1 | #include "io430.h"
2 | #include "intrinsics.h"
3 |
4 | // target: MSP430G2553 (Launch Pad)
5 | //------------------------------------------------------------------------
6 |
7 | /* ------------------------------------------------------------------------------------------------
8 | * Types
9 | * ------------------------------------------------------------------------------------------------
10 | */
11 |
12 | typedef signed int int8;
13 | typedef unsigned int uint8;
14 |
15 | typedef signed short int16;
16 | typedef unsigned short uint16;
17 |
18 | typedef signed long int32;
19 | typedef unsigned long uint32;
20 |
21 | //----------------------------------------------------------------------------------------------
22 |
23 | #define PHASE_A (P1IN & BIT4) // P1.4 als Eingang Encoder
24 | #define PHASE_B (P1IN & BIT5) // P1.5 als Eingang Encoder
25 |
26 |
27 | volatile int8 enc_delta; // -128 ... 127
28 | static int8 last;
29 |
30 |
31 | void encode_init( void )
32 | {
33 | int8 new;
34 |
35 | new = 0;
36 | if( PHASE_A )
37 | new = 3;
38 | if( PHASE_B )
39 | new ^= 1; // convert gray to binary
40 | last = new; // power on state
41 | enc_delta = 0;
42 | }
43 |
44 |
45 | #pragma vector=TIMER0_A0_VECTOR // 1ms for manual movement
46 | __interrupt void Timer_A (void)
47 | {
48 | int8 new, diff;
49 |
50 | new = 0;
51 | if( PHASE_A )
52 | new = 3;
53 | if( PHASE_B )
54 | new ^= 1; // convert gray to binary
55 | diff = last - new; // difference last - new
56 | if( diff & 1 ){ // bit 0 = value (1)
57 | last = new; // store new as next last
58 | enc_delta += (diff & 2) - 1; // bit 1 = direction (+/-)
59 | }
60 | CCR0 += 2000; // Add Offset to CCR0
61 | }
62 |
63 |
64 | int8 encode_read1( void ) // read single step encoders
65 | {
66 | int8 val;
67 |
68 | __disable_interrupt();
69 | val = enc_delta;
70 | enc_delta = 0;
71 | __enable_interrupt();
72 | return val; // counts since last call
73 | }
74 |
75 |
76 | int main( void )
77 | {
78 | WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer to prevent time out reset
79 |
80 | BCSCTL1 = CALBC1_1MHZ; // 1 MHz clock
81 | DCOCTL = CALDCO_1MHZ;
82 |
83 | CCTL0 = CCIE; // CCR0 interrupt enabled
84 | CCR0 = 2000;
85 | TACTL = TASSEL_2 + MC_2; // SMCLK, contmode
86 |
87 | P1SEL = 0x00; // Port 1 als GPIO nutzen
88 | P1REN |= (BIT4 + BIT5); // P1.4 und P1.5 Resistor enabled
89 | P1OUT |= (BIT4 + BIT5); // P1.4 und P1.5 Pullup enabled
90 | P1DIR |= (BIT0 + BIT6); // P1.0 und P1.6 LEDs
91 |
92 |
93 | int32 val = 0;
94 |
95 | encode_init();
96 | __enable_interrupt();
97 |
98 | for(;;)
99 | {
100 | val += encode_read1();
101 |
102 | if(val > 0)
103 | P1OUT |= 0x01;
104 | else
105 | P1OUT &= ~ 0x01;
106 |
107 | if(val < 0)
108 | P1OUT |= 0x40;
109 | else
110 | P1OUT &= ~ 0x40;
111 | }
112 | }
