1 | #include <asf.h>
2 | #include "conf_usart_example.h"
3 | #include "status_codes.h"
4 |
5 |
6 | /*FUNKTIONSPROTOTYPEN*/
7 | void senden(uint16_t wert);
8 | void pause(uint16_t ms);
9 | void analog(uint16_t zahl);
10 | void ADC_init();
11 |
12 |
13 |
14 | int main(void)
15 | {
16 |
17 | // USART init
18 | static usart_rs232_options_t USART_SERIAL_OPTIONS = {
19 | .baudrate = USART_SERIAL_EXAMPLE_BAUDRATE,
20 | .charlength = USART_SERIAL_CHAR_LENGTH,
21 | .paritytype = USART_SERIAL_PARITY,
22 | .stopbits = USART_SERIAL_STOP_BIT
23 | };
24 |
25 | ADC_init(); //ADC init
26 | sysclk_init();
27 | board_init();
28 |
29 | #ifdef USARTC0
30 | if ((uint16_t) USART_SERIAL_EXAMPLE == (uint16_t) & USARTC0) {
31 | sysclk_enable_module(SYSCLK_PORT_C, PR_USART0_bm);
32 | }
33 | #endif
34 |
35 | // Initialize usart driver in RS232 mode
36 | usart_init_rs232(USART_SERIAL_EXAMPLE, &USART_SERIAL_OPTIONS);
37 |
38 | uint16_t temp=0;
39 |
40 | while (true) {
41 |
42 |
43 | ADCB.CH0.MUXCTRL = ADC_CH_MUXPOS_PIN1_gc;
44 | ADCB.CTRLA |= 0x4;
45 | //while(!ADCB.CH0.INTFLAGS);
46 | temp=ADCB.CH0RES;
47 |
48 | pause(500);
49 | analog(temp);
50 | pause(500);
51 | analog(1357);
52 | }
53 |
54 |
55 | }
56 |
57 | /*FUNKTIONEN*/
58 | void senden(uint16_t zahl) //Hier wird nur die Zahl ins ASCII-Format gebracht
59 | {
60 | uint8_t temp = 0;
61 |
62 | temp = zahl/10000;
63 | usart_putchar(USART_SERIAL_EXAMPLE,temp+48);
64 | zahl -= temp*10000;
65 |
66 | temp = zahl/1000;
67 | usart_putchar(USART_SERIAL_EXAMPLE,temp+48);
68 | zahl -= temp*1000;
69 |
70 | temp = zahl/100;
71 | usart_putchar(USART_SERIAL_EXAMPLE,temp+48);
72 | zahl -= temp*100;
73 |
74 | temp = zahl/10;
75 | usart_putchar(USART_SERIAL_EXAMPLE,temp+48);
76 | zahl -= temp*10;
77 |
78 | usart_putchar(USART_SERIAL_EXAMPLE,zahl+48);
79 |
80 | }
81 | void pause(uint16_t ms)
82 | {
83 | uint32_t count;
84 |
85 | // Berechnet den counter von der Runtergezählt wird
86 | count = sysclk_get_cpu_hz() / 6;
87 | count *= ms;
88 | count /= 1000;
89 |
90 | do {
91 | asm("");
92 | } while (--count);
93 | }
94 | void analog(uint16_t zahl)
95 | {
96 | usart_putchar(USART_SERIAL_EXAMPLE, 0x0D);
97 | usart_putchar(USART_SERIAL_EXAMPLE,'A');
98 | usart_putchar(USART_SERIAL_EXAMPLE,'n');
99 | usart_putchar(USART_SERIAL_EXAMPLE,'a');
100 | usart_putchar(USART_SERIAL_EXAMPLE,'l');
101 | usart_putchar(USART_SERIAL_EXAMPLE,'o');
102 | usart_putchar(USART_SERIAL_EXAMPLE,'g');
103 | usart_putchar(USART_SERIAL_EXAMPLE,':');
104 | usart_putchar(USART_SERIAL_EXAMPLE,' ');
105 | senden(zahl);
106 |
107 | }
108 | void ADC_init(){
109 |
110 |
111 |
112 |
113 | ADCB.CTRLA |= 0x01; // enable adc
114 | ADCB.CTRLB = ADC_RESOLUTION_12BIT_gc; // 12-bit
115 | ADCB.REFCTRL = ADC_REFSEL_VCC_gc | 0x02; // internal VCC-0.6V
116 | ADCB.PRESCALER = ADC_PRESCALER_DIV128_gc;
117 | ADCB.CH0.CTRL = ADC_CH_INPUTMODE_SINGLEENDED_gc; // single ended
118 | ADCB.CH0.MUXCTRL = ADC_CH_MUXPOS_PIN1_gc; // input pin B1 - Poti
119 |
120 |
121 |
122 | }
