Guten Tag Weis jemand eine Formel, wo mit dem Autoreloadwert, Systemfrequenz, und dem Prescaler die PWM - Frequenz ausrechnen kann?? Danke und Gruss! M.B.
hmm.. etwas stimmt aber nicht!? OSC = 8000000 Hz Prescale = 3 ARR = 100 ergibt 26,66 kHz !?? TM1_OSC = (1/(Osc/Prsc))*ARR
M. B. schrieb: > hmm.. etwas stimmt aber nicht!? Was stimmt nicht? Je nach Timer Mode muß man gucken, von wo nach wo der Timer dabei zählt.
1 | /* Bit 0, CEN: Counter enable: 0 = Counter disabled / 1 = Counter enabled */
2 | /* Bit 1, UDIS: Update disable: The Update (UEV) event enabled */
3 | /* Bit 2, URS: Update request source: These events can be: Counter overflow/underflow, Setting the UG bit or Update generation through the slave mode controller */
4 | /* Bit 3, OPM: One pulse mode: Counter is not stopped at update event */
5 | /* Bit 4, DIR: Direction: - */
6 | /* Bits 6:5, CMS[1:0]: Center-aligned mode selection: Center-aligned mode 3. The counter counts up and down alternatively */
7 | /* Bit 7, ARPE: Auto-reload preload enable: TIMx_ARR register is not buffered */
8 | /* Bits 9:8, CKD[1:0]: Clock division: tDTS=tCK_INT */
9 | /* Bits 15:10, Reserved: always read as 0
10 | |
11 | |
12 | |
13 | /* -> CCMR1: COMPAREMODREG1 = 0x00000060; */
14 | /* */
15 | /* Bits 1:0, CC1S: Capture/Compare 1 selection: CC1 channel is configured as output */
16 | /* Bit 2, OC1FE: Output Compare 1 fast enable: CC1 behaves normally depending on counter and CCR1 values even when the trigger is ON. The minimum delay to activate CC1 output when an edge occurs on the trigger input is 5 clock cycles */
17 | /* Bit 3, OC1PE: Output Compare 1 preload enable:Preload register on TIMx_CCR1 disabled. TIMx_CCR1 can be written at anytime, the new value is taken in account immediately */
18 | /* Bits 6:4, OC1M: Output Compare 1 mode: PWM mode 1 - In upcounting, channel 1 is active as long as TIMx_CNT<TIMx_CCR1 else inactive. In downcounting, channel 1 is inactive (OC1REF=‘0’) as long as TIMx_CNT>TIMx_CCR1 else active (OC1REF=’1’) */
19 | /* Bit 7, OC1CE: Output Compare 1 clear enable: OC1Ref is not affected by the ETRF Input |
Mit dem KO messe ich 37kHz!
Prescaler 3 (DREI) ist ein ziemlich exotischer Wert. Welcher µC hat den?
Ich verwende den STM32F103VBT6 und habe einen L6235PD Motortreiber angeschlossen. Wenn ich den Wert im CCR1 ändere, ändert ja die Frequemz nicht. Also benötige ich diesen Wert nicht für die Berechnung? Danke und Gruss! M.B.
Ein Problem könnte sein, die hardware ist für den stm32f103vct6 ausgelegt und einen externen Clock von 25MHz angelegt. Der uP ist aber ein stm32f103vbt6 und auf den internen 8MHz Clock eingestellt, jetzt muss ich den Prototypen trotzdem in Betrieb nehmen! :-(
Hallo Drumstick! a) Stimmt die Taktfrequenz am Timer? Sind die Vorteileer AHB1/2 richtig eingestellt? b) Beachte: für einen Vorteiler von 3 muss (wenn ich das richtig im Kopf habe) der Wert "2" ins Register, als Vorteiler-1. Im übrigen ist dies auch beim eigentlichen Timerwert so! Grüße
... c) Und im Übrigen ist die Taktferquenz auch relativ einfach von intern auf Extern einzustellen. Grüße
So viel ich weiss, muss ich für einen Vorteiler von 3 (Drei) auch eine 3 schreiben. Bei den Timer 2, 3 und vier die ich nutze stimmt die Frequenz bzw. die Formel. Aber beim erzeugen des PWMs stimmt sie nicht. Ich weiss da wir einen falschen uP einsetzen (stm32f103vbt6 anstelle eines stm32f103vct6) machen wir uns selber Probleme. Aber der einzige Unterschied, der ich sehe liegt ja daran, dass die B Variante keinen DAC hat. Gruss Mario
2. Beispiel:
1 | #define CLOCKCONFIG 0x00000000 //001D8402 /**/ |
2 | #define CLOCKCONTROLL 0x01000081 //01000081 /**/ |
3 | #define CLOCKENABLES 0x00000A75
4 | |
5 | #define CONRTOLLREG1A 0x00000060 /**/ |
6 | #define CONTROLLREG1B 0x00000061 /**/ |
7 | #define CONTROLLREG2 0x00000000 /**/ |
8 | #define PRESCALE 5 /**/ |
9 | #define AUTORELOAD 67//258 /**/ |
10 | #define COMPAREMODREG1 0x00000060 /**/ |
11 | #define COMPAREMODREG2 0x00000000 /**/ |
12 | #define COMPAREENABLEREG 0x00000011 /**/ |
13 | #define SLAVEMODECONTROLLREG 0x00000000 /**/ |
14 | #define COMPAREREG1 0x00000020 /**/ |
15 | #define COMPAREREG2 0x00000000 /**/ |
16 | #define STATUSREG 0x00000000 /**/ |
17 | #define INTERRUPTENABLEREG 0x00000002 /**/ |
18 | #define EVENTGENERATREG 0x00000003 /**/ |
19 | #define BRAKDEATTIMEREG 0x0000CCFF
20 | |
21 | #define CONFIGREGLOWA 0x88888888 /**/ |
22 | #define CONFIGREGHIGHA 0x888888BB /**/ |
23 | |
24 | |
25 | |
26 | |
27 | void main(void) // |
28 | {
29 | |
30 | // Clocks
31 | RCC -> APB2ENR = CLOCKENABLES; // Enable GPIOA, GPIOC, GPIOD, GPIOE, ADC1, Alternate function and Timer 1 clock |
32 | RCC -> CFGR = CLOCKCONFIG; // Clockconfigurations |
33 | RCC -> CR = CLOCKCONTROLL; // 8MHz, PLL enable |
34 | |
35 | // while(RCC -> CR == (1<<1)) // waiting for Clock is stabile
36 | // { //
37 | // __nop(); //
38 | // } //
39 | |
40 | // GPIOs
41 | |
42 | GPIOA -> CRH = CONFIGREGHIGHA; // Ports configuriere as Input/Output |
43 | |
44 | // Timer
45 | // Timer1
46 | TIM1 -> CR1 = CONRTOLLREG1A; // Auto-Reload Register are puffered; Center Aligned Mode 3, up- and down. An Event is activate by under- and overflow ausgelöst. |
47 | TIM1 -> CR2 = CONTROLLREG2; // Reset Controllregister 2 |
48 | TIM1 -> PSC = PRESCALE; // Prescaler |
49 | TIM1 -> ARR = AUTORELOAD; // Auto-Reload Register |
50 | TIM1 -> CCMR1 = COMPAREMODREG1; // Compare Mode Register 1 Outputcompare Mode |
51 | TIM1 -> CCMR2 = COMPAREMODREG2; // Compare Mode Register 2 Output Compare 1 Mode; Output Compare 2 Mode |
52 | TIM1 -> CCER = COMPAREENABLEREG; // Compare Enable Register; Compare 1 Output Enable; Compare 2 Output Enable |
53 | TIM1 -> SMCR = SLAVEMODECONTROLLREG; // Slave Mode Controll Register |
54 | TIM1 -> CCR1 = COMPAREREG1; // Compare Register 1 |
55 | TIM1 -> CCR2 = COMPAREREG2; // Compare Register 2 |
56 | TIM1 -> SR = STATUSREG; // Status Register: Interrupt Flagbits |
57 | TIM1 -> DIER = INTERRUPTENABLEREG; // Interrupt Enable Register: Interrupt Compare 1 und Compare 2 enable |
58 | TIM1 -> EGR = EVENTGENERATREG; // Event Generator Register: Update generation; Compare 1 Generation / Compare 2 Generation |
59 | TIM1 -> BDTR = BRAKDEATTIMEREG; // Lock off, break inputs disable |
60 | TIM1 -> CR1 = CONTROLLREG1B; // Timer 1 starten |
Mit dem KO messe ich genau 10kHz Aber die Berrechnung ergibt 23,88kHz Hat sonst noch Jemand eine Idee?? Vielen Dank und Gruss! M.B.
