1 | #include <avr/interrupt.h>
2 | #include <EEPROM.h>
3 |
4 |
5 | //Deklaration der Variablen
6 | volatile unsigned int timer4_ovl_counter;
7 | volatile unsigned int timer4_value;
8 | volatile float high_time;
9 | volatile float low_time;
10 | volatile float period;
11 | volatile float frequency;
12 | volatile float prescale;
13 | volatile unsigned long timestamp;
14 | volatile unsigned long test1;
15 | volatile unsigned long test2;
16 |
17 |
18 | // Deklaration der Funktionen
19 | void timer4_config (byte, int, byte, byte, byte); //Prototyp Timer 4 Konfiguration
20 | void initialize_ir(void); //Prototyp Interrupt initialisieren
21 | void get_PWM(int); //PWM Messung starten, Übergabeparameter Zeit in ms
22 |
23 |
24 | void setup(){
25 |
26 | digitalWrite(13, LOW);
27 | // EEPROM zu Null setzen
28 | for (int i = 0; i < 512; i++)
29 | EEPROM.write(i, 0);
30 | // LED anschalten wenn fertig
31 | digitalWrite(13, HIGH);
32 |
33 | Serial.begin(9600); //Kommunikation PC-Schnittstelle aktivieren
34 |
35 | initialize_ir(); //Interrupts aktivieren
36 |
37 | timer4_ovl_counter = 0;
38 | timer4_value = 0;
39 | high_time = 0.0;
40 | low_time = 0.0;
41 | period = 0.0;
42 | frequency = 0.0;
43 | prescale = 0;
44 | timestamp = 0;
45 | test1 = 0;
46 | test2 = 0;
47 | timer4_config(0,8,0,0,1); //Modus 0 = normal; Prescaler auf 8; Capture Compare Modus = 0; Start mit steigender Flanke
48 |
49 | Serial.println("Function Setup is done");
50 |
51 | }
52 |
53 |
54 |
55 | void loop(){
56 |
57 | Serial.println("High Time [s]: ");
58 | Serial.println(high_time,DEC);
59 | Serial.println("\t");
60 |
61 | Serial.println("Low Time [s]: ");
62 | Serial.println(low_time,DEC);
63 | Serial.println("\t");
64 |
65 | Serial.println("Periodendauer [s]: ");
66 | Serial.println(period,DEC);
67 | Serial.println("\t");
68 |
69 | Serial.println("Frequenz [Hz]: ");
70 | Serial.println(frequency,DEC);
71 | Serial.println("\t");
72 |
73 | Serial.println(timer4_value);
74 | Serial.println("\t");
75 |
76 | Serial.println(timer4_ovl_counter);
77 | Serial.println("\t");
78 |
79 | Serial.println(prescale);
80 | Serial.println("\t");
81 |
82 | Serial.print(test1);
83 | Serial.print("\t");
84 | Serial.print(test2);
85 | Serial.println("\t");
86 |
87 |
88 | TIMSK4 |= (1 << ICIE4);
89 |
90 | timestamp = millis();
91 | while((timestamp + 200) >= millis()){}
92 |
93 | TIMSK4 &=~ (1 << ICIE4);
94 |
95 | timestamp = millis();
96 | while((timestamp + 2000) >= millis()){}
97 | // delay(2000);
98 |
99 |
100 | }
101 |
102 |
103 | ISR(__vector_default)
104 | {
105 | Serial.println("Bad ISR");
106 | }
107 |
108 |
109 | void initialize_ir(void){
110 | sei(); //globale Interrupt Freigabe
111 | TIMSK4 |= (1 << TOIE4); //Overflow Timer 4 Interrupt aktiviert
112 | TIMSK4 &=~ (1 << ICIE4); // TIMSK4 |= (1 << ICIE4); //Capture Event Interrupt aktiviert
113 | }
114 |
115 | // Overflow Interrupt: hochzaehlen Overflowvariable, beruecksichtigen beim Zaehlwert Interrupt Name: TIMER4_OVF_vect
116 | ISR(TIMER4_OVF_vect){
117 | cli(); //Interrupts deaktivieren
118 | test1 = test1 + 1;
119 | timer4_ovl_counter = timer4_ovl_counter + 1;
120 | TIFR4 &=~ (1 << TOV4); //Interrupt Flag fuer Overflow zuruecksetzen
121 | sei();
122 | }
123 |
124 | //Capture Event Interrupt: bei erkannter Flanke muss der Zaehlwert des Timers ausgelesen werden
125 | ISR(TIMER4_CAPT_vect){
126 | cli();
127 | test2 += 1;
128 | while((ASSR & 0x4) == 0x4){} //Pause: Maskierung um gesetztes drittes Bit zu erkennen: TCN2UB ist gesetzt solange TCNT4 beschrieben wird
129 | digitalWrite(13, HIGH);
130 | TCCR4A &=~( (1 << CS42) | (1 << CS41) | (1 << CS40)); //Timer anhalten
131 |
132 | timer4_value = ICR4L; // ICR4L 8 Bit Low Zaehlwert auslesen
133 | timer4_value |= (ICR4H << 8); // ICR4H 8 Bit High Zaehlwert auslesen
134 |
135 | //Wenn auf positive Flanke getriggert wird, ist die gemessene Zeit zuvor low_time (Bit ist ICES4)
136 | if((TCCR4B & 0x40) == 0x40){
137 | low_time = ( float(timer4_value) + float(65535 * timer4_ovl_counter) ) * (prescale / 16000000); //beruecksichtigt Zaehler Ueberlauf, und Prescalefaktor
138 | timer4_ovl_counter = 0;
139 | TCCR4B &=~ (1 << ICES4); //wenn auf Positiv getriggert wurde, wird nun auf negative Flanke umgestellt
140 | }
141 |
142 | //Wenn auf negative Flanke getriggert wird, ist die gemessene Zeit zuvor high_time (Bit ist ICES4)
143 | else if((TCCR4B & 0x40) == 0x0){
144 | high_time = ( float(timer4_value) + float(65535 * timer4_ovl_counter) ) * (prescale / 16000000);
145 | timer4_ovl_counter = 0;
146 | TCCR4B |= (1 << ICES4); //wenn auf Negativ getriggert wurde, wird nun auf positive Flanke umgestellt
147 | }
148 |
149 | //Zaehlerstand zuruecksetzten, High-Byte zuerst, dann Low-Byte
150 | TCNT4H = 0x0;
151 | TCNT4L = 0x0;
152 | digitalWrite(13, LOW);
153 |
154 | period = high_time + low_time; //Berechnung der Periodendauer und Frequenz
155 | frequency = 1 / period;
156 |
157 |
158 | TIFR4 &=~ (1 << ICF4); //Interrupt Flag fuer Capture Event zuruecksetzen
159 | sei();
160 | }
161 |
162 |
163 | void timer4_config (byte modus, int prescaler, byte COM4A1_COM4A0, byte COM4B1_COM4B0, byte ICNC4_ICES4)
164 | {
165 | //Bitweise Maskierung
166 | modus &= 15;
167 | COM4A1_COM4A0 &= 3;
168 | COM4B1_COM4B0 &= 3;
169 | ICNC4_ICES4 &= 3;
170 | prescale = float(prescaler);
171 |
172 | byte takt = 0 ;
173 | switch (prescaler)
174 | {
175 | case -99: takt = 6; break;
176 | case -89: takt = 7; break;
177 | case 0: takt = 0; break;
178 | case 1: takt = 1; break;
179 | case 8: takt = 2; break;
180 | case 64: takt = 3; break;
181 | case 256: takt = 4; break;
182 | case 1024: takt = 5; break;
183 | default:
184 | takt = 1;
185 | }
186 |
187 | TCCR4A = (COM4A1_COM4A0 << 6) | (COM4B1_COM4B0 << 4) | (modus & 3);
188 | TCCR4B = (ICNC4_ICES4 << 6) | ((modus & 0xC) << 1) | takt;
189 |
190 | while((ASSR & 0x1) == 0x1){} //Maskierung um gesetztes erstes Bit zu erkennen: TCR2UB ist gesetzt solange TCCR4 beschrieben wird
191 | }
