Hallo, wenn ich mit dem AVR Studio4 programmieren möchte, kommt immer diese Fehlermeldung, ich verwende einen ATMEL ISP Programmer: --------------------------- ISP Mode Error --------------------------- A problem occurred when executing the command. Make sure that you are using the correct programming method. Current mode is ISP. See the command output for more info. The troubleshooting section in the help system contains more information on what may have caused the problems. To open the help system, click the Help button below. Quick Tips: Verify that the device is placed in the correct socket, and that the ISP cable is properly connected. Check that the ISP programming frequency specified on the 'Main' page is well below 1/4 of the clock frequency of the device. Extra precaution should be made when using the CKDIV fuse and/or Clock Prescaler Register (CLKPR) on parts supporting this. --------------------------- OK Hilfe ---------------------------
Jonas W. schrieb: > wenn ich mit dem AVR Studio4 programmieren möchte, kommt immer diese > Fehlermeldung Ja, kommt vor. Welche von den angegebenen Punkten hast du schon abgearbeitet?
Hi Jonas, so wirklich warm mit µC bist du wohl noch nicht geworden, oder? :) Jonas W. schrieb: > --------------------------- > ISP Mode Error > --------------------------- > A problem occurred when executing the command. Make sure that you are > using the correct > programming method. Current mode is ISP. See the command output for more > info. > > The troubleshooting section in the help system contains more information > on what may > have caused the problems. To open the help system, click the Help button > below. > > Quick Tips: Verify that the device is placed in the correct socket, and > that the ISP > cable is properly connected. Check that the ISP programming frequency > specified on the > 'Main' page is well below 1/4 of the clock frequency of the device. > Extra precaution > should be made when using the CKDIV fuse and/or Clock Prescaler Register > (CLKPR) on > parts supporting this. > --------------------------- > OK Hilfe > --------------------------- Hast du die Quick Tips schon befolgt? Wenn du den Programmer anschließt, müsste eine zweite LED grün leuchten - das heißt, alles ist hardwaremäßig OK. Kannst du das bestätigen? Ferner probier doch mal, die Frequenz herunterzuschalten. 125 kHz z.B. Wenn du Pech hast, hast du dich von deinem µC ausgesperrt und müsstest ihn ggf. austauschen :( Gruß
Jonas W. schrieb: > Beide LEDs leuchten grün. Das ist doch schon mal gut :) > Und die Punkte habe ich abgearbeitet und es hat sich nichts geändert. Das ist nicht so gut :( Hast du zufällig einen Ersatz-µC, den du ausprobieren könntest? Gruß
Hängt an den ISP-Programmierpins irendwelche Periphie? Falls ja, würde ich die zum Programmieren einfach mal vom MC trennen.
Jonas W. schrieb: > Beide LEDs leuchten grün. > Und die Punkte habe ich abgearbeitet und es hat sich nichts geändert. Hast du mal die Fuses geprüft? Mit denen kenne ich mich leider auch nicht sonderlich gut aus, aber das ist das, was ich mit "aussperren" meinte. Gruß
Jonas W. schrieb: > Anderen Controller habe ich schon geprüft. Hast du mal ein Update für den Programmer durchgeführt? Wenn du AVR Studio geöffnet hast, ist da so ein Button mit "Con". Hast du da den richtigen Programmer ausgewählt?
