1 | void svpwm(volatile svpwm_options_t *svpwm_options)
2 | {
3 | int tempsr0, tempsr2, tempsr4;
4 | int delta_i, delta_2i, delta_z;
5 | int Vb_M_Va, Vb_P_Va, Va_P_Vb, Va_M_Vb;
6 |
7 | //******************************************************************
8 | // Vbeta-sqrt(3)*Valpha
9 | Vb_M_Va = svpwm_options->Vbeta - (svpwm_options->Valpha <<1) + (svpwm_options->Valpha >>2) + (svpwm_options->Valpha >>6);
10 | // Vbeta+sqrt(3)*Valpha
11 | Vb_P_Va = (svpwm_options->Vbeta <<1) - Vb_M_Va;
12 | if (svpwm_options->Vbeta >0)
13 | {
14 | if (svpwm_options->Valpha >0)
15 | {
16 | if (Vb_M_Va <0) // SECTOR =i =1
17 | { // delta_2i= 2*sqrt(2)* Vbeta
18 | svpwm_options->current_to_be_measured=BC;
19 | delta_2i = (svpwm_options->Vbeta<<1) + (svpwm_options->Vbeta>>1) + (svpwm_options->Vbeta>>2) + (svpwm_options->Vbeta>>4)+ (svpwm_options->Vbeta>>6);
20 |
21 | // delta_i = 2*sqrt(1.5)*Valpha - 0.5*delta_2i
22 | delta_i = (svpwm_options->Valpha<<1) + (svpwm_options->Valpha>>1) - (svpwm_options->Valpha>>4) - (delta_2i>>1);
23 |
24 | // delta_z = 0.5*( 1 - delta_2i - delta_i )
25 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
26 |
27 | tempsr0 = delta_z + delta_2i + delta_i;
28 | tempsr2 = delta_2i + delta_z;
29 | tempsr4 = delta_z;
30 | }
31 |
32 | else // SECTOR = i = 2
33 | {
34 | svpwm_options->current_to_be_measured=AC;
35 | //Valpha-sqrt(3)*Vbeta
36 | Va_P_Vb = svpwm_options->Valpha + (svpwm_options->Vbeta<<1) - (svpwm_options->Vbeta>>2) - (svpwm_options->Vbeta>>6);
37 | // delta_2i = sqrt(2)* Vb_M_Va
38 | delta_2i = (Vb_M_Va<<1) - (Vb_M_Va>>1) -(Vb_M_Va>>4) -(Vb_M_Va>>5);
39 | // delta_i = sqrt(1.5)*(Valpha+sqrt(3)*Vbeta) - 0.5*delta_2i
40 | delta_i = Va_P_Vb + (Va_P_Vb>>2) - (Va_P_Vb>>5) - (delta_2i>>1);
41 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
42 | tempsr0 = delta_i + delta_z;
43 | tempsr2 = delta_i + delta_2i + delta_z;
44 | tempsr4 = delta_z;
45 | }
46 | }
47 | else
48 | if (Vb_P_Va <0) // SECTOR = i = 3
49 | {
50 | svpwm_options->current_to_be_measured=CA;
51 | // delta_2i = -sqrt(2)*Vb_P_Va
52 | delta_2i = -(Vb_P_Va<<1) + (Vb_P_Va>>1) + (Vb_P_Va>>4) + (Vb_P_Va>>5);
53 | // Valpha-sqrt(3)*Vbeta
54 | Va_M_Vb = svpwm_options->Valpha - (svpwm_options->Vbeta<<1) + (svpwm_options->Vbeta>>2) + (svpwm_options->Vbeta>>6);
55 | // delta_i = -sqrt(1.5)*(Va_M_Vb)- 0.5*delta_2i
56 | delta_i = - Va_M_Vb - (Va_M_Vb>>2) + (Va_M_Vb>>5) - (delta_2i>>1);
57 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
58 | tempsr0 = delta_z;
59 | tempsr2 = delta_i + delta_2i+ delta_z;
60 | tempsr4 = delta_2i + delta_z;
61 | }
62 | else // SECTOR = i = 2
63 | {
64 |
65 | svpwm_options->current_to_be_measured=AC;
66 | //Valpha+sqrt(3)*Vbeta
67 | Va_P_Vb = svpwm_options->Valpha + (svpwm_options->Vbeta<<1) - (svpwm_options->Vbeta>>2) - (svpwm_options->Vbeta>>6);
68 | // delta_2i = sqrt(2)* Vb_M_Va
69 | delta_2i = (Vb_M_Va<<1) - (Vb_M_Va>>1) -(Vb_M_Va>>4) -(Vb_M_Va>>5);
70 | // delta_i = sqrt(1.5)*(Valpha+sqrt(3)*Vbeta) - 0.5*delta_2i
71 | delta_i = Va_P_Vb + (Va_P_Vb>>2) - (Va_P_Vb>>5) - (delta_2i>>1);
72 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
73 | tempsr0 = delta_i + delta_z;
74 | tempsr2 = delta_i + delta_2i + delta_z;
75 | tempsr4 = delta_z;
76 | }
77 | }
78 | else
79 | {
80 | if (svpwm_options->Valpha >0)
81 | {
82 | if (Vb_P_Va <0)// SECTOR = i = 5
83 | {
84 | svpwm_options->current_to_be_measured=AB;
85 | // delta_2i = - sqrt(2)*( Vbeta - sqrt(3)*Valpha)
86 | delta_2i = -(Vb_M_Va<<1) + (Vb_M_Va>>1) + (Vb_M_Va>>4) + (Vb_M_Va>>5);
87 | //Valpha+sqrt(3)*Vbeta
88 | Va_P_Vb = svpwm_options->Valpha + (svpwm_options->Vbeta<<1) - (svpwm_options->Vbeta>>2) - (svpwm_options->Vbeta>>6);
89 | // delta_i = - sqrt(1.5)*(Valpha+sqrt(3)*Vbeta) - 0.5* delta_2i
90 | delta_i = - Va_P_Vb - (Va_P_Vb>>2) + (Va_P_Vb>>5) - (delta_2i>>1);
91 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
92 | tempsr0 = delta_2i + delta_z;
93 | tempsr2 = delta_z;
94 | tempsr4 = delta_z + delta_2i + delta_i;
95 | }
96 | else // SECTOR = i = 6
97 | {
98 | svpwm_options->current_to_be_measured=CB;
99 | // delta_2i = sqrt(2)*( Vbeta + sqrt(3)*Valpha)
100 | delta_2i = (Vb_P_Va<<1) - (Vb_P_Va>>1) - (Vb_P_Va>>4) - (Vb_P_Va>>5);
101 | // Valpha-sqrt(3)*Vbeta
102 | Va_M_Vb = svpwm_options->Valpha - (svpwm_options->Vbeta<<1) + (svpwm_options->Vbeta>>2) + (svpwm_options->Vbeta>>6);
103 | // delta_i = sqrt(1.5)*(Valpha-sqrt(3)*Vbeta) - 0.5* delta_2i
104 | delta_i = Va_M_Vb + (Va_M_Vb>>2) - (Va_M_Vb>>5) - (delta_2i>>1);
105 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
106 | tempsr0 = delta_2i + delta_z + delta_i;
107 | tempsr2 = delta_z;
108 | tempsr4 = delta_z + delta_i;
109 | }
110 | }
111 | else
112 | if (Vb_M_Va <0)// SECTOR = i = 5
113 | {
114 | svpwm_options->current_to_be_measured=AB;
115 | // delta_2i = - sqrt(2)*( Vbeta - sqrt(3)*Valpha)
116 | delta_2i = -(Vb_M_Va<<1) + (Vb_M_Va>>1) + (Vb_M_Va>>4) + (Vb_M_Va>>5);
117 | //Valpha+sqrt(3)*Vbeta
118 | Va_P_Vb = svpwm_options->Valpha + (svpwm_options->Vbeta<<1) - (svpwm_options->Vbeta>>2) - (svpwm_options->Vbeta>>6);
119 | // delta_i = - sqrt(1.5)*(Valpha+sqrt(3)*Vbeta) - 0.5* delta_2i
120 | delta_i = - Va_P_Vb - (Va_P_Vb>>2) + (Va_P_Vb>>5) - (delta_2i>>1);
121 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
122 | tempsr0 = delta_2i + delta_z;
123 | tempsr2 = delta_z;
124 | tempsr4 = delta_z + delta_2i + delta_i;
125 | }
126 | else // SECTOR = i = 4
127 | {
128 | svpwm_options->current_to_be_measured=BA;
129 | // delta_2i= -2*sqrt(2)* Vbeta
130 | delta_2i = -(svpwm_options->Vbeta<<1)- (svpwm_options->Vbeta>>1) - (svpwm_options->Vbeta>>2) - (svpwm_options->Vbeta>>4)- (svpwm_options->Vbeta>>6);
131 | // delta_i = -2*sqrt(1.5)*Valpha - 0.5*delta_2i
132 | delta_i = -(svpwm_options->Valpha<<1) - (svpwm_options->Valpha>>1) + (svpwm_options->Valpha>>4) - (delta_2i>>1);
133 | delta_z = (Un_1 - delta_2i - delta_i)>>1;
134 | tempsr0 = delta_z;
135 | tempsr2 = delta_z + delta_i;
136 | tempsr4 = delta_z + delta_2i + delta_i;
137 | }
138 | }
139 |
140 | svpwm_options->duty0 = (tempsr0>>20) - (tempsr0>>22) - (tempsr0>>23) - (tempsr0>>25) - (tempsr0>>26)-10;
141 | svpwm_options->duty1 = svpwm_options->duty0+20;
142 | svpwm_options->duty2 = (tempsr2>>20) - (tempsr2>>22) - (tempsr2>>23) - (tempsr2>>25) - (tempsr2>>26)-10;
143 | svpwm_options->duty3 = svpwm_options->duty2+20;
144 | svpwm_options->duty4 = (tempsr4>>20) - (tempsr4>>22) - (tempsr4>>23) - (tempsr4>>25) - (tempsr4>>26)-10;
145 | svpwm_options->duty5 = svpwm_options->duty4+20;
146 | }
