Hallo, Ich suche einen erfahrener FPGA Entwickler. Die Aufgabe ist: ---------------------------------------------------------- We want to protect our IP cores, targeting Xilinx FPGAs, by using a 1-Wire EEPROM with SHA engine. It is explained in Xilinx application note xapp780 how it can be made. The vhdl source codes as well as picoblaze processor source codes for the xapp780 can also be downloaded from the Xilinx website. The problem is that the xapp780 is for DS2432 EEPROM from Maxim IC. However, I want to use DS28E01-100 EEPROM instead. I compiled the sources but the design is not working with DS28E01-100 EEPROMs. Some more points: 1 - You have to change the xapp780 sources so that it it works with DS28E01-100 EEPROM. 2 - We need 2 designs as it is in xapp780, loader and tester. Loader programs the EEPROM with our security key. Tester checks if the SHA keys are matching. 3 - Target FPGA is XC3S200AN. So you must have a Spartan 3A or 3AN evaluation kit. 4 - We use the big SFN package with 2 pins. Therefore it is very easy to connect the evaluation kit with the EEPROM through 2 cables. We will also provide some EEPROMs for testing. 5 - You will deliver me the complete source codes 6 - You can download only a restricted version of DS28E01-100 from Maxim website. You must sign an NDA to get the complete datasheet.
Gesperrt durch Moderator
Ersin Oezalp schrieb: > Ich suche einen erfahrener FPGA Entwickler. Die Aufgabe ist: Kostenlos oder Bezahlt? > 5 - You will deliver me the complete source codes Sicher doch, geht aber nur... > 6 - You can download only a restricted version of DS28E01-100 from Maxim > website. You must sign an NDA to get the complete datasheet. ...wenn der ENDKUNDE (also Du?) das NDA auch zeichnet, sowie ALLE PERSONEN und FIRMEN die den Sourcecode bekommen sollen! Ich setze den genannten DS28E01-100 in mehreren Applicationen ein und habe das NDA gezeichnet. Mit zwei meiner Kunden hatte ich dabei ein Problem weil Maxim sie nach einer Überpüfungnicht akzeptiert hat... Anm.: Ich bin keine FPGA Programmiererin. Grüße Michelle
@ Ersin Oezalp Solche Angebote sind an den Forum-Betreiber zu richten. Dann kann das hier formgerecht im Stellenteil (Ausbildung & Beruf) veröffentlicht werden. So geht das nicht und verstößt leider gegen die Forenregeln.
