1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_arith.all;
4 | use ieee.std_logic_unsigned.all;
5 | use ieee.numeric_std.all;
6 |
7 | entity vga_control is
8 | port (
9 | reset, taster : in std_logic;
10 | clk : in std_logic;
11 |
12 | VGA_CLK, -- Should be 25.125 MHz VGA_CLK, Dot clock to DAC
13 | VGA_HS, -- Active Low Horizontal Sync
14 | VGA_VS, -- Active Low Vertical Sync
15 | VGA_BLANK, -- Active Low DAC blanking control
16 | VGA_SYNC : out std_logic; -- Active Low DAC Sync on Green
17 | VGA_R, VGA_G, VGA_B : out std_logic_vector(7 downto 0);
18 | ledtest1, ledtest2, ledtest3 : out std_logic := '0'
19 | );
20 |
21 | end vga_control;
22 |
23 | architecture rtl of vga_control is
24 |
25 | -- Video parameters
26 |
27 | constant HTOTAL : integer := 800;
28 | constant HSYNC : integer := 96;
29 | constant HBACK_PORCH : integer := 48;
30 | constant HACTIVE : integer := 640;
31 | constant HFRONT_PORCH : integer := 16;
32 | constant VTOTAL : integer := 525;
33 | constant VSYNC : integer := 2;
34 | constant VBACK_PORCH : integer := 33;
35 | constant VACTIVE : integer := 480;
36 | constant VFRONT_PORCH : integer := 10;
37 | constant RECTANGLE_HSTART : integer := 100;
38 | constant RECTANGLE_HEND : integer := 540;
39 | constant RECTANGLE_VSTART : integer := 100;
40 | constant RECTANGLE_VEND : integer := 380;
41 |
42 | signal Hcount : std_logic_vector(9 downto 0):= "0000000000"; -- Horizontal position (0 - 800)
43 | signal Vcount : std_logic_vector(9 downto 0):= "0000000000"; -- Vertical position (0 - 524)
44 | signal EndOfLine, EndOfField : std_logic :='0';
45 | signal vga_hblank, vga_hsync,
46 | vga_vblank, vga_vsync : std_logic; -- Sync. signals
47 |
48 | signal rectangle_h, rectangle_v, rectangle : std_logic; -- rectangle area
49 |
50 | begin
51 |
52 | test : process (clk)
53 | begin
54 |
55 | if taster= '1' then
56 | ledtest1<='0';
57 | else
58 | ledtest1<='1';
59 | end if;
60 |
61 | end process test;
62 |
63 |
64 |
65 | HCounter : process (clk)
66 | begin
67 |
68 | if reset = '0' then
69 | Hcount <= (others=> '0');
70 | ledtest2<='1';
71 | elsif (clk'event and clk = '1') then
72 | ledtest2<='0';
73 | if EndOfLine = '1' then
74 | Hcount <= (others=> '0');
75 | else
76 | Hcount <= Hcount + 1;
77 |
78 | end if;
79 | end if;
80 |
81 | end process;
82 |
83 |
84 | VCounter: process (clk)
85 | begin
86 |
87 | if reset = '0' then
88 | Vcount <= (others=> '0');
89 |
90 | elsif (clk'event and clk = '1') then
91 | if EndOfLine = '1' then
92 | if EndOfField = '1' then
93 | Vcount <= (others=> '0');
94 |
95 | else
96 | Vcount <= Vcount + 1;
97 | end if;
98 | end if;
99 | end if;
100 | end process VCounter;
101 |
102 |
103 | HSyncGen : process (clk)
104 | begin
105 | if reset = '1' then
106 | vga_hsync <= '1';
107 | elsif clk'event and clk = '1' then
108 | if EndOfLine = '1' then
109 | vga_hsync <= '1';
110 | elsif Hcount = HSYNC - 1 then
111 | vga_hsync <= '0';
112 | end if;
113 | end if;
114 | end process HSyncGen;
115 |
116 | HBlankGen : process (clk)
117 | begin
118 |
119 | if reset='1' then
120 | vga_hblank <= '1';
121 |
122 | elsif clk'event and clk='1' then
123 |
124 | if Hcount = HSYNC + HBACK_PORCH then
125 | vga_hblank <= '0';
126 | elsif Hcount = HSYNC + HBACK_PORCH + HACTIVE then
127 | vga_hblank <= '1';
128 | end if;
129 |
130 | end if;
131 | end process HBlankGen;
132 |
133 |
134 |
135 | VSyncGen : process (clk)
136 | begin
137 |
138 | if reset='1' then
139 | vga_vsync <= '1';
140 | elsif clk'event and clk = '1' then
141 | if EndOfLine ='1' then
142 | if EndOfField = '1' then
143 | vga_vsync <= '1';
144 | elsif Vcount = VSYNC - 1 then
145 | vga_vsync <= '0';
146 | end if;
147 | end if;
148 | end if;
149 | end process VSyncGen;
150 |
151 |
152 | VBlankGen : process (clk)
153 | begin
154 |
155 | if reset = '1' then
156 | vga_vblank <= '1';
157 | elsif clk'event and clk = '1' then
158 | if EndOfLine = '1' then
159 | if Vcount = VSYNC + VBACK_PORCH - 1 then
160 | vga_vblank <= '0';
161 | elsif Vcount = VSYNC + VBACK_PORCH + VACTIVE - 1 then
162 | vga_vblank <= '1';
163 | end if;
164 | end if;
165 | end if;
166 | end process VBlankGen;
167 |
168 |
169 | RectangleHGen : process (clk)
170 | begin
171 |
172 | if reset = '1' then
173 | rectangle_h <= '1';
174 | elsif clk'event and clk = '1' then
175 | if Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HSTART then
176 | rectangle_h <= '1';
177 | elsif Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HEND then
178 | rectangle_h <= '0';
179 | end if;
180 | end if;
181 | end process RectangleHGen;
182 |
183 |
184 | RectangleVGen : process (clk)
185 | begin
186 | if reset = '1' then
187 | rectangle_v <= '0';
188 | elsif clk'event and clk = '1' then
189 | if EndOfLine = '1' then
190 | if Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VSTART then
191 | rectangle_v <= '1';
192 | elsif Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VEND then
193 | rectangle_v <= '0';
194 |
195 | end if;
196 | end if;
197 | end if;
198 | end process RectangleVGen;
199 |
200 | rectangle <= rectangle_h and rectangle_v;
201 |
202 |
203 |
204 | VideoOut: process (clk)
205 | begin
206 |
207 | if reset = '1' then
208 | VGA_R <= "00000000";
209 | VGA_G <= "00000000";
210 | VGA_B <= "00000000";
211 | elsif clk'event and clk = '1' then
212 |
213 | if rectangle = '1' then
214 | VGA_R <= "11111111";
215 | VGA_G <= "11111111";
216 | VGA_B <= "11111111";
217 | elsif vga_hblank = '0' and vga_vblank ='0' then
218 | VGA_R <= "00000000";
219 | VGA_G <= "00000000";
220 | VGA_B <= "11111111";
221 | else
222 | VGA_R <= "00000000";
223 | VGA_G <= "00000000";
224 | VGA_B <= "00000000";
225 | end if;
226 | end if;
227 | end process VideoOut;
228 |
229 |
230 | vga_clk_gen : PROCESS(clk)--devides 50MHz clock in 2, making it a 25MHz clock
231 | VARIABLE count : INTEGER := 0;
232 | BEGIN
233 |
234 | IF rising_edge(clk) THEN
235 | IF count = 0 THEN
236 | VGA_CLK <= '1'; --1 period of 50MHz high
237 | count := 1;
238 | ELSIF count = 1 THEN
239 | VGA_CLK <= '0';
240 | count := 0;
241 | END IF;
242 | END IF;
243 | END PROCESS vga_clk_gen;
244 |
245 |
246 |
247 | VGA_HS <= not vga_hsync;
248 | VGA_VS <= not vga_vsync;
249 | VGA_SYNC <='0';
250 | VGA_BLANK <= not (vga_hsync or vga_vsync);
251 |
252 | end rtl;
