1 | void initPC_Com()
2 | {
3 | USART_Config conf;
4 | //USART_DMA_Config dmaConf;
5 | configureUSART2(&conf);
6 | //configureUSART2_DMA(&dmaConf);
7 | USART_Ini(&conf);
8 |
9 | currentUsedUSART = &conf;
10 |
11 |
12 | USARTDMA_Ini(&TestBuf,9);
13 | }
14 |
15 | static inline void configureUSART2(USART_Config* conf)
16 | {
17 | conf->Rx_Source = GPIO_PinSource3;
18 | conf->Tx_Source = GPIO_PinSource2;
19 | conf->LowSpeed_APB_PeripheralClock = RCC_APB1Periph_USART2;
20 | conf->AHB1_PeripheralClock_Rx = RCC_AHB1Periph_GPIOA;
21 | conf->AHB1_PeripheralClock_Tx = RCC_AHB1Periph_GPIOA;
22 | conf->GPIO_Rx_Pin = GPIO_Pin_3;
23 | conf->GPIO_Tx_Pin = GPIO_Pin_2;
24 | conf->Rx_PORT = GPIOA;
25 | conf->Tx_PORT = GPIOA;
26 | conf->GPIO_AlternativeFunction = GPIO_AF_USART2;
27 | conf->USARTx = USART2;
28 |
29 | conf->InterfaceConfig.USART_BaudRate = 115200;
30 | conf->InterfaceConfig.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
31 | conf->InterfaceConfig.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
32 | conf->InterfaceConfig.USART_Parity = USART_Parity_No;
33 | conf->InterfaceConfig.USART_StopBits = USART_CR2_STOP_1;
34 | conf->InterfaceConfig.USART_WordLength = USART_WordLength_8b;
35 |
36 | conf->USART_GPIO_Config.GPIO_Mode = GPIO_Mode_AF;
37 | conf->USART_GPIO_Config.GPIO_Speed = GPIO_Speed_25MHz;
38 | conf->USART_GPIO_Config.GPIO_OType = GPIO_OType_PP;
39 | conf->USART_GPIO_Config.GPIO_PuPd = GPIO_PuPd_NOPULL;
40 | };
41 |
42 | void USART_Ini(USART_Config* conf)
43 | {
44 | RCC_APB1PeriphClockCmd(conf->LowSpeed_APB_PeripheralClock, ENABLE);
45 | RCC_AHB1PeriphClockCmd(conf->AHB1_PeripheralClock_Rx, ENABLE);
46 | RCC_AHB1PeriphClockCmd(conf->AHB1_PeripheralClock_Tx, ENABLE);
47 |
48 | //Changes the mapping for the pins to use for USART for Port A
49 | GPIO_PinAFConfig(conf->Tx_PORT, conf->Tx_Source, conf->GPIO_AlternativeFunction);
50 | GPIO_PinAFConfig(conf->Rx_PORT, conf->Rx_Source, conf->GPIO_AlternativeFunction);
51 |
52 | conf->USART_GPIO_Config.GPIO_Pin = conf->GPIO_Rx_Pin;
53 | GPIO_Init(conf->Rx_PORT,&(conf->USART_GPIO_Config));
54 | conf->USART_GPIO_Config.GPIO_Pin = conf->GPIO_Tx_Pin;
55 | GPIO_Init(conf->Tx_PORT,&(conf->USART_GPIO_Config));
56 |
57 | //Set upt the USART configuration
58 | USART_Init(conf->USARTx,&(conf->InterfaceConfig));
59 |
60 | //Enable USART 2 now
61 | USART_Cmd(conf->USARTx, ENABLE);
62 | }
63 |
64 | void USARTDMA_Ini(uint8_t* buffer,uint32_t size)
65 | {
66 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
67 |
68 | DMA_DeInit(DMA1_Stream2);
69 | DMA_Cmd(DMA1_Stream2, DISABLE);
70 | DMA_InitTypeDef DMA_InitStruct;
71 | DMA_StructInit(&DMA_InitStruct);
72 | DMA_InitStruct.DMA_Channel = DMA_Channel_0;
73 | DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)&(USART2->DR);
74 | DMA_InitStruct.DMA_Memory0BaseAddr = (uint32_t)buffer;
75 | DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralToMemory;
76 | DMA_InitStruct.DMA_BufferSize = size;
77 | DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
78 | DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
79 | DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
80 | DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
81 | DMA_InitStruct.DMA_Mode = DMA_Mode_Circular;
82 | DMA_InitStruct.DMA_Priority = DMA_Priority_Medium;
83 | DMA_InitStruct.DMA_FIFOMode = DMA_FIFOMode_Disable;
84 | DMA_InitStruct.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
85 | DMA_InitStruct.DMA_MemoryBurst = DMA_MemoryBurst_Single;
86 | DMA_InitStruct.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
87 | DMA_Init(DMA1_Stream2, &DMA_InitStruct);
88 | DMA_Cmd(DMA1_Stream2, ENABLE);
89 | USART_DMACmd(USART2, USART_DMAReq_Rx, ENABLE);
90 |
91 | NVIC_InitTypeDef NVIC_InitStructure;
92 | /* Enable the USARTx Interrupt */
93 | NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream2_IRQn;
94 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0f;
95 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0f;
96 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
97 | NVIC_Init(&NVIC_InitStructure);
98 |
99 | /* Enable USART */
100 | DMA_ITConfig(DMA1_Stream2, DMA_IT_TC, ENABLE);
101 | }
