ASCII über UART senden
Gast #2635770
Ums einfach zu erklären: Ich möchte gerne das ASCII Zeichen "c" senden
und zwar in HEX. Mein Code sieht aus wie folgt.
// FID:            33X000035
// Target:         C8051F33x
// Tool chain:     Keil C51 7.50 / Keil EVAL C51
// Command Line:   None
// Release 1.0
//    -Initial Revision (PD)
//    -16 AUG 2006
// Includes
#include <c8051F330.h>                 // SFR declarations
#include <stdio.h>
// Global CONSTANTS
#define SYSCLK      24500000           // SYSCLK frequency in Hz
#define BAUDRATE        9600           // Baud rate of UART in bps
// Function PROTOTYPES
void SYSCLK_Init (void);
void UART0_Init (void);
void PORT_Init (void);
void Timer2_Init (int);
// MAIN Routine
void main (void)
   unsigned char inputcharacter;       // Used to store character from
UART
   PCA0MD &= ~0x40;                    // WDTE = 0 (clear watchdog timer
                                       // enable)
   PORT_Init();                        // Initialize Port I/O
   SYSCLK_Init ();                     // Initialize Oscillator
   UART0_Init();
   while (1)
// Initialization Subroutines
// PORT_Init
// Return Value : None
// Parameters   : None
// Configure the Crossbar and GPIO ports.
// P0.4   digital   push-pull    UART TX
// P0.5   digital   open-drain   UART RX
   P0MDOUT |= 0x10;                    // Enable UTX as push-pull output
   XBR0    = 0x01;                     // Enable UART on P0.4(TX) and
P0.5(RX)
   XBR1    = 0x40;                     // Enable crossbar and weak
pull-ups
// SYSCLK_Init
// This routine initializes the system clock to use the internal
oscillator
// at its maximum frequency.
// Also enables the Missing Clock Detector.
   OSCICN |= 0x03;                     // Configure internal oscillator
for
                                       // its maximum frequency
   RSTSRC  = 0x04;                     // Enable missing clock detector
// UART0_Init
// Configure the UART0 using Timer1, for <BAUDRATE> and 8-N-1.
   SCON0 = 0x10;                       // SCON0: 8-bit variable bit rate
                                       //        level of STOP bit is
ignored
                                       //        RX enabled
                                       //        ninth bits are zeros
                                       //        clear RI0 and TI0 bits
   if (SYSCLK/BAUDRATE/2/256 < 1) {
      TH1 = -(SYSCLK/BAUDRATE/2);
      CKCON &= ~0x0B;                  // T1M = 1; SCA1:0 = xx
      CKCON |=  0x08;
   } else if (SYSCLK/BAUDRATE/2/256 < 4) {
      TH1 = -(SYSCLK/BAUDRATE/2/4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   } else if (SYSCLK/BAUDRATE/2/256 < 12) {
      TH1 = -(SYSCLK/BAUDRATE/2/12);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 00
   } else {
      TH1 = -(SYSCLK/BAUDRATE/2/48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   TL1 = TH1;                          // Init Timer1
   TMOD &= ~0xf0;                      // TMOD: timer 1 in 8-bit
autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
   TI0 = 1;                            // Indicate TX0 ready
// End Of File
Gast #2635822
Ich habe keinen Schimmer wie ich das anstelle, über printf wird es ja
wohl nicht gehen, ich weiß nur dass ich in irgend ein Register (verm.
das SCON) etwas hineinschreiben muss.
Frage: Kann mir jemand genau erklären und evtl sogar zeigen wie ich
meinen Code ändern muss damit ich letztendlich ein Zeichen versenden
kann?!?!
Gast #2635901
Hmmm. Ich dachte eher so:
SBUF0 = 'c';
oder?!?!? Wo im Quellcode muss ich das dann einfügen wenn ich es
einmalig senden will? Mein Empfangstelle muss es in HEX bekommen!
Momentan ist es doch noch ASCII oder????
Gast #2635932
Peter S. schrieb:
> Ja ich brauch es als HEX-Wert, weil das Empfangsmodul nur HEX-Werte
> verarbeiten kann.
Was dir der Vorposter sagen wollte es gibt keinen "HEX-Wert". Der Wert
ist immer der Gleiche. Es unterscheidet sich die Darstellung. Es gilt:
'c' == 0x63 == 99 auch wenn sich die Darstellung hier in Textform
offensichtlich unterscheidet.
Was wichtig ist: willst du es Zeichenfolge oder als natives Byte
übertragen?
Gast #2636176
Gute Frage :D ich kann dir nur soviel sagen:
Auf der anderen Seite wartet ein Modul welches auf einen Tastaturbefehl
(via Hyperterminal z.B.) wartet z.B. "c" oder "v". Also wenn ich das
Modul direkt über den Hypterm. anspreche funktioniert es. Das selbe soll
jetzt mein Programm machen...
Gast #2636178
entlich mal ein sinnvolle aussage. Also braucht du es doch nicht als
Hex. Sende einfach als 'C' und gut ist.
Gast #2636239
> kann?!?!
Du guckst im Datenblatt nach, wie dein UART signalisiert, dass sein
Senderegister frei ist. Das Programm zum Senden des Zeichens sieht dann
etwa so aus:
while (Senderegister nicht frei);
Senderegister = "c";
Gast #2636493
Ich seh schon wir kommen der Sache näher :D
hab jetzt in der headerdatei rumgestöbert, da ich im  Datenblatt nichs
finden konnte... aufjedenfall steht da folgendes zu UART:
/* SCON0 0x98 */
sbit S0MODE =     0x9F ;  /* UART 0 MODE */
sbit MCE0 =       0x9D ;  /* UART 0 MCE */
sbit REN0 =       0x9C ;  /* UART 0 RX ENABLE */
sbit TB80 =       0x9B ;  /* UART 0 TX BIT 8 */
sbit RB80 =       0x9A ;  /* UART 0 RX BIT 8 */
sbit TI0 =        0x99 ;  /* UART 0 TX INTERRUPT FLAG */
sbit RI0 =        0x98 ;  /* UART 0 RX INTERRUPT FLAG */
kann es sein dass ich das sbit TB80 setzen muss???
Gast #2636547
Peter S. schrieb:
> da ich im Datenblatt nichs finden konnte
http://www.silabs.com/Support%20Documents/TechnicalDocs/C8051F33x.pdf
Seite 159:
SBUF0[7:0]: Serial Data Buffer Bits 7–0 (MSB–LSB)This SFR accesses two
registers; a transmit shift register and a receive latch register. When
data is written to SBUF0, it goes to the transmit shift register and is
held for serial transmis-sion. Writing a byte to SBUF0 initiates the
transmission. A read of SBUF0 returns the con-tents of the receive
latch.
