LED - Cube, if anweißung
OP #2421512
servus...
ich habe folgende frage. wie und wo kann ich in meinem code eine
if-anweißung zufügen.
sodass
if(PINC & (1<<PC0)){
// mache die und die led an
mein text:
#define F_CPU 8000000UL
//  Includes
#include <util/delay.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
//  Bitpopelei
#define  set_bit(var, bit)  ((var) |= (1 << (bit)))
#define  clear_bit(var, bit)  ((var) &= (unsigned)~(1 << (bit)))
//  Bool
#define FALSE  0
#define TRUE  1
//  Definitionen
#define PIXEL_TON  30
#define PIXEL_TOFF  10
//  Cube-Array
unsigned char cube[3][3][3];
unsigned char buffer[3][3][3];  //  Framebuffer
//  Prototypen
void init();
//  Programmzähler
unsigned int program_counter = 0;
//  Framezähler
volatile unsigned char frame_counter = 0, fps = 0;
//  Pixelmakros
#define PSET(x,y,z)    (0b01000000 | ((z * 3 + x) + y * 9))
#define PCLEAR(x,y,z)  (0b00000000 | ((z * 3 + x) + y * 9))
//  Instructions
#define CLEAR  0b10000000
#define SET    0b10010000
#define FPS    0b10110000
#define NEXT  0b11110000
//  Variablen
#define VAR_FPS  0
//  Für CLEAR und SET
#define CLEAR_ALL  0
#define SET_ALL    0
//  Für NEXT
#define JUMP_FORWARD  1
#define JUMP_BACKWARD  2
//  Programmcode
const prog_char program_1[] =              //Pset(x,y,z)
  FPS, 5,
  // PSET(0,0,0), PSET(1,0,0), PSET(0,1,0), PSET(1,1,0), PSET(0,2,0),
PSET(1,2,0), NEXT,
  // PCLEAR(0,0,0), PSET(2,0,0), PCLEAR(0,1,0), PSET(2,1,0),
PCLEAR(0,2,0), PSET(2,2,0), NEXT,
  PSET(0,0,0), NEXT, PSET(1,1,1), NEXT,
  // PSET(2,0,0), NEXT, PSET(8,0,0), NEXT, PSET(6,0,0), NEXT, CLEAR_ALL,
  //CLEAR_ALL, NEXT, PSET(1,1,1), NEXT,
const prog_char *program_pointer = program_1;
unsigned int program_length = sizeof(program_1);
//  Main
int main(void)
  //  Initialisierung
  init();
  //  Hauptschleife
  while (1)
    unsigned char instruction =
pgm_read_byte(&(program_pointer[program_counter]));
    if ((instruction & 0b10000000) == 0)
    //  Pixel
      unsigned char coord = instruction & 0b00111111;  //  Uns
interessieren nur die 6 untersten Bits
      unsigned char y = coord / 9;
      unsigned char x = (coord - y * 9) % 3;
      unsigned char z = (coord - y * 9) / 3;
      buffer[x][y][z] = (instruction & 0b01000000) / 0b01000000;
    else
    //  Instruction
      unsigned char operation = instruction & 0b11110000;  //  Uns
interessieren nur die 4 obersten Bits
      if (operation == CLEAR || operation == SET)
        unsigned char frame = instruction & 0b00001111;
        //  Folgende Werte entsprechen SET_ALL
        unsigned char x_min = 0, x_max = 3, y_min = 0, y_max = 3, z_min
= 0, z_max = 3;
        //  Folgendes kann noch optimiert werden.
        //  Y-Z-Ebene (links, mitte, rechts)
        if (frame == 1) { x_min = 0; x_max = 1; }
        if (frame == 2) { x_min = 1; x_max = 2; }
        if (frame == 3) { x_min = 2; x_max = 3; }
        //  X-Z-Ebene (unten, mitte, oben)
        if (frame == 4) { y_min = 0; y_max = 1; }
        if (frame == 5) { y_min = 1; y_max = 2; }
        if (frame == 6) { y_min = 2; y_max = 3; }
        //  X-Y-Ebene (hinten, mitte, vorne)
        if (frame == 7) { z_min = 0; z_max = 1; }
        if (frame == 8) { z_min = 1; z_max = 2; }
        if (frame == 9) { z_min = 2; z_max = 3; }
        if (frame < 10)
          for (unsigned char z = z_min; z < z_max; z++)
            for (unsigned char y = y_min; y < y_max; y++)
              for (unsigned char x = x_min; x < x_max; x++)
                if (operation == SET) buffer[x][y][z] = 1; else
buffer[x][y][z] = 0;
        } else
          for (unsigned char a = 0; a < 3; a++)
            for (unsigned char b = 0; b < 3; b++)
              unsigned char x = 0, y = 0, z = 0;
              if (frame == 10) { x = a; y = b; z = b; }      //  Unten
hinten nach oben vorne
              if (frame == 11) { x = a; y = a; z = b; }      //  Unten
links nach oben rechts
              if (frame == 12) { x = a; y = b; z = 2 - b; }    //  Unten
vorne nach oben hinten
              if (frame == 13) { x = a; y = 2 - a; z = b; }    //  Oben
links nach unten rechts
              if (frame == 14) { x = b; y = a; z = b; }      //  Hinten
links nach vorne rechts
              if (frame == 15) { x = a; y = 2 - b; z = 2 - a; }  //
Vorne links nach hinten rechts
      } else
      if (operation == FPS)
        if (program_counter + 1 < program_length) program_counter++; //
else: Fehler
        unsigned char byte =
        fps = byte;
      } else
      if (operation == NEXT)
        //  VAR_FPS = 0: Frame nicht zeichnen, keine Wartezeit
        if (fps > 0)
          //  Temporäres Array ins "echte" Array kopieren
          for (unsigned char z = 0; z < 3; z++)
            for (unsigned char y = 0; y < 3; y++)
              for (unsigned char x = 0; x < 3; x++)
                cube[x][y][z] = buffer[x][y][z];
          for (unsigned char i = 0; i < fps; i++)
            _delay_ms(5);
    //  Programmzähler erhöhen, bzw. bei Erreichen des Programmendes
wieder von vorn beginnen
    if (program_counter + 1 < program_length) program_counter++; else
//  Initialisierung
void init()
  //  Ports vorbereiten
  DDRB =  0b11111111;  //  PB0-PB7: LED 1-8 (Kathoden)  //DDRB =
0b11111111;
  PORTB =  0b11111111;  //  HIGH            //PORTB =  0b11111111;
  DDRC = 0x00;  //eigenes...!!!?
  DDRD =  0b1111000;  //  PD6: LED 9 (Kathode); PD5-PD3: A-C (Anoden)
  PORTD =  0b1000000;
  //  Timer-Interrupt "TIMER1" vorbereiten
  cli();
  set_bit(TIMSK, OCIE1A);
  set_bit(TCCR1B, WGM12);
  //  Animations-Geschwindigkeit
  OCR1AH = 0x05;
  OCR1AL = 0x00;
  clear_bit(TCCR1B, CS12);  //  Prescaler 64
  set_bit(TCCR1B, CS11);
  set_bit(TCCR1B, CS10);
  sei();
//  Interruptvektor von TIMER1
SIGNAL(SIG_OUTPUT_COMPARE1A)
  //  Pixel multiplexen
        unsigned char n = z * 3 + x;
        //  LED an
        if (cube[x][y][z] == 1)
          if (n < 8) clear_bit(PORTB, n); else clear_bit(PORTD, 6);
          set_bit(PORTD, y + 3);
        //  ON-Time
        for (unsigned long i = 0; i < PIXEL_TON; i++) { asm
volatile("nop"::); }
        //  LED aus
          clear_bit(PORTD, y + 3);
          if (n < 8) set_bit(PORTB, n); else set_bit(PORTD, 6);
        //  OFF-Time
        for (unsigned long i = 0; i < PIXEL_TOFF; i++) { asm
das ist der code, wo ich den cube ansteuern kann....
//  Programmcode
  FPS, 5,
PSET(1,2,0), NEXT,
danke schonmal...
mfg.: J. adler
Gast #2421524
Hm, Du hast offenbar nicht einmal rudimentär Ahnung von dem, was Du
vorhast... Wäre es nicht angeraten, statt Quelltexte zu kopieren,
zunächst einmal ein "C"-Tutorial durchzuarbeiten?
Gruß, Guenther
OP #2421539
ist richtig...mit c tutorial hab ich angefangen und durchgearbeitet.
auch den "kopierten" code verstehe ich...
das ist nicht das problem...
aber wie bekomme ich raus, wo ich so eine anweißung einfügen kann...
mein verdacht war schonmal, die initialisierung der ports, mit if zu
bestimmen, doch das haut nicht hin, da ich mehrere ausgangszustände
bestimmen will
OP #2421705
//  http://mosfetkiller.de/?s=miniledcube
//  Includes
#include <avr/io.h>
//  Bitpopelei
//  Bool
#define FALSE  0
#define TRUE  1
//  Definitionen
//  Cube-Array
unsigned char cube[6][3][3];
//  Prototypen
void init();
//  Programmzähler
//  Framezähler
//  Pixelmakros
//  Instructions
//  Variablen
#define VAR_FPS  0
#define CLEAR_ALL  0
#define SET_ALL    0
//  Für NEXT
//  Programmcode
  FPS, 10,
  CLEAR, SET + 12, NEXT, CLEAR, SET + 14, NEXT,  //  Vor- und zurück
tanzen
  CLEAR, SET + 12, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 5, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,  //  Umdrehung
  FPS, 5, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 6, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,
  FPS, 6, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 7, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,
  FPS, 7, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 8, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,
  FPS, 8, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 9, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,
  FPS, 9, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  FPS, 10, CLEAR, SET + 8, NEXT, CLEAR, SET + 14, NEXT,
  FPS, 10, CLEAR, SET + 2, NEXT, CLEAR, SET + 15, NEXT,
  CLEAR, SET + 8, NEXT, CLEAR, SET + 12, NEXT,  //  Umfallen
  CLEAR, SET + 4, NEXT, CLEAR, SET + 5, NEXT, CLEAR, SET + 6, NEXT,  //
Ebenen
  CLEAR, SET + 1, NEXT, CLEAR, SET + 2, NEXT, CLEAR, SET + 3, NEXT,
  CLEAR, SET + 7, NEXT, CLEAR, SET + 8, NEXT, CLEAR, SET + 9, NEXT,
  FPS, 10,  //  Außen langlaufen
  CLEAR,
PSET(1,2,0), NEXT,
  PCLEAR(0,0,0), PSET(2,0,0), PCLEAR(0,1,0), PSET(2,1,0), PCLEAR(0,2,0),
PSET(2,2,0), NEXT,
  PCLEAR(1,0,0), PSET(2,0,1), PCLEAR(1,1,0), PSET(2,1,1), PCLEAR(1,2,0),
PSET(2,2,1), NEXT,
  PCLEAR(2,0,0), PSET(2,0,2), PCLEAR(2,1,0), PSET(2,1,2), PCLEAR(2,2,0),
PSET(2,2,2), NEXT,
  PCLEAR(2,0,1), PSET(1,0,2), PCLEAR(2,1,1), PSET(1,1,2), PCLEAR(2,2,1),
PSET(1,2,2), NEXT,
  PCLEAR(2,0,2), PSET(0,0,2), PCLEAR(2,1,2), PSET(0,1,2), PCLEAR(2,2,2),
PSET(0,2,2), NEXT,
  PCLEAR(1,0,2), PSET(0,0,1), PCLEAR(1,1,2), PSET(0,1,1), PCLEAR(1,2,2),
PSET(0,2,1), NEXT,
  PCLEAR(0,0,2), PSET(0,0,0), PCLEAR(0,1,2), PSET(0,1,0), PCLEAR(0,2,2),
PSET(0,2,0), NEXT,
  PCLEAR(0,0,1), PCLEAR(0,1,1), PCLEAR(0,2,1),
  CLEAR, SET + 8, NEXT, CLEAR, SET + 7, NEXT,
//  Main
int main(void)
  //  Initialisierung
  init();
  //  Hauptschleife
  while (1)
    //  Pixel
    else
    //  Instruction
= 0, z_max = 3;
        if (frame < 10)
        } else
      } else
else: Fehler
        fps = byte;
      } else
        if (fps > 0)
            _delay_ms(5);
//  Initialisierung
void init()
0b11111111;
  PORTD =  0b1000000;
  cli();
  OCR1AH = 0x05;
  OCR1AL = 0x00;
  sei();
        //  LED an
        //  ON-Time
        //  LED aus
        //  OFF-Time
Gast #2422244
Mahlzeit,
mal ganz von vorn, falls du noch nicht verstanden hast, was dir andere
Leute versucht haben zu sagen:
* nur du weißt wie (hoffentlich) deine aufgebaute Hardware aussieht und
damit, wie das entsprechende Programm dazu funktionieren muss
* nur du kannst sagen, was dein Programm machen sollst, weil du es
(hoffentlich) selbst geschrieben hast
* nur du weißt, was du mit dem "if", welches du einbauen möchtest,  wann
zu welchem Zeitpunkt bezwecken willst
Ergo (weißt du obiges nicht):
* solltest du dich mal mit der Funktionsweise deiner Hardware
beschäftigen
* solltest du verstehen, wie deine MCU funktioniert
* solltest du versuchen, dein Programm zu verstehen
* solltest du versuchen zu erklären, welche Funktionalität du noch
einbauen willst
Wenn du diese Punkte mal abgearbeitet hast, sollte es eigentlich kein
Problem sein, die richtige Stelle im Programm zu finden. Alles andere
dürfte sinnlos sein!
PS.: baue den "if" einfach in Zeile 42 ein, das stimmt immer...
Gast #2739377
hallo zusammen...
ich habe den code auch mal probiert, bzw. sitze ich noch dran...
beim brennen jedoch (im avr studio 6) erscheinen 2 fehler meldungen...
1. unknow type name 'prog_char'
2. unknow type name 'prog_char'
zuweißung für erste meldung:
zuweißung für zweite meldung:
kann mir jemand weiterhelfen.?
danke....
