Forum: Compiler & IDEs avr-gcc funktioniert nach Update nicht mehr (Linux)
von
updater (Gast)
08.05.2012 20:26
Guten Abend,
Ich habe (blöderweise) ein update meines Kubuntu gemacht. Ich bin jetzt
mit der wohl neuesten 12.04 oder sowas unterwegs. Leider schmeißt mir
mein make seit dem nur noch grütze raus. Undzwar: 1 In file included from / usr / lib / gcc / avr / 4 . 5 . 3 / include / stdint . h : 3 : 0 ,
2 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / inttypes . h : 37 ,
3 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdio . h : 44 ,
4 from main . c : 32 :
5 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 121 : 1 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ typedef ’
6 In file included from / usr / lib / gcc / avr / 4 . 5 . 3 / include / stdint . h : 3 : 0 ,
7 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / inttypes . h : 37 ,
8 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdio . h : 44 ,
9 from main . c : 32 :
10 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 159 : 16 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_least8_t ’
11 In file included from / usr / lib / gcc / avr / 4 . 5 . 3 / include / stdint . h : 3 : 0 ,
12 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / inttypes . h : 37 ,
13 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdio . h : 44 ,
14 from main . c : 32 :
15 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 213 : 16 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_fast8_t ’
16 In file included from main . c : 36 : 0 :
17 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / avr / pgmspace . h : 221 : 16 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ prog_int8_t ’
Meine Versuche: Ich habe zuerst avr-gcc und avr-libc deinstalliert, dann
apt-get update gemacht, autoremove und dann wieder installiert. Hat
nichts gebracht.
Leider bin ich nicht so der Held was Linux und AVR angeht, würde aber
gerne bisschen weiter programmieren. Lösungsvorschläge irgendjemand?
Grüße
Du installierst in /usr/lib? Klingt seltsam...
Die Pfade sehen aber eher so aus als hättest nach /usr installiert?
Was sagt denn der Aufruf mit -v, und das steht an den angemeckerten
Stellen?
prog_types sind deprecated.
von
updater (Gast)
08.05.2012 21:09
Wenn du das sagst, scheints zu stimmen... Ich hab keine Ahnung. Ich
benutze sudo apt-get install
Bis jetzt hat das immer einwandfrei mit allem und jedem geklappt. Wie
kann ich denn den Installationspfad überhaupt beeinflussen? Dachte unter
Linux wird das alles automatisch gemacht.
Ich habe jetzt mal nur: avr-gcc main.c -v eingegeben.
1 avr - gcc main . c - v
2 Using built - in specs .
3 COLLECT_GCC = avr - gcc
4 COLLECT_LTO_WRAPPER =/ usr / lib / gcc / avr / 4 . 5 . 3 / lto - wrapper
5 Target : avr
6 Configured with : .. / src / configure - v -- enable - languages = c , c ++ -- prefix =/ usr / lib -- infodir =/ usr / share / info -- mandir =/ usr / share / man -- bindir =/ usr / bin -- libexecdir =/ usr / lib -- libdir =/ usr / lib -- enable - shared -- with - system - zlib -- enable - long - long -- enable - nls -- without - included - gettext -- disable - libssp -- build = x86_64 - linux - gnu -- host = x86_64 - linux - gnu -- target = avr
7 Thread model : single
8 gcc version 4 . 5 . 3 ( GCC )
9 COLLECT_GCC_OPTIONS = ' - v '
10 / usr / lib / gcc / avr / 4 . 5 . 3 / cc1 - quiet - v main . c - quiet - dumpbase main . c - auxbase main - version - o / tmp / cchoxGF8 . s
11 GNU C ( GCC ) version 4 . 5 . 3 ( avr )
12 compiled by GNU C version 4 . 6 . 2 , GMP version 5 . 0 . 2 , MPFR version 3 . 1 . 0 - p3 , MPC version 0 . 9
13 GGC heuristics : -- param ggc - min - expand = 100 -- param ggc - min - heapsize = 131072
14 ignoring nonexistent directory "/usr/lib/gcc/avr/4.5.3/../../../avr/sys-include"
15 #include "..." search starts here:
16 #include <...> search starts here:
17 / usr / lib / gcc / avr / 4 . 5 . 3 / include
18 / usr / lib / gcc / avr / 4 . 5 . 3 / include - fixed
19 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include
20 End of search list .
21 GNU C ( GCC ) version 4 . 5 . 3 ( avr )
22 compiled by GNU C version 4 . 6 . 2 , GMP version 5 . 0 . 2 , MPFR version 3 . 1 . 0 - p3 , MPC version 0 . 9
23 GGC heuristics : -- param ggc - min - expand = 100 -- param ggc - min - heapsize = 131072
24 Compiler executable checksum : a178c2de5985e958d5ea3a6b75766c05
25 In file included from / usr / lib / gcc / avr / 4 . 5 . 3 / include / stdint . h : 3 : 0 ,
26 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / inttypes . h : 37 ,
27 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdio . h : 44 ,
28 from main . c : 32 :
29 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 121 : 1 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ typedef ’
30 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 159 : 18 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_least8_t ’
31 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 213 : 16 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_fast8_t ’
32 In file included from main . c : 33 : 0 :
33 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / avr / io . h : 428 : 6 : warning : # warning "device type not defined"
34 In file included from main . c : 35 : 0 :
35 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / util / delay . h : 95 : 3 : warning : # warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
36 In file included from main . c : 36 : 0 :
37 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / avr / pgmspace . h : 221 : 19 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ prog_int8_t ’
38 main . c : In function ‘ init ’ :
39 main . c : 102 : 3 : error : ‘ DDRB ’ undeclared ( first use in this function )
40 main . c : 102 : 3 : note : each undeclared identifier is reported only once for each function it appears in
41 main . c : 102 : 16 : error : ‘ PB5 ’ undeclared ( first use in this function )
42 main . c : 102 : 29 : error : ‘ PB3 ’ undeclared ( first use in this function )
43 main . c : 102 : 42 : error : ‘ PB2 ’ undeclared ( first use in this function )
44 main . c : 103 : 3 : error : ‘ SPCR ’ undeclared ( first use in this function )
45 main . c : 103 : 17 : error : ‘ SPE ’ undeclared ( first use in this function )
46 main . c : 103 : 30 : error : ‘ MSTR ’ undeclared ( first use in this function )
47 main . c : 104 : 2 : error : ‘ SPSR ’ undeclared ( first use in this function )
48 main . c : 104 : 16 : error : ‘ SPI2X ’ undeclared ( first use in this function )
49 main . c : 107 : 2 : error : ‘ TCCR0 ’ undeclared ( first use in this function )
50 main . c : 107 : 17 : error : ‘ CS01 ’ undeclared ( first use in this function )
51 main . c : 107 : 31 : error : ‘ CS00 ’ undeclared ( first use in this function )
52 main . c : 108 : 2 : error : ‘ TIMSK ’ undeclared ( first use in this function )
53 main . c : 108 : 17 : error : ‘ TOIE0 ’ undeclared ( first use in this function )
54 main . c : 111 : 2 : error : ‘ TCCR1B ’ undeclared ( first use in this function )
55 main . c : 111 : 18 : error : ‘ CS11 ’ undeclared ( first use in this function )
56 main . c : 111 : 32 : error : ‘ WGM12 ’ undeclared ( first use in this function )
57 main . c : 112 : 17 : error : ‘ OCIE1A ’ undeclared ( first use in this function )
58 main . c : 113 : 2 : error : ‘ OCR1A ’ undeclared ( first use in this function )
59 main . c : In function ‘ SPI_schiebe ’ :
60 main . c : 245 : 2 : error : ‘ SPDR ’ undeclared ( first use in this function )
61 main . c : 247 : 10 : error : ‘ SPSR ’ undeclared ( first use in this function )
62 main . c : 247 : 23 : error : ‘ SPIF ’ undeclared ( first use in this function )
63 main . c : 249 : 2 : error : ‘ PORTB ’ undeclared ( first use in this function )
64 main . c : 249 : 17 : error : ‘ PB2 ’ undeclared ( first use in this function )
Das ist die Ausgabe direkt aus dem Terminal kopiert. Ich kann damit
leider herzlich wenig anfangen...
von
g457 (Gast)
08.05.2012 21:14
> avr-gcc main.c -v
da fehlt ein '-mmcu=$mcu'. Zeig mal was dann rauskommt.
von
updater (Gast)
08.05.2012 21:20
Kann es sein, dass es an der Zeile liegt?: ignoring nonexistent
1 Using built - in specs .
2 COLLECT_GCC = avr - gcc
3 COLLECT_LTO_WRAPPER =/ usr / lib / gcc / avr / 4 . 5 . 3 / lto - wrapper
4 Target : avr
5 Configured with : .. / src / configure - v -- enable - languages = c , c ++ -- prefix =/ usr / lib -- infodir =/ usr / share / info -- mandir =/ usr / share / man -- bindir =/ usr / bin -- libexecdir =/ usr / lib -- libdir =/ usr / lib -- enable - shared -- with - system - zlib -- enable - long - long -- enable - nls -- without - included - gettext -- disable - libssp -- build = x86_64 - linux - gnu -- host = x86_64 - linux - gnu -- target = avr
6 Thread model : single
7 gcc version 4 . 5 . 3 ( GCC )
8 COLLECT_GCC_OPTIONS = ' - v ' ' - mmcu = '
9 / usr / lib / gcc / avr / 4 . 5 . 3 / cc1 - quiet - v main . c - quiet - dumpbase main . c - mmcu = - auxbase main - version - o / tmp / cckpf3kr . s
10 cc1 : error : missing argument to "-mmcu="
von
g457 (Gast)
08.05.2012 21:28
> COLLECT_GCC_OPTIONS='-v' '-mmcu='
> cc1: error: missing argument to "-mmcu="
da noch die mmcu reinsubstituieren.. sowas wie 'm16' für einen atmega16
von
g457 (Gast)
08.05.2012 21:32
huch, update: muss latürnich heissen '-mmcu=atmega16' für einen m16 :-)
von
updater (Gast)
08.05.2012 21:33
Ok, da hab ich dann mal substituiert und nun kommen wieder mehr
Fehlermeldungen.
4 Target : avr
8 COLLECT_GCC_OPTIONS = ' - v ' ' - mmcu = atmega8 '
9 / usr / lib / gcc / avr / 4 . 5 . 3 / cc1 - quiet - v - imultilib avr4 main . c - quiet - dumpbase main . c - mmcu = atmega8 - auxbase main - version - o / tmp / ccOK4yeg . s
10 GNU C ( GCC ) version 4 . 5 . 3 ( avr )
11 compiled by GNU C version 4 . 6 . 2 , GMP version 5 . 0 . 2 , MPFR version 3 . 1 . 0 - p3 , MPC version 0 . 9
12 GGC heuristics : -- param ggc - min - expand = 100 -- param ggc - min - heapsize = 131072
13 ignoring nonexistent directory "/usr/lib/gcc/avr/4.5.3/../../../avr/sys-include"
14 #include "..." search starts here:
15 #include <...> search starts here:
16 / usr / lib / gcc / avr / 4 . 5 . 3 / include
17 / usr / lib / gcc / avr / 4 . 5 . 3 / include - fixed
18 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include
19 End of search list .
20 GNU C ( GCC ) version 4 . 5 . 3 ( avr )
21 compiled by GNU C version 4 . 6 . 2 , GMP version 5 . 0 . 2 , MPFR version 3 . 1 . 0 - p3 , MPC version 0 . 9
22 GGC heuristics : -- param ggc - min - expand = 100 -- param ggc - min - heapsize = 131072
23 Compiler executable checksum : a178c2de5985e958d5ea3a6b75766c05
24 In file included from / usr / lib / gcc / avr / 4 . 5 . 3 / include / stdint . h : 3 : 0 ,
25 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / inttypes . h : 37 ,
26 from / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdio . h : 44 ,
27 from main . c : 32 :
28 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 121 : 1 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ typedef ’
29 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 159 : 18 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_least8_t ’
30 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / stdint . h : 213 : 16 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ int_fast8_t ’
31 In file included from main . c : 35 : 0 :
32 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / util / delay . h : 95 : 3 : warning : # warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
33 In file included from main . c : 36 : 0 :
34 / usr / lib / gcc / avr / 4 . 5 . 3 / .. / .. / .. / avr / include / avr / pgmspace . h : 221 : 19 : error : expected ‘ = ’ , ‘ , ’ , ‘ ; ’ , ‘ asm ’ or ‘ __attribute__ ’ before ‘ prog_int8_t ’
Nein.
von
Yalu X.
(yalu )
(Moderator )
08.05.2012 21:40
Ich bin mir fast sicher, dass in den ersten 31 Zeilen deines main.c
etwas Böses steht (z.B. eine Deklaration ohne abschließendes Semikolon)
oder etwas Böses includet wird.
Böses entfernen oder korrigieren und noch einmal probieren.
von
updater (Gast)
08.05.2012 21:45
> etwas Böses steht oder etwas Böses includet wird.
Boah wie ich mein Leben hasse... Ich habe bestimmt schon 4 Stunden
versucht das zu reparieren und habs aufs Update geschoben und da ist VOR
dem ersten #define ein Buchstabe gerutscht. Wie der da hingekommen ist,
ist mir ein Rätsel.... Bah.
So. Genug geflucht.
Danke für die Hilfe! Tut mir wirklich leid, dass ich mich da so tierisch
blöd bei angestellt habe!
Grüße!
