1 | library ieee;
2 |
3 | use ieee.std_logic_1164.all;
4 | use ieee.std_logic_unsigned.all;
5 | use ieee.std_logic_arith.all;
6 |
7 | use work.zlm2k4_pkg.all;
8 |
9 | entity xj2bin32 is
10 | generic(
11 | delay: time:= 1.0 ns); -- Generic delay
12 | port (
13 | HCLK : in std_logic; -- High Clock, 240 MHz
14 | RESET : in std_logic; -- System Reset, high active, asynchron
15 | --
16 | Z : in slv32; -- Measurement interface
17 | -- MASK : in slv6; -- Mask
18 | --
19 | X : out slv32);
20 | end xj2bin32;
21 |
22 |
23 | architecture rtl of xj2bin32 is
24 | --
25 | -- component declaration
26 | --
27 | component udc26
28 | port (
29 | Q: OUT std_logic_VECTOR(25 downto 0);
30 | CLK: IN std_logic;
31 | UP: IN std_logic;
32 | CE: IN std_logic;
33 | ACLR: IN std_logic);
34 | end component;
35 |
36 | --
37 | -- Signal declaration
38 | --
39 | signal Z_Q : std_logic_vector(Z'range);
40 | signal Z_QQ : std_logic_vector(Z'range);
41 | signal Z_QQQ : std_logic_vector(Z'range);
42 | signal Q : slv26; -- Output 26-bit-up/down counter
43 | signal O : slv32; -- Counter + decoder
44 | signal XLOW : slv6; -- Decoder output
45 | signal XZOUT: slv32;
46 |
47 | signal CE : std_logic; -- Count Enable
48 | signal UP : std_logic; -- 1:UP, 0:DOWN
49 |
50 | signal C1 : slv3;
51 | signal C2 : slv3;
52 |
53 | begin
54 |
55 |
56 | PSYNCZ:process(RESET,HCLK)
57 | begin
58 | if RESET = '1' then
59 | Z_Q <= (Z'range => '0') after delay;
60 | Z_QQ <= (Z'range => '0') after delay;
61 | Z_QQQ <= (Z'range => '0') after delay;
62 | elsif rising_edge(HCLK) then
63 | Z_Q <= Z after delay;
64 | Z_QQ <= Z_Q after delay;
65 | Z_QQQ <= Z_QQ after delay;
66 | end if;
67 | end process PSYNCZ;
68 |
69 |
70 | C1 <= Z_Q(0) & Z_QQ(0) & Z_Q(16) after delay;
71 | C2 <= Z_Q(16) & Z_QQ(16) & Z_Q(0) after delay;
72 |
73 | P100:process(RESET,HCLK)
74 | begin
75 | if RESET = '1' then
76 | CE <= '0' after delay;
77 | UP <= '0' after delay;
78 | elsif rising_edge(HCLK) then
79 | if C1 = "100" then
80 | UP <= '1' after delay;
81 | CE <= '1' after delay;
82 | elsif C2 = "101" then
83 | UP <= '1' after delay;
84 | CE <= '0' after delay;
85 | elsif C1 = "011" then
86 | UP <= '1' after delay;
87 | CE <= '0' after delay;
88 | elsif C2 = "010" then
89 | UP <= '1' after delay;
90 | CE <= '0' after delay;
91 | elsif C1 = "010" then
92 | UP <= '0' after delay;
93 | CE <= '1' after delay;
94 | elsif C2 = "100" then
95 | UP <= '0' after delay;
96 | CE <= '0' after delay;
97 | elsif C1 = "101" then
98 | UP <= '0' after delay;
99 | CE <= '0' after delay;
100 | elsif C2 = "011" then
101 | UP <= '0' after delay;
102 | CE <= '0' after delay;
103 | else
104 | CE <= '0' after delay;
105 | end if;
106 | end if;
107 | end process P100;
108 |
109 | --
110 | -- 26 up/down counter
111 | --
112 | U1: udc26
113 | port map (
114 | Q => Q,
115 | CLK => HCLK,
116 | UP => UP,
117 | CE => CE,
118 | ACLR => RESET);
119 |
120 | XLOW <= convert4(Z_QQQ);
121 | -- XZOUT(0) <= Z_QQQ(0);
122 | -- XZOUT(1) <= Z_QQQ(1);
123 | -- XZOUT(2) <= Z_QQQ(2);
124 | -- XZOUT(3) <= Z_QQQ(3);
125 | -- XZOUT(4) <= Z_QQQ(4);
126 | -- XZOUT(5) <= Z_QQQ(5);
127 | -- XZOUT(6) <= Z_QQQ(6);
128 | -- XZOUT(7) <= Z_QQQ(7);
129 | -- XZOUT(8) <= Z_QQQ(8);
130 | -- XZOUT(9) <= Z_QQQ(9);
131 | -- XZOUT(10) <= Z_QQQ(10);
132 | -- XZOUT(11) <= Z_QQQ(11);
133 | -- XZOUT(12) <= Z_QQQ(12);
134 | -- XZOUT(13) <= Z_QQQ(13);
135 | -- XZOUT(14) <= Z_QQQ(14);
136 | -- XZOUT(15) <= Z_QQQ(15);
137 | -- XZOUT(16) <= Z_QQQ(16);
138 | -- XZOUT(17) <= Z_QQQ(17);
139 | -- XZOUT(18) <= Z_QQQ(18);
140 | -- XZOUT(19) <= Z_QQQ(19);
141 | -- XZOUT(20) <= Z_QQQ(20);
142 | -- XZOUT(21) <= Z_QQQ(21);
143 | -- XZOUT(22) <= Z_QQQ(22);
144 | -- XZOUT(23) <= Z_QQQ(23);
145 | -- XZOUT(24) <= Z_QQQ(24);
146 | -- XZOUT(25) <= Z_QQQ(25);
147 | -- XZOUT(26) <= Z_QQQ(26);
148 | -- XZOUT(27) <= Z_QQQ(27);
149 | -- XZOUT(28) <= Z_QQQ(28);
150 | -- XZOUT(29) <= Z_QQQ(29);
151 | -- XZOUT(30) <= Z_QQQ(30);
152 | -- XZOUT(31) <= Z_QQQ(31);
153 |
154 | -- XZOUT <= bitclear(Z_QQQ);
155 | -- XLOW(0) := '0';
156 | -- XLOW(1) := '0';
157 | -- XLOW(2) := '0';
158 | -- XLOW(3) := '0';
159 | -- XLOW(4) := '0';
160 | -- XLOW(5) := '0';
161 |
162 |
163 |
164 | POUT:process(RESET,HCLK)
165 | variable O : slv32; -- Counter + decoder
166 | variable T : slv6;
167 | begin
168 | if RESET = '1' then
169 | X <= (X'range => '0') after delay;
170 | elsif rising_edge(HCLK) then
171 | -- O := Q & XLOW;
172 | -- T := MASK and O(5 downto 0);
173 | -- X <= O(31 downto 6) & T after delay;
174 | -- X <= Q & XLOW after delay;
175 | -- X <= XZOUT after delay;
176 |
177 | X <= Q & XLOW after delay;
178 |
179 |
180 |
181 | end if;
182 | end process POUT;
183 |
184 |
185 | end rtl;
