1 | library IEEE;
2 | use IEEE.std_logic_1164.all;
3 | use IEEE.std_logic_arith.all;
4 | use IEEE.std_logic_unsigned.all;
5 |
6 | entity Spi_Master is
7 | generic (data_width: integer := 16);
8 | Port ( CLK : in std_logic;
9 | RESET : in std_logic;
10 | Datain : in std_logic_vector( data_width-1 downto 0);
11 | SCLK : out std_logic;
12 | MOSI : out std_logic;
13 | MISO : in std_logic;
14 | CS1 : out std_logic); -- Slave Chip Select#1
15 | -- SS : out std_logic_vector (7 downto 0);
16 | end Spi_Master;
17 |
18 | architecture behave of Spi_Master is
19 | signal shreg: std_logic_vector( data_width-1 downto 0);
20 | type states is ( Idle, Data_transfer, Stop);
21 | signal State: states := Idle;
22 | begin
23 | MOSI <= shreg(shreg'left);
24 | SCLK <= CLK
25 | when State = Data_Transfer -- Master clock send to SCLK
26 | else '0';
27 |
28 | process( CLK)
29 | variable Count: integer range 0 to data_width;
30 | begin
31 | if rising_edge( CLK) then
32 | case State is
33 | when Idle =>
34 | CS1 <= '1';
35 | if RESET='1' then
36 | Count := 0; -- Init Data bit counter
37 | shreg <= Datain; -- Load parallel data
38 | CS1 <= '0'; -- Select Slave aktive
39 | State <= Data_Transfer; -- Change state
40 | end if;
41 | when Data_transfer =>
42 | if Count < (data_width-1) then
43 | Count := Count+1;
44 | shreg <= shreg( shreg'left-1 downto 0)& MISO; -- Shift
45 | else
46 | State <= Stop; -- Change state
47 | end if;
48 | when Stop =>
49 | CS1 <= '1'; -- Deselect slave
50 | if RESET ='0' then
51 | State <= Idle;
52 | end if;
53 | end case;
54 | end if; end process;
55 | end behave;
56 | ----------------------Simulation--------------------
57 | library IEEE;
58 | use IEEE.std_logic_1164.ALL;
59 | use IEEE.std_logic_arith.ALL;
60 | use IEEE.std_logic_unsigned.ALL;
61 |
62 | entity tb_Spi_Master is
63 | end tb_Spi_Master;
64 |
65 | architecture RTL of tb_Spi_Master is
66 | component Spi_Master
67 | Port ( CLK : in std_logic;
68 | RESET : in std_logic;
69 | Datain : in std_logic_vector( 15 downto 0);
70 | SCLK : out std_logic;
71 | MOSI : out std_logic;
72 | MISO : in std_logic;
73 | CS1 : out std_logic); -- Slave Chip Select#1
74 | end component;
75 | -----------------------------------------------------
76 | signal CLK : std_logic:= '0';
77 | signal RESET : std_logic;
78 | signal Datain : std_logic_vector( 15 downto 0);
79 | signal SCLK : std_logic := '0';
80 | signal MOSI : std_logic;
81 | signal MISO : std_logic;
82 | signal CS1 : std_logic;
83 | ----------------------------------------------------
84 | signal data_serial : std_logic;
85 | constant T : time:= 10 ns;
86 | ----------------------------------------------------
87 | begin
88 | -- ******************* Port Map ***************
89 | DUT : Spi_Master
90 | port map (CLK => CLK,
91 | RESET => RESET ,
92 | Datain => Datain,
93 | SCLK => SCLK,
94 | MOSI => MOSI,
95 | MISO => MISO,
96 | CS1 => CS1);
97 | -- *********** clk and reset definition ***********
98 | clk <= not clk after T; -- 50 MHz
99 | process
100 | begin
101 | reset <= '0'; wait for T + 10 ns;
102 | reset <= '1'; wait for T + 10 ns;
103 | end process;
104 | -- *********** Generating serial data ************
105 | Datain <= "1010101010101010"; -- 16 Bit
106 | process
107 | begin
108 | for i in 15 downto 0 loop
109 | wait until SCLK = '1' and SCLK'event;
110 | data_serial <= Datain(i);
111 | end loop;
112 | end process;
113 | end RTL;
