1 | -------------------------------------------------------------------
2 | -- ASCII HEX TABLE
3 | -- Hex Low Hex Digit
4 | -- Value 0 1 2 3 4 5 6 7 8 9 A B C D E F
5 | ------\----------------------------------------------------------------
6 | --H 2 | SP ! " # $ % & ' ( ) * + , - . /
7 | --i 3 | 0 1 2 3 4 5 6 7 8 9 : ; < = > ?
8 | --g 4 | @ A B C D E F G H I J K L M N O
9 | --h 5 | P Q R S T U V W X Y Z [ \ ] ^ _
10 | -- 6 | ` a b c d e f g h i j k l m n o
11 | -- 7 | p q r s t u v w x y z { | } ~ DEL
12 | -----------------------------------------------------------------------
13 |
14 | LIBRARY IEEE;
15 | USE IEEE.STD_LOGIC_1164.all;
16 | USE IEEE.STD_LOGIC_ARITH.all;
17 | USE IEEE.STD_LOGIC_UNSIGNED.all;
18 |
19 | entity lcd_control is
20 | port
21 | (
22 | trigger,trigger2, clk : in std_logic;
23 | ascii : in std_logic_vector(7 downto 0);
24 | lcd_rs, lcd_e, lcd_rw : out std_logic;
25 | lcd_data : out std_logic_vector(7 downto 0);
26 | lcd_an : out std_logic
27 |
28 | );
29 | end lcd_control;
30 |
31 | architecture behv of lcd_control is
32 |
33 | type state_type is ( START, START_WAIT, FUNC_SET_WAIT, DISP_ON_WAIT,
34 | DROP_E, HOLD,
35 | FUNC_SET, DISP_ON, DISP_CLEAR, MODE_SET,
36 | WAIT_CHAR, DISP_CLEAR_WAIT,
37 | WAIT_TRIGGER_RESET,
38 | CHK_CNT, LINE2, HOME);
39 |
40 | signal state, next_command : state_type;
41 | signal char_cnt : std_logic_vector(5 downto 0);
42 | signal wait_cnt : std_logic_vector(7 downto 0);
43 |
44 | begin
45 |
46 |
47 |
48 |
49 | process(clk)
50 | begin
51 |
52 | if trigger2='1' then -- a switch to turn the lcd on and off
53 | lcd_an<='1';
54 | lcd_rw<='0'; -- setting the rw permenantly to 1
55 | else
56 | lcd_an<='0';
57 | end if;
58 |
59 | state <= START;
60 |
61 | case state is
62 |
63 | when START =>
64 |
65 | lcd_e <= '1';
66 | lcd_rs <= '0';
67 | lcd_data <= X"38"; -- set the lcd to 8 bit lenght
68 | wait_cnt<=X"00";
69 | state <= DROP_E; -- function of DROP_E: just sets lcd_e to '1' and state goes to next_command
70 | next_command <= START_WAIT;
71 |
72 | when START_WAIT => -- waiting for a few msec
73 | if wait_cnt < X"10" then
74 | wait_cnt <= wait_cnt +1;
75 | state <= START_WAIT;
76 | else
77 | state <= FUNC_SET;
78 | wait_cnt <= X"00";
79 | end if;
80 |
81 |
82 |
83 | when FUNC_SET =>
84 | lcd_e <= '1';
85 | lcd_rs <= '0';
86 | lcd_data <= X"38";
87 | state <= DROP_E;
88 | next_command <= FUNC_SET_WAIT;
89 |
90 |
91 | when FUNC_SET_WAIT =>
92 | if wait_cnt < X"10" then
93 | wait_cnt <= wait_cnt +1;
94 | state <= FUNC_SET_WAIT;
95 | else
96 | state <= DISP_ON;
97 | wait_cnt <= X"00";
98 | end if;
99 |
100 |
101 |
102 | when DISP_ON =>
103 | lcd_e <= '1';
104 | lcd_rs <= '0';
105 | lcd_data <= X"0F"; -- set the lcd to Display on, Cursor is displayed, Blinking enable,
106 | state <= DROP_E;
107 | next_command <= DISP_ON_WAIT;
108 |
109 |
110 | when DISP_ON_WAIT =>
111 | if wait_cnt < X"10" then
112 | wait_cnt <= wait_cnt +1;
113 | state <= DISP_ON_WAIT;
114 | else
115 | state <= DISP_CLEAR;
116 | wait_cnt <= X"00";
117 | end if;
118 |
119 |
120 | when DISP_CLEAR =>
121 |
122 | lcd_e <= '1';
123 | lcd_rs <= '0';
124 | lcd_data <= X"01"; -- command: clear the display
125 | wait_cnt <= X"00";
126 | state <= DROP_E;
127 | next_command <= DISP_CLEAR_WAIT;
128 |
129 |
130 |
131 | when DISP_CLEAR_WAIT =>
132 |
133 | if wait_cnt < X"10" then
134 | wait_cnt <= wait_cnt +1;
135 | state <= DISP_CLEAR_WAIT;
136 | else
137 | state <= MODE_SET;
138 | wait_cnt <= X"00";
139 | end if;
140 |
141 | when MODE_SET =>
142 | lcd_e <= '1';
143 | lcd_rs <= '0';
144 | lcd_data <= X"06"; -- Cursor moves right, Display shift enabled.
145 | state <= DROP_E;
146 | next_command <= WAIT_CHAR;
147 |
148 | ---------------- initialization done, Loop of writing begins -------------------------------------------
149 |
150 | -- WAIT_CHAR -> DROP_E -> HOLD -> WAIT_TRIGGER_RESET -> CHK_CNT -> LINE2 -> DROP_E -> HOLD -> |
151 | -- | |
152 | -- ^ -> HOME -> DROP_E -> HOLD -> |
153 | -- | | |
154 | -- | v v
155 | -- |----------------------------------------<<-------------------------------------------|
156 |
157 | -------------------------------------------------------------------------------------------------
158 |
159 | when WAIT_CHAR =>
160 | if trigger = '0' then -- trigger is set to a switch
161 |
162 | lcd_e <= '1';
163 | lcd_rs <= '1';
164 | lcd_data <= ascii; -- ascii is defined through 7 switchs
165 | char_cnt <= char_cnt +1; -- a counter for the written letters
166 | state <= DROP_E;
167 | next_command <= WAIT_TRIGGER_RESET;
168 | else
169 | next_command <= WAIT_CHAR;
170 | end if;
171 |
172 | when WAIT_TRIGGER_RESET => -- loop, waiting for an change at the switch
173 | if trigger = '0' then
174 | state <= WAIT_TRIGGER_RESET;
175 | else
176 | state <= CHK_CNT;
177 | end if;
178 |
179 | when CHK_CNT => -- checking if the first line is full of letters,
180 | if char_cnt = X"10" then
181 | state <= LINE2;
182 | elsif char_cnt = X"20" then
183 | state <= HOME; -- clears the display
184 | else
185 | state <= WAIT_CHAR;
186 | end if;
187 |
188 |
189 | when LINE2 => -- starts writing at the secound line
190 | lcd_e <= '1';
191 | lcd_rs <= '0';
192 | lcd_data <= X"C0"; -- sets the DDRAM-Adress to '1000000'
193 | state <= DROP_E;
194 | next_command <= WAIT_CHAR;
195 |
196 | when HOME =>
197 | lcd_e <= '1';
198 | lcd_rs <= '0';
199 | lcd_data <= X"80"; -- sets the DDRAM-adress to '0000000'
200 | char_cnt <= "000000";
201 | state <= DROP_E;
202 | next_command <= WAIT_CHAR;
203 |
204 | when DROP_E =>
205 | lcd_e <= '1';
206 | state <= HOLD;
207 |
208 | when HOLD =>
209 | state <= next_command;
210 |
211 | end case;
212 |
213 | end process;
214 |
215 |
216 | end behv;
