1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.numeric_std.all;
4 | LIBRARY lpm;
5 | USE lpm.lpm_components.all;
6 |
7 | ENTITY Func IS
8 | PORT(
9 | x : in std_logic_vector(7 downto 0);
10 | reset : in std_logic;
11 | clk : in std_logic;
12 | f : out std_logic_vector(7 downto 0);
13 | done : out std_logic;
14 | );
15 | END Func;
16 |
17 | ARCHITECTURE rtl OF Func IS
18 |
19 | --dividierer mit 16 bit zähler und 8bit nenner
20 | component LPM_DIVIDE
21 | generic (LPM_WIDTHN : natural := 16;
22 | LPM_WIDTHD : natural := 8;
23 | LPM_NREPRESENTATION : string := "UNSIGNED";
24 | LPM_DREPRESENTATION : string := "UNSIGNED";
25 | LPM_PIPELINE : natural := 0;
26 | LPM_TYPE : string := L_DIVIDE;
27 | LPM_HINT : string := "UNUSED");
28 | port (NUMER : in std_logic_vector(LPM_WIDTHN-1 downto 0);
29 | DENOM : in std_logic_vector(LPM_WIDTHD-1 downto 0);
30 | ACLR : in std_logic := '0';
31 | CLOCK : in std_logic := '0';
32 | CLKEN : in std_logic := '1';
33 | QUOTIENT : out std_logic_vector(LPM_WIDTHN-1 downto 0);
34 | REMAIN : out std_logic_vector(LPM_WIDTHD-1 downto 0));
35 | end component;
36 |
37 | component LPM_MULT
38 | generic ( LPM_WIDTHA : natural := 8;
39 | LPM_WIDTHB : natural := 8;
40 | LPM_WIDTHS : natural := 16;
41 | LPM_WIDTHP : natural := 16;
42 | LPM_REPRESENTATION : string := "UNSIGNED";
43 | LPM_PIPELINE : natural := 0;
44 | LPM_TYPE: string := L_MULT;
45 | LPM_HINT : string := "UNUSED");
46 | port ( DATAA : in std_logic_vector(LPM_WIDTHA-1 downto 0);
47 | DATAB : in std_logic_vector(LPM_WIDTHB-1 downto 0);
48 | ACLR : in std_logic := '0';
49 | CLOCK : in std_logic := '0';
50 | CLKEN : in std_logic := '1';
51 | SUM : in std_logic_vector(LPM_WIDTHS-1 downto 0) := (OTHERS
52 | => '0');
53 | RESULT : out std_logic_vector(LPM_WIDTHP-1 downto 0));
54 | end component;
55 |
56 | type state_t is (S_start, S_calc, S_done);
57 | signal state, state_nxt : state_t;
58 |
59 | signal cs_div_res : std_logic_vector(15 downto 0);
60 | signal cs_mult_res : std_logic_vector(15 downto 0);
61 | signal cs_diff_res : std_logic_vector(7 downto 0);
62 | signal counter : std_logic_vector(7 downto 0);
63 | signal calc : std_logic;
64 |
65 | begin
66 |
67 | cs_mult: LPM_MULT
68 | port map (
69 | DATAA => "11111111",
70 | DATAB => cs_diff_res,
71 | RESULT => cs_mult_res);
72 |
73 | cs_div: LPM_DIVIDE
74 | port map (
75 | NUMER => cs_mult_res,
76 | DENOM => "10010110", --150 binär
77 | QUOTIENT => cs_div_res);
78 |
79 | process(x)
80 | begin
81 | cs_diff_res <= std_logic_vector(unsigned(x)-unsigned("110010")); --binär 50
82 | f <= cd_div_res (7 downto 0); --die ersten 8 least significant bit
83 | end process;
84 |
85 | process(clk)
86 | begin
87 | if clk_in'event and clk_in='1' then
88 | if reset = '1' then
89 | counter <= (others => '0');
90 | state <= S_start;
91 | end if;
92 | state <= state_nxt;
93 | if calc = '1' then
94 | counter <= std_logic_vector(unsigned(counter) + 1);
95 | else
96 | counter <= (others => '0');
97 | end if;
98 | end if;
99 | end process;
100 |
101 | process(state, counter)
102 | begin
103 | --defaultwerte
104 |
105 | state_nxt <= state;
106 | calc <= '0';
107 | done <= '0';
108 |
109 | case state is
110 | when S_start =>
111 | state_nxt <= S_calc;
112 |
113 | when S_calc =>
114 | calc='1';
115 | if counter > 50 then --nach spätestens 50 takten sollte die berechnung fertig sein
116 | state_nxt <= S_done;
117 | end if;
118 |
119 | when S_done =>
120 | done <= '1';
121 | --idle
122 | end case;
123 | end process;
124 | END rtl;
