1 | void StoreCalibrationValues(void)
2 | {
3 | uint8_t nBuffer[52];
4 | uint8_t i, j;
5 | uint16_t nTmpVal;
6 |
7 | FncDispEnable(false); // disable periodically function dispatcher
8 |
9 | //-----------------------------------------------------------------------------------
10 | // mark this block as calibrated or not as not calibrated -> store this information within CALIBRATION_STATUS section of EEPROM
11 | //-----------------------------------------------------------------------------------
12 | if (CalibrationTemp.fNominalLow == 0.0)
13 | {
14 | // by define a nominal low calibration point of 0.0 degree Celsius will mark this block as not calibrated
15 | nBuffer[0] = 0x00;
16 | nBuffer[1] = 0xFF;
17 | nBuffer[2] = 0x00;
18 | }
19 | else
20 | {
21 | // mark this block as calibrated
22 | nBuffer[0] = 0xA5;
23 | nBuffer[1] = 0x00;
24 | nBuffer[2] = 0x5A;
25 | }
26 | // write unique pattern to EEPROM to detect read / write access problems as well
27 | if(Epr_WriteBuffer(nBuffer, CALIB_STATUS_ADDRESS, 3) == ERROR)
28 | EH_SetErrorCode(ERR_EEPROM);
29 |
30 |
31 | //-----------------------------------------------------------------------------------
32 | // write calibration values for lower calibration point to EEPROM
33 | //-----------------------------------------------------------------------------------
34 |
35 | // clear temporary buffer
36 | // was 20 for (1+8+1)*2, for dlx (1+24+1)*2
37 | for (i=0; i<52; i++)
38 | nBuffer[i] = 0;
39 |
40 | // fill write buffer -> multiply values by 100 to store values including tenth and hundredth rank as integer and split them into two bytes
41 | i = 0;
42 | nTmpVal = (uint16_t)(CalibrationTemp.fNominalLow * 100.0);
43 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8; // high byte
44 | nBuffer[i++] = nTmpVal & 0x00FF; // low byte
45 |
46 | //AM: TODO: j max is changed from 8 to 24 channels for dlx
47 | for(j = 0; j < 24; j++)
48 | {
49 | nTmpVal =(uint16_t)(CalibrationTemp.fZoneLow[j] * 100.0);
50 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8;
51 | nBuffer[i++] = nTmpVal & 0x00FF;
52 | }
53 |
54 | nTmpVal =(uint16_t)(CalibrationTemp.fLidLow * 100.0);
55 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8;
56 | nBuffer[i++] = nTmpVal & 0x00FF;
57 |
58 | // write buffer to EEPROM
59 | if(Epr_WriteBuffer(nBuffer, CALIB_LOW_ADDRESS, 52) == ERROR)
60 | EH_SetErrorCode(ERR_EEPROM);
61 |
62 | //-----------------------------------------------------------------------------------
63 | // write calibration values for upper calibration point to EEPROM
64 | //-----------------------------------------------------------------------------------
65 |
66 | // clear temporary buffer
67 | for (i=0; i<52; i++)
68 | nBuffer[i] = 0;
69 |
70 | // fill write buffer -> multiply values by 100 to store values including tenth and hundredth rank as integer
71 | i = 0;
72 | nTmpVal =(uint16_t)(CalibrationTemp.fNominalHigh * 100.0);
73 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8; // high byte
74 | nBuffer[i++] = nTmpVal & 0x00FF; // low byte
75 |
76 | for(j = 0; j < 24; j++)
77 | {
78 | nTmpVal =(uint16_t)(CalibrationTemp.fZoneHigh[j] * 100.0);
79 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8;
80 | nBuffer[i++] = nTmpVal & 0x00FF;
81 | }
82 |
83 | nTmpVal =(uint16_t)(CalibrationTemp.fLidHigh * 100.0);
84 | nBuffer[i++] = (nTmpVal & 0xFF00) >> 8;
85 | nBuffer[i++] = nTmpVal & 0x00FF;
86 |
87 | // write buffer to EEPROM
88 | if(Epr_WriteBuffer(nBuffer, CALIB_HIGH_ADDRESS, 52) == ERROR)
89 | EH_SetErrorCode(ERR_EEPROM);
90 |
91 | FncDispEnable(true); // enable periodically function dispatcher
92 | }
