1 | $:~/workspace/ICnova$ make
2 |
3 | Checking build system dependencies:
4 | BUILDROOT_DL_DIR clean: Ok
5 | CC clean: Ok
6 | CXX clean: Ok
7 | CPP clean: Ok
8 | CFLAGS clean: Ok
9 | INCLUDES clean: Ok
10 | CXXFLAGS clean: Ok
11 | which installed: Ok
12 | sed works: Ok (/bin/sed)
13 | GNU make version '3.81': Ok
14 | C compiler '/usr/bin/gcc'
15 | C compiler version '4.6.2': Ok
16 | C++ compiler '/usr/bin/g++'
17 | C++ compiler version '4.6.2': Ok
18 | awk installed: Ok
19 | bash installed: Ok
20 | bison installed: Ok
21 | flex installed: Ok
22 | gettext installed: Ok
23 | makeinfo installed: Ok
24 | Build system dependencies: Ok
25 |
26 | rm -rf /home/m/workspace/ICnova/project_build_avr32/adb1004g45b5inch/buildroot-config
27 | mkdir -p /home/m/workspace/ICnova/project_build_avr32/adb1004g45b5inch
28 | cp -dpRf package/config/buildroot-config /home/m/workspace/ICnova/project_build_avr32/adb1004g45b5inch/buildroot-config
29 | toolchain/patch-kernel.sh /home/m/workspace/ICnova/toolchain_build_avr32/linux-2.6.33.2 toolchain/kernel-headers \
30 | linux-2.6.33.2-\*.patch{,.gz,.bz2}
31 |
32 | Applying linux-2.6.33.2-0004-.gitignore-ignore-arm-image-output.patch using plaintext:
33 | patching file .gitignore
34 |
35 | Applying linux-2.6.33.2-0008-atmel_serial-adding-support-for-RS485.patch using plaintext:
36 | patching file arch/arm/include/asm/ioctls.h
37 | patching file drivers/serial/atmel_serial.c
38 | patching file include/linux/atmel_serial.h
39 |
40 | Applying linux-2.6.33.2-0009-ICnova-add-support-for-ADB3000-revB.patch using plaintext:
41 | can't find file to patch at input line 16
42 | Perhaps you used the wrong -p or --strip option?
43 | The text leading up to this was:
44 | --------------------------
45 | |From 44a7e4c328dc2d1d40525fead5d80d28c3e8758c Mon Sep 17 00:00:00 2001
46 | |From: Benjamin Tietz <benjamin@marvin.local.in-circuit.de>
47 | |Date: Wed, 15 Dec 2010 14:00:48 +0100
48 | |Subject: [PATCH 09/18] [ICnova] add support for ADB3000 revB
49 | |
50 | |This changed the numbering of UARTs and the atmel-tsadcc was
51 | |replaced by a ads7846.
52 | |---
53 | | arch/arm/mach-at91/board-icnova_adb3000.c | 42 +++++++++++++++++++++++++---
54 | | 1 files changed, 37 insertions(+), 5 deletions(-)
55 | |
56 | |diff --git a/arch/arm/mach-at91/board-icnova_adb3000.c b/arch/arm/mach-at91/board-icnova_adb3000.c
57 | |index 6006faa..7bbe786 100644
58 | |--- a/arch/arm/mach-at91/board-icnova_adb3000.c
59 | |+++ b/arch/arm/mach-at91/board-icnova_adb3000.c
60 | --------------------------
61 | File to patch:
62 | Skip this patch? [y] y
63 | Skipping patch.
64 | 7 out of 7 hunks ignored
65 | Patch failed! Please fix linux-2.6.33.2-0009-ICnova-add-support-for-ADB3000-revB.patch!
66 | make: *** [/home/maxim/workspace/ICnova/toolchain_build_avr32/linux-2.6.33.2/.patched] Error 1
