1  | #include <avr/io.h>
2  | #include <avr/interrupt.h>
3  |
4  | // ----- Pin maps (see scematics) -----
5  | #define SATELIT_CLK        PA1
6  |
7  | // ----- Makros -----
8  | #define FASTER_CLK_ON      PORTA |=  (1<<SATELIT_CLK)      // high
9  | #define FASTER_CLK_OFF      PORTA &= ~(1<<SATELIT_CLK)      // low
10  |
11  | // ----- Timer -----
12  | // number of clockcycles of equal length *2 you want to insert between to clock cycles on ICP1 input capture pin
13  | #define CLK_multiplier_times_2  8
14  |
15  | void Toggle_Clock(void)
16  | {
17  |   // static variables for faster access compared to global
18  |   static unsigned int full_interval_length = 0;
19  |   static char Pin_level_state = 0;
20  |   static char Clock_state = 0;
21  |   static unsigned int timing_vector[CLK_multiplier_times_2];
22  |
23  |   // Toggle faster clock
24  |   if (Pin_level_state){
25  |     FASTER_CLK_OFF;
26  |     Pin_level_state = 0;
27  |   }
28  |   else{
29  |     FASTER_CLK_ON;
30  |     Pin_level_state = 1;
31  |   }
32  |
33  |   if (Clock_state == 0){
34  |     // new cycles starts
35  |     // prepare timing vector
36  |     // read measured interval length between two slower clock pulses
37  |     full_interval_length = ICR1;
38  |
39  |     char rest = full_interval_length % 8;// rest of division by 8
40  |
41  |     timing_vector[0] = (1*full_interval_length)/CLK_multiplier_times_2;
42  |     timing_vector[1] = (2*full_interval_length)/CLK_multiplier_times_2;
43  |     timing_vector[2] = (3*full_interval_length)/CLK_multiplier_times_2;
44  |     timing_vector[3] = (4*full_interval_length)/CLK_multiplier_times_2;
45  |     timing_vector[4] = (5*full_interval_length)/CLK_multiplier_times_2;
46  |     timing_vector[5] = (6*full_interval_length)/CLK_multiplier_times_2;
47  |     timing_vector[6] = (7*full_interval_length)/CLK_multiplier_times_2;
48  |     timing_vector[7] = 0xFFFE;// Dummy, timer should never reach this value. external slower clock ISR should appear before this happens.
49  |
50  |     // divide rest of division "equaly" over the timers
51  |     if (rest == 1){
52  |       timing_vector[3]++;
53  |     }
54  |     else if (rest == 2){
55  |       timing_vector[2]++;
56  |       timing_vector[4]++;
57  |     }
58  |     else if (rest == 3){
59  |       timing_vector[1]++;
60  |       timing_vector[3]++;
61  |       timing_vector[5]++;
62  |     }
63  |     else if (rest == 4){
64  |       timing_vector[0]++;
65  |       timing_vector[2]++;
66  |       timing_vector[4]++;
67  |       timing_vector[6]++;
68  |     }
69  |     else if (rest == 5){
70  |       timing_vector[0]++;
71  |       timing_vector[1]++;
72  |       timing_vector[3]++;
73  |       timing_vector[5]++;
74  |       timing_vector[6]++;
75  |     }
76  |     else if (rest == 6){
77  |       timing_vector[0]++;
78  |       timing_vector[1]++;
79  |       timing_vector[2]++;
80  |       timing_vector[4]++;
81  |       timing_vector[5]++;
82  |       timing_vector[6]++;
83  |     }
84  |     else if (rest == 7){
85  |       timing_vector[0]++;
86  |       timing_vector[1]++;
87  |       timing_vector[2]++;
88  |       timing_vector[3]++;
89  |       timing_vector[4]++;
90  |       timing_vector[5]++;
91  |       timing_vector[6]++;
92  |     }
93  |   }
94  |
95  |   OCR1A  = timing_vector[Clock_state];// set time for next satellite clk event
96  |
97  |   Clock_state++;      // increment faster clk cycle counter
98  |   if (Clock_state == 8){
99  |     Clock_state = 0;  // reset cycle
100  |   }
101  |
102  |   // it is necessary to reach end of this before "timing_vector[Clock_state]" MCU cycles
103  | }
104  |
105  | ISR(TIMER1_CAPT_vect)
106  | {
107  |   // ICR1 is set to TCNT1 by hardware.
108  |   TCNT1 = 0;    // reset current value of timer 1.
109  |   Toggle_Clock();  // Toggle faster clock
110  | }
111  |
112  | ISR(TIMER1_COMPA_vect)
113  | {
114  |
115  |   OCR1A = 0xFFFE;// Dummy 16-bit access that "should" take as long as TCNT1 = 0;.Timer should never reach this value.
116  |   Toggle_Clock();  // Toggle faster clock
117  | }
118  |
119  | int main(void)
120  | {
121  |   // ----- Hardware -----
122  |   // GPIOs
123  |     FASTER_CLK_OFF;
124  |     DDRA   |=  (1 << SATELIT_CLK);
125  |
126  |   // ----- Timer 1 -----
127  |   TCCR1B |= (1<<ICES1);        // Trigger positive edge
128  |
129  |   //CS12 CS11 CS10 Description
130  |   //0 0 0 No clock source (Timer/Counter stopped).
131  |   //0 0 1 clkI/O/1    (No prescaling)
132  |   //0 1 0 clkI/O/8    (From prescaler)
133  |   //0 1 1 clkI/O/64    (From prescaler)
134  |   //1 0 0 clkI/O/256    (From prescaler)
135  |   //1 0 1 clkI/O/1024    (From prescaler)
136  |   //1 1 0 External clock source on T1 pin. Clock on falling edge.
137  |   //1 1 1 External clock source on T1 pin. Clock on rising edge.
138  |
139  |   // prescaler = 1
140  |   //TCCR1B |=  (1<<CS12);
141  |   TCCR1B &= ~(1 <<CS12);
142  |   //TCCR1B |=  (1<<CS11);
143  |   TCCR1B &= ~(1 <<CS11);
144  |   TCCR1B |=  (1<<CS10);
145  |   //TCCR1B &= ~(1 <<CS10);
146  |
147  |   OCR1A  = 0xFFFE;    // Dummy, should never be reached - if slower clock is present
148  |
149  |   // integrate overflow ISR depending on what you wnat to do when no slow clock is present
150  |   //TIMSK   &= ~(1 <<TOIE1);  // overflow ISR
151  |   TIMSK |=  (1 <<ICIE1 );  // Input Capture Interrupt Enable
152  |   TIMSK |=  (1 <<OCIE1A);  // compare A match enable
153  | while(1){}
154  | }
