1 | //
2 | // local functions
3 | //
4 | ; r24 r22
5 | ; void startSCI(u08 mode, u08 address)
6 | startSCI:
7 | cbi MP3_PORT,MP3_PIN ; activate VS1001 Chip Select
8 | rcall spi_tx_rx ; send the mode (READ or WRITE)
9 | mov r24,r22 ; get address
10 | rjmp spi_tx_rx ; send address
11 |
12 | ; void endSCI(void)
13 | endSCI:
14 | sbi MP3_PORT, MP3_PIN ; set CS hi
15 | clr r25 ; do a 10us
16 | rcall delay10us ; delay
17 | ret
18 |
19 | spi_tx_rx:
20 | out SPDR, r24 ; send over SPI
21 | vspi1: sbis SPSR,SPIF ; while flag is clear
22 | rjmp vspi1 ; wait for SPI
23 | in r24, SPDR ; and get input data
24 | ret ; done
25 |
26 |
27 | //
28 | // global functions
29 | //
30 |
31 | ; r24
32 | ;void vs1001_send_data(u08 data)
33 | .global vs1001_send_data
34 | vs1001_send_data:
35 | cli
36 | sbi BSYNC_PORT,BSYNC_PIN ; start BSYNC
37 | out SPDR, r24 ; send over SPI
38 | nop
39 | nop
40 | nop
41 | cbi BSYNC_PORT,BSYNC_PIN ; stop BSYNC
42 | vssd1: sbis SPSR,SPIF ; while flag is clear
43 | rjmp vssd1 ; wait for SPI
44 | sei
45 | ret
46 |
47 |
48 | ; r24
49 | ;u16 vs1001_read(u08 address)
50 | .global vs1001_read
51 | vs1001_read:
52 | mov r22,r24 ; address in r22
53 | ldi r24,VS1001_READ
54 | rcall startSCI ; start SCI communication
55 | clr r24
56 | rcall spi_tx_rx ; get a byte
57 | mov r23,r24
58 | clr r24
59 | rcall spi_tx_rx ; get a byte
60 | mov r22,r24
61 | rcall endSCI
62 | mov r24,r22 ; get back word
63 | mov r25,r23 ; get back word
64 | ret
65 |
66 | ; r24 r23/r22
67 | ;void vs1001_write(u08 address, u16 data)
68 | .global vs1001_write
69 |
70 | vs1001_write:
71 | mov r18,r22 ; save register
72 | mov r22,r24 ; address in r22
73 | ldi r24,VS1001_WRITE
74 | rcall startSCI ; start SCI communication
75 | mov r24,r23 ; get hi byte
76 | rcall spi_tx_rx ; send it
77 | mov r24,r18 ; get lo byte
78 | rcall spi_tx_rx ; send it
79 | rjmp endSCI
80 |
81 |
82 | ; send a 32 byte block of data to the VS1001
83 | ; using the SPI port.
84 | ; r25/r24
85 | ;void vs1001_send_32(char *pData);
86 |
87 | .global vs1001_send_32
88 |
89 | vs1001_send_32:
90 | mov r31,r25 ; transfer input pointer to Z
91 | mov r30,r24
92 | ldi r25,32 ; init loop counter
93 | vs32_2: ld r24,Z+ ; get a byte and inc pointer
94 | rcall vs1001_send_data
95 | dec r25 ; dec loop counter
96 | brne vs32_2 ; loop if not zero
97 | ret
98 |
99 |
100 | ; r25/r24
101 | ; void vs1001_nulls(u16 nNulls)
102 | .global vs1001_nulls
103 |
104 | vs1001_nulls:
105 | mov r30,r24
106 | mov r31,r25
107 | vs1001_nulls_2:
108 | clr r24
109 | rcall vs1001_send_data
110 | sbiw r30,1
111 | brne vs1001_nulls_2
112 | ret
113 |
114 | ; r24 r22
115 | ;void vs1001_setvolume(u08 left, u08 right)
116 | .global vs1001_setvolume
117 | vs1001_setvolume:
118 | mov r23,r24
119 | ldi r24,11 ; volume register
120 | rjmp vs1001_write
121 |
122 |
123 | .comm vs1001_xtalcomp,2 ; compensation value for the VS1001 xtal
124 |
125 | ; r24
126 | ;void vs1001_reset(bool bLoud)
127 |
128 | .global vs1001_reset
129 |
130 | vs1001_reset:
131 | push r24
132 | ldi r25,8
133 | clr r24
134 | rcall vs1001_nulls
135 |
136 | ldi r24,VS1001_MODE
137 | clr r23
138 | ldi r22,4
139 | rcall vs1001_write
140 | rcall delay10us ; delay
141 | w_dreq:
142 | sbis DREQ_PORT-2,DREQ_PIN ; wait for DREQ
143 | rjmp w_dreq
144 | clr r25
145 | ldi r24,32;
146 | rcall vs1001_nulls
147 |
148 | ; set CLOCKF to compensate for a non 24,576 MHz x-tal
149 | ldi r24,VS1001_CLOCKF
150 | lds r23,vs1001_xtalcomp+1
151 | lds r22,vs1001_xtalcomp
152 | rcall vs1001_write
153 |
154 | ; set sound enchance bit
155 |
156 | pop r24
157 | clr r22 ; clear r22
158 | ror r24 ; rotate bit into carry
159 | ror r22 ; rotate carry to high bit of r22
160 | clr r23
161 | ldi r24,VS1001_MODE
162 | rjmp vs1001_write
163 |
164 |
165 | ; r25/r24
166 | ; void vs1001_setcomp(u16 comp)
167 | .global vs1001_setcomp
168 | vs1001_setcomp:
169 | sts vs1001_xtalcomp,r24
170 | sts vs1001_xtalcomp+1,r25
171 | ret
