Hallo, wenn ich Programmieren möchte, kommt immer dieser Fehler: --------------------------- ISP Mode Error --------------------------- A problem occurred when executing the command. Make sure that you are using the correct programming method. Current mode is ISP. See the command output for more info. The troubleshooting section in the help system contains more information on what may have caused the problems. To open the help system, click the Help button below. Quick Tips: Verify that the device is placed in the correct socket, and that the ISP cable is properly connected. Check that the ISP programming frequency specified on the 'Main' page is well below 1/4 of the clock frequency of the device. Extra precaution should be made when using the CKDIV fuse and/or Clock Prescaler Register (CLKPR) on parts supporting this. --------------------------- OK Hilfe --------------------------- Und unten wo eingeblendet wird was er geschaft hat steh immer Dass hier: Getting isp parameter.. SD=0x00 .. OKOK Reading FLASH input file.. OK Setting mode and device parameters.. OK! Entering programming mode.. OK! Erasing device.. OK! Programming FLASH .. FAILED! Leaving programming mode.. OK! Getting isp parameter.. SD=0x00 .. OKOK Reading EEPROM input file.. OK Setting mode and device parameters.. OK! Entering programming mode.. OK! Programming EEPROM .. FAILED! Leaving programming mode.. OK! Getting isp parameter.. SD=0x00 .. OK Validating ELF input file.. OK! Reading FLASH input..OK! No EEPROM contents in ELF file. No FUSE contents in ELF file. No LOCKBITS contents in ELF file. No SIGNATURE contents in ELF file. Setting mode and device parameters.. OK! Entering programming mode.. OK! Erasing device.. OK! Programming FLASH .. FAILED! Leaving programming mode.. OK! Danke schon einmal für Lösungsvorschläge.
Fange erst einmal klein an: Lies die Signatur des Bausteins aus. Wenn das erfolgreich ist, ist die ISP-Verbindung schon mal in Ordnung. Dann verrate mal dein großes Geheimnis: um welchen Kontroller handelt es sich denn ? Da gibt es nämlich Modelle, die auch JTAG sprechen und das verträgt sich nicht mit ISP. Auch der Typ des Programmiergeräts könnte eine nützliche Angabe sein. usw.
Ich kann alles auslesen, nur weiter geht es immer noch nicht.
Hi
>Als programmer habe ich einen AVR ISP mklII.
Einen echten oder einen Clone?
Welche ISP-Frequenz ist eingestellt?
Stromversorgung?
MfG Spess
Es ist ein originaler. 8 mHz als Frequenz Externe Spannungsversorgung ist auch angeschlossen.
Hi
>8 mHz als Frequenz
Ich meine die ISP-Frequenz
Programmierdialog-> Main -> ISP Frequency
MfG Spess
Du hast auch den richtigen MC im 'Main' Tab ( da wo die Signatur gelesen wird) eingestellt und nach dem Auslesen kommt die Meldung' Signature matches the selected Device'? Wähle als ISP Frequenz dann mal 125 kHz aus - auch in diesem Tab des Programmierdialogs. Sind etwa Lockbits gesetzt? Kann ja eigentlich nicht sein, da Jonas W. schrieb: > Ich kann alles auslesen, nur weiter geht es immer noch nicht. Trotzdem: In diesem Fall geht es nicht weiter, bevor du ein 'Erase Device' angestossen hast. Falls dann immer noch nichts geht, könnte es sein, das * Zuwenig Betriebsspannung am MC anliegt. * Der MC 'ermüdet' ist, also nicht mehr programmierfähig. Das sollte aber erst nach etwa 10000 Programmiervorgängen passieren. * Doch noch ein Clock/Takt Problem besteht. Geh nochmal die Fuses durch und stelle sicher, das der interne 8 Mhz Oszillator ausgewählt ist.
Hi
>Da hatte ich 4kHz.
Ist zwar relativ niedrig, aber möglich. Fällt mir als mögliche
Fehlerquelle nur noch deine Hardware ein. Wie sieht die aus?
MfG Spess
Die zuprogrammierende Platine habe ich überprüft, daran liegt es nicht.
Jetzt funktioniert es, jetzt muss ich nur noch eine .eep Datei erstellen und daran scheitert es. Kann mir einer kurz erklären wie dass in dem AVR Studio4 geht?
Wenn Du keinen Quelltext hast, dann EEPROM auslesen und abspeichern. Wenn Du ASM-Quelltext mit .eseg hast, dann wird die .eep-Datei beim Assemblieren automatisch erstellt. ...
Hi >Jetzt funktioniert es, Wie jetzt? Wunderheilung? >Kann mir einer kurz erklären wie dass in dem AVR Studio4 geht? Welche Sprache? MfG Spess
Wo ich die ISP Frequenz runter gestellt habe, konnte ich es übertragen. Ich programmiere in C. Und mit dem ersten vorschlag mit dem Umwandeln funktioniert es nicht. Hat vielleicht noch jemand einen anderen Vorschlag?
Hi >Hat vielleicht noch jemand einen anderen Vorschlag? Must du mal hier nachsehen: http://www.mikrocontroller.net/articles/AVR-GCC-Tutorial#EEPROM MfG Spess
Hi
>Da steht auch nicht viel.
Und was vermisst du da?
MfG Spess
Hi
>Wie ich es in dem AVR Studio4 umwandeln kann.
In was?
uint8_t eeFooByte EEMEM = 123;
Wenn du eine Variable mit EEMEN anlegst wird automatisch ein File für
den EEPROM (xyz.eep) angelegt. Und mit dem programmierst du dann deinen
Controller.
MfG Spess
Verstehe ich noch nicht ganz, kann ich dass einfach in den CODE kopieren? Kann einer mal ein Bild dazu einstellen? In .eep möchte ich es umwandeln.
>Verstehe ich noch nicht ganz, kann ich dass einfach in den CODE kopieren? Und ich versteh nicht was Du nicht verstehst. Du musst die Antworten schon lesen. :-) Spess hat Dir den Code schon geschrieben: uint8_t eeFooByte EEMEM = 123; Das IST der Code. Das musst Du nicht in den Code kopieren (falls es nicht doch schon welchen gibt). >In .eep möchte ich es umwandeln. Schön. Hast Du das hier gelesen? >Wenn du eine Variable mit EEMEN anlegst wird automatisch ein File für >den EEPROM (xyz.eep) angelegt.
Hi >>In .eep möchte ich es umwandeln. >Schön. Hast Du das hier gelesen? >>Wenn du eine Variable mit EEMEN anlegst wird automatisch ein File für >>den EEPROM (xyz.eep) angelegt. Da meine C-Kenntnisse, als notorischer Assemblerprogrammier, eher rudimentär sind war mir folgendes entgangen: Damit das funktioniert muss noch die eeprom.h eingebunden werden: #include <avr/eeprom.h> Dann funktioniert es auch mit dem EEPROM. MfG Spess
