Moin Moin, Vielleicht kann mir ja einer von euch weiterhelfen! Ich habe ein Programm geschrieben (sehr lang, da ich viel Text auf einem 2x16 LCD anzeigen lassen will) und hab nun ein Problem beim Build: Message[302] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 112 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 114 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 116 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[305] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 7757 : Using default destination of 1 (file). Message[305] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 7759 : Using default destination of 1 (file). Message[305] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 7761 : Using default destination of 1 (file). Message[302] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 7869 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\USERS\EXECUTE\DATEN\ELEKTRONIK\AKTUELLES PROJEKT\MARIA\PROGRAMMCODE\16F84ATEMP.ASM 7888 : Register in operand not in bank 0. Ensure that bank bits are correct. Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\mplink.exe" /p16F84A "16F84ATEMP.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"Maria.cof" /M"Maria.map" /W MPLINK 4.37, Linker Copyright (c) 1998-2010 Microchip Technology Inc. Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000004, length=0x000035c8 Errors : 1 Link step failed. ---------------------------------------------------------------------- Debug build of project `C:\Users\eXecuTe\Daten\Elektronik\Aktuelles Projekt\Maria\Programmcode\Maria.mcp' failed. Language tool versions: MPASMWIN.exe v5.37, mplink.exe v4.37, mplib.exe v4.37 Preprocessor symbol `__DEBUG' is defined. Wed May 23 12:43:20 2012 ---------------------------------------------------------------------- BUILD FAILED Ich denke die 302-Messages kann ich ignorieren. Hab überprüft ob die Bank-Bits richtig gesetzt sind. Unsicher bin ich mir bei den 305-Messages und vor allem macht mir das hier Sorgen: Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000004, length=0x000035c8 Errors : 1 Ich sag schon einmal danke für eure Hilfe! :-) MfG
Berndi schrieb: > Unsicher bin ich mir bei den 305-Messages und vor allem macht mir das > hier Sorgen: > > Error - section '.org_1' can not fit the absolute section. Section > '.org_1' start=0x00000004, length=0x000035c8 > Errors : 1 Dann wird wohl .... > Ich habe ein Programm geschrieben (sehr lang, da ich viel Text > auf einem 2x16 LCD anzeigen lassen will) .... etwas zu viel Text und/oder Programm gewesen sein.
Vielen Dank für deine Antwort. Ich habe das Programm nun mit ein paar Tricks gekürzt und taaadaaaa: es geht! Nochmal vielen Dank und liebe Grüße ;-)
