1 | // enable the SPI GPIO clock
2 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
3 |
4 | // disable card's CS before enabling pin to avoid pulses/glitches
5 | GPIO_SetBits (SD_GPIO, SD_PIN_NSS);
6 |
7 | GPIO_InitTypeDef GPIO_InitStructure;
8 |
9 | // set MISO as Input with pull-up enabled
10 | GPIO_InitStructure.GPIO_Pin = SD_PIN_MISO;
11 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
12 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
13 | GPIO_Init(SD_GPIO, &GPIO_InitStructure);
14 |
15 | // set SCK and MOSI as alternate function output (push/pull)
16 | GPIO_InitStructure.GPIO_Pin = SD_PIN_SCK | SD_PIN_MOSI;
17 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
18 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
19 | GPIO_Init(SD_GPIO, &GPIO_InitStructure);
20 |
21 | // set NSS as output push/pull
22 | GPIO_InitStructure.GPIO_Pin = SD_PIN_NSS;
23 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
24 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
25 | GPIO_Init(SD_GPIO, &GPIO_InitStructure);
26 |
27 | // init SPI with approx. 280KHz clock
28 | RCC_APB2PeriphClockCmd (RCC_APB2Periph_SPI1, ENABLE);
29 | SPI_InitTypeDef SPI_InitStructure;
30 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
31 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
32 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
33 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
34 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
35 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
36 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
37 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
38 | SPI_InitStructure.SPI_CRCPolynomial = 7; // ?
39 | SPI_Init (SPI1, &SPI_InitStructure);
40 |
41 | // enable SPI
42 | SPI_Cmd(SPI1, ENABLE);
43 |
44 | // wait 1ms after power on
45 | delay_ms(1);
46 |
47 | // ----- wait more than 74 clock cycles while card is disabled
48 | uint8_t res;
49 | uint32_t i;
50 | for (i=0; i<10000; ++i) //todo: reset to 10 again...
51 | {
52 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
53 | SPI_I2S_SendData(SPI1, 0xff);
54 | }
55 |
56 | uint32_t retries = 0;
57 | uint32_t timeout = 0;
58 | do
59 | {
60 |
61 | // ----- wait for transmission complete and enable card CS
62 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
63 | GPIO_ResetBits (SD_GPIO, SD_PIN_NSS);
64 |
65 | // ----- send CMD0
66 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
67 | SPI_I2S_SendData(SPI1, 0x40);
68 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
69 | SPI_I2S_SendData(SPI1, 0x00);
70 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
71 | SPI_I2S_SendData(SPI1, 0x00);
72 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
73 | SPI_I2S_SendData(SPI1, 0x00);
74 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
75 | SPI_I2S_SendData(SPI1, 0x00);
76 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
77 | SPI_I2S_SendData(SPI1, 0x95);
78 |
79 | // ----- read R1 response
80 | timeout = 0;
81 | do
82 | {
83 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
84 | SPI_I2S_ReceiveData (SPI1); // clear RNXE
85 | SPI_I2S_SendData(SPI1, 0xff); // start transmission
86 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); // wait for data
87 | res = SPI_I2S_ReceiveData (SPI1);
88 | }
89 | while ((res == 0xff) && (++timeout<100));
90 |
91 | // ----- wait for transmission complete and disable card CS
92 | while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
93 | GPIO_SetBits (SD_GPIO, SD_PIN_NSS);
94 | SPI_I2S_SendData(SPI1, 0xff); // 8 clock cycles while card is not selected to finish operation
95 | }
96 | while ((res == 0xff) && (++retries<100));
97 |
98 | SDC_TRACE_DEBUG(("SD: CMD0 returned %u, retries:%u, timeout:%u", res, retries, timeout));
99 |
100 |
101 | while (1);
