 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
284 | //Schaltkanal
285 | schaltkanal();
286 |
287 | //Links
288 | PORTC = (1 << PC4) | (0 << PC5);
289 | _delay_ms(130);
290 | PORTC = (0 << PC4) | (0 << PC5);
291 | _delay_ms(50);
292 | PORTC = (1 << PC4) | (0 << PC5);
293 | _delay_ms(30);
294 | PORTC = (0 << PC4) | (0 << PC5);
295 | _delay_ms(50);
296 | PORTC = (1 << PC4) | (0 << PC5);
297 | _delay_ms(30);
298 | PORTC = (0 << PC4) | (0 << PC5);
299 | _delay_ms(50); //340ms
300 |
301 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
302 | //Schaltkanal
303 | schaltkanal();
304 |
305 | //Rechts
306 | PORTC = (0 << PC4) | (1 << PC5);
307 | _delay_ms(135);
308 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
309 | PORTC = (0 << PC4) | (0 << PC5);
310 | _delay_ms(50);
311 | PORTC = (0 << PC4) | (1 << PC5);
312 | _delay_ms(30);
313 | PORTC = (0 << PC4) | (0 << PC5);
314 | _delay_ms(50);
315 | PORTC = (0 << PC4) | (1 << PC5);
316 | _delay_ms(30);
317 | PORTC = (0 << PC4) | (0 << PC5);
318 | _delay_ms(160); //455ms
319 |
320 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
321 | //Schaltkanal
322 | schaltkanal();
323 |
324 | //Links
325 | PORTC = (1 << PC4) | (0 << PC5);
326 | _delay_ms(130);
327 | PORTC = (0 << PC4) | (0 << PC5);
328 | _delay_ms(25);
329 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
330 | _delay_ms(25);
331 | PORTC = (1 << PC4) | (0 << PC5);
332 | _delay_ms(30);
333 | PORTC = (0 << PC4) | (0 << PC5);
334 | _delay_ms(50);
335 | PORTC = (1 << PC4) | (0 << PC5);
336 | _delay_ms(30);
337 | PORTC = (0 << PC4) | (0 << PC5);
338 | _delay_ms(20); //310ms
339 |
340 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
341 | //Schaltkanal
342 | schaltkanal();
343 |
344 | //Rechts
345 | PORTC = (0 << PC4) | (1 << PC5);
346 | _delay_ms(130);
347 | PORTC = (0 << PC4) | (0 << PC5);
348 | _delay_ms(50);
349 | PORTC = (0 << PC4) | (1 << PC5);
350 | _delay_ms(30);
351 | PORTC = (0 << PC4) | (0 << PC5);
352 | _delay_ms(50);
353 | PORTC = (0 << PC4) | (1 << PC5);
354 | _delay_ms(30);
355 | PORTC = (0 << PC4) | (0 << PC5);
356 | _delay_ms(30);
357 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
358 | _delay_ms(100); //420ms
359 |
360 |
361 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
362 | //Schaltkanal
363 | schaltkanal();
364 |
365 | //-------------------------------------------------
366 |
367 | PORTC = (1 << PC4) | (0 << PC5);
368 | _delay_ms(130);
369 | PORTC = (0 << PC4) | (0 << PC5);
370 | _delay_ms(50);
371 | PORTC = (1 << PC4) | (0 << PC5);
372 | _delay_ms(30);
373 | PORTC = (0 << PC4) | (0 << PC5);
374 | _delay_ms(50);
375 | PORTC = (1 << PC4) | (1 << PC5);
376 | _delay_ms(30);
377 | PORTC = (0 << PC4) | (0 << PC5);
378 | _delay_ms(50); //290ms
379 |
380 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
381 | //Schaltkanal
382 | schaltkanal();
383 |
384 | PORTC = (0 << PC4) | (1 << PC5);
385 | _delay_ms(35);
386 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
387 | _delay_ms(95);
388 | PORTC = (0 << PC4) | (0 << PC5);
389 | _delay_ms(50);
390 | PORTC = (0 << PC4) | (1 << PC5);
391 | _delay_ms(30);
392 | PORTC = (0 << PC4) | (0 << PC5);
393 | _delay_ms(50);
394 | PORTC = (0 << PC4) | (1 << PC5);
395 | _delay_ms(30);
396 | PORTC = (1 << PC4) | (0 << PC5);
397 | _delay_ms(50);
398 | PORTC = (1 << PC4) | (1 << PC5);
399 | _delay_ms(30);
400 | PORTC = (0 << PC4) | (0 << PC5);
401 | _delay_ms(50);
402 | PORTC = (0 << PC4) | (0 << PC5);
403 | _delay_ms(30); //450ms
404 |
405 |
406 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
407 | //Schaltkanal
408 | schaltkanal();
409 |
410 | //-------------------------------------------------
411 |
412 | PORTC = (1 << PC4) | (0 << PC5);
413 | _delay_ms(60);
414 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
415 | _delay_ms(70);
416 | PORTC = (0 << PC4) | (0 << PC5);
417 | _delay_ms(50);
418 | PORTC = (1 << PC4) | (0 << PC5);
419 | _delay_ms(30);
420 | PORTC = (0 << PC4) | (0 << PC5);
421 | _delay_ms(50);
422 | PORTC = (1 << PC4) | (0 << PC5);
423 | _delay_ms(30);
424 | PORTC = (0 << PC4) | (0 << PC5);
425 | _delay_ms(50); //340ms
426 |
427 | if(on_oben1==0 || on_unten1==0) goto start;//Abbruch
428 | //Schaltkanal
429 | schaltkanal();
430 |
431 | PORTC = (0 << PC4) | (1 << PC5);
432 | _delay_ms(130);
433 | PORTC = (0 << PC4) | (0 << PC5);
434 | _delay_ms(50);
435 | PORTC = (0 << PC4) | (1 << PC5);
436 | _delay_ms(15);
437 | if (blinker_an == 0){ PORTD = (0 << PD7); blinker_an = 1; } else { PORTD = (1 << PD7); blinker_an = 0;}//Blinker
438 | _delay_ms(15);
439 | PORTC = (0 << PC4) | (0 << PC5);
440 | _delay_ms(50);
441 | PORTC = (0 << PC4) | (1 << PC5);
442 | _delay_ms(30);
443 | PORTC = (0 << PC4) | (0 << PC5);
444 | _delay_ms(50);
445 | PORTC = (0 << PC4) | (1 << PC5);
446 | _delay_ms(30);
447 | PORTC = (0 << PC4) | (0 << PC5);
448 | _delay_ms(50);
449 | PORTC = (0 << PC4) | (1 << PC5);
450 | _delay_ms(30);
451 | PORTC = (0 << PC4) | (0 << PC5);
452 | _delay_ms(50);
453 | PORTC = (1 << PC4) | (1 << PC5);
454 | _delay_ms(20);
455 | PORTC = (0 << PC4) | (0 << PC5);
456 | _delay_ms(150); //520ms
457 |
458 | }
459 |
460 |
461 |
462 |
463 | }
464 |
465 | return 0;
466 |
467 | }
468 |
469 |
470 |
471 |
472 | //---------------------------------------------------------------------------------------------------
473 |
474 | ISR(INT1_vect) //Interruptvektor INT1
475 | {
476 |
477 |
478 | //SCHALTEN: HEBEL NACH UNTEN
479 |
480 |
481 | //Muss Hebel in Mitte? reset=0 NEIN ; reset=1 JA
482 | if(reset_unten1==0) //Nein muss er nicht
483 | {
484 | _delay_us(1200);
485 | if( !(PIND & (1 << PD3)) ) //Ist Hebel unten?
486 | {
487 | if(on_unten1==0) on_unten1=1; else on_unten1=0; //Ja ist er: Schalten
488 | reset_unten1 = 1; //Hebel muss in Mitte!
489 |
490 | }
491 | }
492 |
493 | else //Ja muss er
494 | {
495 | _delay_us(1400);
496 | if(PIND & (1 << PD3)) //Ist Hebel in Mitte?
497 | {
498 | reset_unten1 = 0; //Ja ist er!
499 | }
500 | }
501 |
502 |
503 |
504 |
505 | //SCHALTEN: HEBEL NACH OBEN
506 |
507 |
508 | //Muss Hebel in Mitte? reset=0 NEIN ; reset=1 JA
509 | if(reset_oben1==0) //Nein muss er nicht
510 | {
511 | _delay_us(600);
512 | if(PIND & (1 << PD3)) //Ist Hebel oben?
513 | {
514 | if(on_oben1==0) on_oben1=1; else on_oben1=0; //Ja ist er: Schalten
515 | reset_oben1 = 1; //Hebel muss in Mitte!
516 |
517 | }
518 | }
519 |
520 | else //Ja muss er
521 | {
522 | _delay_us(400);
523 | if( !(PIND & (1 << PD3)) ) //Ist Hebel in Mitte?
524 | {
525 | reset_oben1 = 0; //Ja ist er!
526 | }
527 | }
528 |
529 | _delay_us(1000);
530 |
531 |
532 | }
533 |
534 |
535 |
536 | //---------------------------------------------------------------------------------------------------
537 |
538 | ISR(INT0_vect) //Interruptvektor INT0
539 | {
540 |
541 |
542 | //SCHALTEN: HEBEL NACH UNTEN
543 |
544 |
545 | //Muss Hebel in Mitte? reset=0 NEIN ; reset=1 JA
546 | if(reset_unten1==0) //Nein muss er nicht
547 | {
548 | _delay_us(1200);
549 | if( !(PIND & (1 << PD3)) ) //Ist Hebel unten?
550 | {
551 | if(on_unten1==0) on_unten1=1; else on_unten1=0; //Ja ist er: Schalten
552 | reset_unten1 = 1; //Hebel muss in Mitte!
553 |
554 | }
555 | }
556 |
557 | else //Ja muss er
558 | {
559 | _delay_us(1400);
560 | if(PIND & (1 << PD3)) //Ist Hebel in Mitte?
561 | {
562 | reset_unten1 = 0; //Ja ist er!
563 | }
564 | }
565 |
566 |
567 |
568 |
569 | //SCHALTEN: HEBEL NACH OBEN
570 |
571 |
572 | //Muss Hebel in Mitte? reset=0 NEIN ; reset=1 JA
573 | if(reset_oben1==0) //Nein muss er nicht
574 | {
575 | _delay_us(600);
576 | if(PIND & (1 << PD3)) //Ist Hebel oben?
577 | {
578 | if(on_oben1==0) on_oben1=1; else on_oben1=0; //Ja ist er: Schalten
579 | reset_oben1 = 1; //Hebel muss in Mitte!
580 |
581 | }
582 | }
583 |
584 | else //Ja muss er
585 | {
586 | _delay_us(400);
587 | if( !(PIND & (1 << PD3)) ) //Ist Hebel in Mitte?
588 | {
589 | reset_oben1 = 0; //Ja ist er!
590 | }
591 | }
592 |
593 | _delay_us(1000);
594 |
595 |
596 | }
