1 | ----------------------------------------------------------------------------------
2 | -- Company:
3 | -- Engineer:
4 | --
5 | -- Create Date: 10:01:07 02/27/2012
6 | -- Design Name:
7 | -- Module Name: fsm - Behavioral
8 | -- Project Name:
9 | -- Target Devices:
10 | -- Tool versions:
11 | -- Description:
12 | --
13 | -- Dependencies:
14 | --
15 | -- Revision:
16 | -- Revision 0.01 - File Created
17 | -- Additional Comments:
18 | --
19 | ----------------------------------------------------------------------------------
20 | library IEEE;
21 | use IEEE.STD_LOGIC_1164.ALL;
22 |
23 | -- Uncomment the following library declaration if using
24 | -- arithmetic functions with Signed or Unsigned values
25 | use IEEE.NUMERIC_STD.ALL;
26 |
27 | -- Uncomment the following library declaration if instantiating
28 | -- any Xilinx primitives in this code.
29 | --library UNISIM;
30 | --use UNISIM.VComponents.all;
31 |
32 | entity fsm is
33 | Port ( clk : in STD_LOGIC;
34 | res_n : in STD_LOGIC;
35 | lcd_e : out STD_LOGIC;
36 | lcd_rs : out STD_LOGIC;
37 | lcd_rw : out STD_LOGIC;
38 | lcd_db : inout STD_LOGIC_VECTOR (7 downto 0));
39 | end fsm;
40 |
41 | architecture Behavioral of fsm is
42 |
43 | constant delay_40ms : integer := 4000000;
44 | constant delay_37us : integer := 3700;
45 | constant delay_1520us : integer := 152000;
46 | constant tsu : integer := 0; -- RS, R/W setup time (min. 0ns)
47 | constant twdsu : integer := 8; -- Write data setup time (min. 80ns)
48 | constant tdh : integer := 30; -- Data hold time (min. 300ns)
49 | constant th : integer := 1; -- RS, R/W hold time (min. 10ns)
50 |
51 | type state_type is (boot, function_set1, function_set2, disp_ctr, disp_clr, disp_entr, write_letter,idle);
52 | signal current_state : state_type := boot;
53 | signal cnt : integer range 0 to delay_40ms := 0;
54 |
55 | begin
56 |
57 | process(clk) is
58 |
59 | begin
60 | if rising_edge(clk) then
61 | case current_state is
62 | when boot => if cnt < delay_40ms then
63 | cnt <= cnt + 1;
64 | current_state <= boot;
65 | else
66 | cnt <= 0;
67 | current_state <= function_set1;
68 | end if;
69 |
70 | when function_set1 => lcd_rs <= '0';
71 | lcd_rw <= '0';
72 | lcd_db <= "001110" & '-' & '-';
73 |
74 | if cnt < delay_37us then
75 | cnt <= cnt + 1;
76 | current_state <= function_set1;
77 | else
78 | cnt <= 0;
79 | current_state <= function_set2;
80 | end if;
81 |
82 | when function_set2 => lcd_rs <= '0';
83 | lcd_rw <= '0';
84 | lcd_db <= "001110" & '-' & '-';
85 | if cnt < delay_37us then
86 | cnt <= cnt + 1;
87 | current_state <= function_set2;
88 | else
89 | cnt <= 0;
90 | current_state <= disp_ctr;
91 | end if;
92 |
93 | when disp_ctr => lcd_rs <= '0';
94 | lcd_rw <= '0';
95 | lcd_db <= "00001111";
96 | if cnt < delay_37us then
97 | cnt <= cnt + 1;
98 | current_state <= disp_ctr;
99 | else
100 | cnt <= 0;
101 | current_state <= disp_clr;
102 | end if;
103 |
104 | when disp_clr => lcd_rs <= '0';
105 | lcd_rw <= '0';
106 | lcd_db <= "00000001";
107 | if cnt < delay_1520us then
108 | cnt <= cnt + 1;
109 | current_state <= disp_clr;
110 | else
111 | cnt <= 0;
112 | current_state <= disp_entr;
113 | end if;
114 | when disp_entr => lcd_rs <= '0';
115 | lcd_rw <= '0';
116 | lcd_db <= "00000110";
117 | if cnt < delay_37us then
118 | cnt <= cnt + 1;
119 | current_state <= disp_entr;
120 | else
121 | cnt <= 0;
122 | current_state <= write_letter;
123 | end if;
124 | when write_letter => if cnt < twdsu then
125 | lcd_e <= '1';
126 | lcd_rw <= '0';
127 | lcd_rs <= '1';
128 | lcd_db <= "01000001";
129 | cnt <= cnt + 1;
130 | elsif cnt = twdsu then
131 | lcd_e <= '0';
132 | cnt <= cnt + 1;
133 | elsif cnt < twdsu + th then
134 | cnt <= cnt + 1;
135 | elsif cnt = twdsu + th then
136 | lcd_rw <= '1';
137 | cnt <= cnt + 1;
138 | else
139 | cnt <= 0;
140 | current_state <= idle;
141 | end if;
142 |
143 | when idle => lcd_e <= '1';
144 | lcd_rw <= '1';
145 | lcd_db <= "--------";
146 |
147 | current_state <= idle;
148 | end case;
149 | end if;
150 | end process f;
151 |
152 | end Behavioral;
