1 | //! -----------------------------------------------------------------------------------------------
2 | //!
3 | //! © Copyright 2011 by
4 | //!
5 | //! Carsten Wille
6 | //! Karlstraße 68
7 | //! D-38106 Braunschweig
8 | //!
9 | //! All rights reserved.
10 | //!
11 | //! Redistribution and use in source and binary forms, with or without modification, are permitted
12 | //! provided that the following conditions are met:
13 | //!
14 | //! * Redistributions of source code must retain the above copyright notice, this list of
15 | //! conditions and the following disclaimer.
16 | //! * Redistributions in binary form must reproduce the above copyright notice, this list of
17 | //! conditions and the following disclaimer in the documentation and/or other materials provided
18 | //! with the distribution.
19 | //! * Neither the name of Carsten Wille nor the names of its contributors may be used to
20 | //! endorse or promote products derived from this software without specific prior written
21 | //! permission.
22 | //!
23 | //! THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR
24 | //! IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
25 | //! AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
26 | //! CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 | //! CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
28 | //! SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29 | //! THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
30 | //! OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 | //! POSSIBILITY OF SUCH DAMAGE.
32 | //!
33 | //! -----------------------------------------------------------------------------------------------
34 |
35 | // Make the necessary adjustments at this point to match with the desired target MCU and clocking.
36 | #define F_CPU 32000000UL // Run with 32MHz after PLL
37 | #define USARTxx USARTC1 // Choose USART C1 as communications port
38 | #define USARTport PORTC // Matching port for the chosen USART
39 | #define USARTtxd PIN7_bm // Bit mask of the TxD pin
40 |
41 | #include <avr/eeprom.h>
42 | #include <avr/interrupt.h>
43 | #include <avr/io.h>
44 | #include <avr/pgmspace.h>
45 | #include <stdbool.h>
46 |
47 | #include "types.h"
48 |
49 |
50 | //! \brief Fuses for the .elf-file
51 | //!
52 | //! The following code lines define the fuses for the .elf-file. There is no more need to set them
53 | //! manually during the programming process.
54 | //! Fuses of the naked device: 0xFF, 0x00, 0xFF, 0xFE, 0xFF
55 |
56 | FUSES =
57 | {
58 | 0xFF, // JTAG User ID
59 | 0x0A, // WDPER set to 8s, no window
60 | 0xBE, // BOOTRST = BOOTLDR, BODPD = BOD enabled continuously during power down
61 | 0xFF, // Reserved byte with no function here.
62 | 0xFD, // ext. Reset enabled, no startup delay, WDT locked and enabled, JTAG I/F disabled
63 | 0xE3 // BODACT = BOD enabled continuously, EESAVE on, BODLEVEL = 2.6V
64 | };
65 |
66 |
67 | #if F_CPU != 32000000UL
68 | #error "ERROR: F_CPU must be 32MHz or baud rate generation won't work as designed!"
69 | #endif
70 |
71 | #ifndef USARTxx
72 | #error "ERROR: USARTxx must be defined with the correct port!"
73 | #endif
74 |
75 |
76 | //! \brief CCP write helper function written in assembly.
77 | //!
78 | //! This function is written in assembly because of the time critical operation of writing to
79 | //! the registers. (From clksys_driver.c of the Atmel application note AVR1003)
80 | //!
81 | //! \param address A pointer to the address to write to.
82 | //! \param value The value to put in to the register.
83 |
84 | void CCPWrite (tVUINT8* address, tUINT8 value)
85 | {
86 | tVUINT8* tmpAddr = address;
87 |
88 | #ifdef RAMPZ
89 | RAMPZ = 0;
90 | #endif
91 | asm volatile
92 | (
93 | "movw r30, %0" "\n\t"
94 | "ldi r16, %2" "\n\t"
95 | "out %3, r16" "\n\t"
96 | "st Z, %1" "\n\t"
97 | :
98 | : "r" (tmpAddr), "r" (value), "M" (CCP_IOREG_gc), "i" (&CCP)
99 | : "r16", "r30", "r31"
100 | );
101 | }
102 |
103 |
104 | //! \brief Check for an available character.
105 | //!
106 | //! Check for an available character in the receive buffer.
107 | //!
108 | //! \return True, if the flag is set.
109 |
110 | bool CharAvailable ()
111 | {
112 | return ((USARTxx.STATUS & USART_RXCIF_bm) != 0x00);
113 | }
114 |
115 |
116 | //! \brief getchar () replacement
117 | //!
118 | //! Simple, blocking getchar () replacement routine.
119 | //!
120 | //! \return Character, read from the serial interface of USART C1
121 |
122 | char GetChar ()
123 | {
124 | // Wait until something is ready to be read from the receive buffer.
125 | while ((USARTxx.STATUS & USART_RXCIF_bm) == 0x00)
126 | {
127 | // Reset watchdog timer while waiting for the next character.
128 | asm ("wdr");
129 | }
130 | return USARTxx.DATA;
131 | }
132 |
133 |
134 | //! \brief putchar () replacement
135 | //!
136 | //! Simple, blocking putchar () replacement.
137 | //!
138 | //! \param ch Character to be sent.
139 |
140 | void PutChar (char ch)
141 | {
142 | // Wait until the transmit buffer is free to accept the next character
143 | while ((USARTxx.STATUS & USART_DREIF_bm) == 0x00)
144 | {
145 | // Reset watchdog timer while waiting for the buffer to be free again.
146 | asm ("wdr");
147 | }
148 | USARTxx.DATA = ch;
149 |
150 | // Expand a <cr> to a <cr><lf> sequence.
151 | if (ch == '\r')
152 | PutChar ('\n');
153 | }
154 |
155 |
156 | //! \brief Main loop
157 |
158 | int main ()
159 | {
160 | // Turn off any interrupts, just in case.
161 | cli ();
162 |
163 | // ----------------------------------------------------------------------------------------------
164 |
165 | // Configure the oscillator from internal 2MHz clock to external 8MHz crystal and internal
166 | // PLL quadruplication.
167 |
168 | // Switch to external crystal (8 MHz) and wait for it to become stable.
169 | OSC.XOSCCTRL = OSC_FRQRANGE_2TO9_gc | OSC_XOSCSEL_XTAL_16KCLK_gc;
170 |
171 | OSC.CTRL = OSC_XOSCEN_bm | OSC_RC2MEN_bm;
172 | while ((OSC.STATUS & OSC_XOSCRDY_bm) != OSC_XOSCRDY_bm);
173 |
174 | // Set all the prescalers after the PLL to 1
175 | CCPWrite (&CLK.PSCTRL, CLK_PSADIV_1_gc | CLK_PSBCDIV_1_1_gc);
176 |
177 | // Activate the PLL with a multiplier of four to generate 32 MHz out of 8 MHz.
178 | OSC.PLLCTRL = 4 << OSC_PLLFAC_gp | OSC_PLLSRC_XOSC_gc;
179 |
180 | OSC.CTRL = OSC_XOSCEN_bm | OSC_RC2MEN_bm | OSC_PLLEN_bm;
181 | while ((OSC.STATUS & OSC_PLLRDY_bm) != OSC_PLLRDY_bm);
182 |
183 | // Switch from internal 2 MHz to 32 MHz PLL output.
184 | CCPWrite (&CLK.CTRL, CLK_SCLKSEL_PLL_gc);
185 |
186 | // ----------------------------------------------------------------------------------------------
187 |
188 | // Configure the USART C1 to 57600 baud 8N1, no handshake. Only polling will we used to
189 | // avoid any interrupts in the boot loader firmware.
190 |
191 | // Values calculated from baud rate and CPU Clock:
192 | // BSEL 1.079 (Select a BSEL Value from 0 to 4095)
193 | // BSCALE -5 (Select a BSCALE Value from -7 to 7)
194 | // CLK2X 0 (Select 2x speed mode)
195 | // Error% 0,01% (Error from selected baud rate)
196 | //
197 | // Values calculated from BSEL, BSCALE and CLK2X:
198 | // Baud rate 57.606 bits per second
199 | // Error% 0,01% error from selected baud rate
200 |
201 | #define BSEL 1079
202 | #define BSCALE 11 // -5 in 4-bit two's complement writing
203 |
204 | // Enable output functionality for the TXD pin.
205 | USARTport.DIRSET = USARTtxd;
206 |
207 | // Set baud rate generation to 57600 baud.
208 | USARTxx.BAUDCTRLA = (tUINT8) BSEL;
209 | USARTxx.BAUDCTRLB = (BSCALE << USART_BSCALE0_bp) | (BSEL >> 8);
210 | // Set USART to asynchronous mode and format to 8N1.
211 | USARTxx.CTRLC = USART_CHSIZE_8BIT_gc | USART_PMODE_DISABLED_gc | USART_CMODE_ASYNCHRONOUS_gc;
212 | // Enable Rx and Tx, no clock doubling, no multiprocessor communication at all.
213 | USARTxx.CTRLB = USART_RXEN_bm | USART_TXEN_bm;
214 | // Disable all interrupts.
215 | USARTxx.CTRLA = 0;
216 |
217 | #undef BSEL
218 | #undef BSCALE
219 |
220 | // ----------------------------------------------------------------------------------------------
221 |
222 | PutChar ('H');
223 | PutChar ('e');
224 | PutChar ('l');
225 | PutChar ('l');
226 | PutChar ('o');
227 | PutChar ('!');
228 | PutChar ('\r');
229 |
230 | while (1)
231 | {
232 | PutChar (GetChar ());
233 | }
234 | }
