1 | #/*
2 | # FreeRTOS V7.1.0 - Copyright (C) 2011 Real Time Engineers Ltd.
3 | #
4 | # ***************************************************************************
5 | # * *
6 | # * If you are: *
7 | # * *
8 | # * + New to FreeRTOS, *
9 | # * + Wanting to learn FreeRTOS or multitasking in general quickly *
10 | # * + Looking for basic training, *
11 | # * + Wanting to improve your FreeRTOS skills and productivity *
12 | # * *
13 | # * then take a look at the FreeRTOS books - available as PDF or paperback *
14 | # * *
15 | # * "Using the FreeRTOS Real Time Kernel - a Practical Guide" *
16 | # * http://www.FreeRTOS.org/Documentation *
17 | # * *
18 | # * A pdf reference manual is also available. Both are usually delivered *
19 | # * to your inbox within 20 minutes to two hours when purchased between 8am *
20 | # * and 8pm GMT (although please allow up to 24 hours in case of *
21 | # * exceptional circumstances). Thank you for your support! *
22 | # * *
23 | # ***************************************************************************
24 | #
25 | # This file is part of the FreeRTOS distribution.
26 | #
27 | # FreeRTOS is free software; you can redistribute it and/or modify it under
28 | # the terms of the GNU General Public License (version 2) as published by the
29 | # Free Software Foundation AND MODIFIED BY the FreeRTOS exception.
30 | # ***NOTE*** The exception to the GPL is included to allow you to distribute
31 | # a combined work that includes FreeRTOS without being obliged to provide the
32 | # source code for proprietary components outside of the FreeRTOS kernel.
33 | # FreeRTOS is distributed in the hope that it will be useful, but WITHOUT
34 | # ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
35 | # FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
36 | # more details. You should have received a copy of the GNU General Public
37 | # License and the FreeRTOS license exception along with FreeRTOS; if not it
38 | # can be viewed here: http://www.freertos.org/a00114.html and also obtained
39 | # by writing to Richard Barry, contact details for whom are available on the
40 | # FreeRTOS WEB site.
41 | #
42 | # 1 tab == 4 spaces!
43 | #
44 | # http://www.FreeRTOS.org - Documentation, latest information, license and
45 | # contact details.
46 | #
47 | # http://www.SafeRTOS.com - A version that is certified for use in safety
48 | # critical systems.
49 | #
50 | # http://www.OpenRTOS.com - Commercial support, development, porting,
51 | # licensing and training services.
52 | #*/
53 |
54 |
55 | #/*************************************************************************
56 | # * Please ensure to read http://www.freertos.org/portLM3Sxxxx_Eclipse.html
57 | # * which provides information on configuring and running this demo for the
58 | # * various Luminary Micro EKs.
59 | # *************************************************************************/
60 |
61 | #+---------------------------------------------------------------------------
62 | #
63 | # Copyright (c) 2010 Anton Gusev aka AHTOXA (HTTP://AHTOXA.NET)
64 | #
65 | # File: makefile
66 | #
67 | # Contents: makefile to build arm Cortex-M3 software with gcc
68 | #
69 | #----------------------------------------------------------------------------
70 |
71 | ############# program name
72 | TARGET = main
73 |
74 | # program version
75 | VER_MAJOR = 0
76 | VER_MINOR = 1
77 |
78 | TOOL = arm-none-eabi-
79 | # TOOL = arm-kgp-eabi-
80 |
81 | OPTIMIZE = -O2
82 | USE_LTO = NO
83 |
84 | # compile options
85 | # MCU = cortex-m3
86 | # Select family
87 | # STM32F10X_LD : STM32 Low density devices
88 | # STM32F10X_LD_VL : STM32 Low density Value Line devices
89 | # CHIP = STM32F10X_MD #: STM32 Medium density devices
90 | # STM32F10X_MD_VL : STM32 Medium density Value Line devices
91 | # STM32F10X_HD : STM32 High density devices
92 | # STM32F10X_HD_VL : STM32 XL-density devices
93 | # STM32F10X_CL : STM32 Connectivity line devices
94 | # STM32F10X_XL : STM32 XL-density devices
95 | # CHIP = STM32F10X_MD
96 |
97 | MCU = cortex-m4
98 | CHIP = STM32F407VG
99 |
100 | #STARTUP = startup_stm32f10x_md.S
101 | STARTUP = startup_$(CHIP)
102 |
103 | RTOS_ROOT=../FreeRTOSV7.1.1
104 | CMSIS_DRIVER_DIR=../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/CMSIS/Include
105 |
106 |
107 | #defines
108 | DEFS = -D$(CHIP)
109 | DEFS += -DVER_MAJOR=$(VER_MAJOR)
110 | DEFS += -DVER_MINOR=$(VER_MINOR)
111 |
112 | ###########################################################
113 | # common part for all my cortex-m3 projects
114 | ###########################################################
115 |
116 | BASE = .
117 | CC = $(TOOL)gcc
118 | CXX = $(TOOL)g++
119 | LD = $(TOOL)g++
120 | AS = $(CC) -x assembler-with-cpp
121 | OBJCOPY = $(TOOL)objcopy
122 | OBJDUMP = $(TOOL)objdump
123 | SIZE = $(TOOL)size -d
124 | FLASHER = openocd
125 | RM = rm -f
126 | CP = cp
127 | MD = mkdir
128 |
129 |
130 | # dirs
131 | SRCDIR = $(BASE)/src
132 | OBJDIR = $(BASE)/obj
133 | EXEDIR = $(BASE)/exe
134 | LSTDIR = $(BASE)/lst
135 | PRJDIR = $(BASE)/prj
136 | BAKDIR = $(BASE)/bak
137 |
138 | #files
139 | HEX = $(EXEDIR)/$(TARGET).hex
140 | BIN = $(EXEDIR)/$(TARGET).bin
141 | AXF = $(EXEDIR)/$(TARGET).axf
142 | ELF = $(EXEDIR)/$(TARGET).elf
143 | MAP = $(LSTDIR)/$(TARGET).map
144 | LSS = $(LSTDIR)/$(TARGET).lss
145 | OK = $(EXEDIR)/$(TARGET).ok
146 |
147 | # linker script (chip dependent)
148 | LD_SCRIPT = $(SRCDIR)/$(CHIP).ld
149 |
150 | # scmRTOS dir
151 | # SCMDIR = ../scmRTOS
152 | # COMMON = ../SamplesCommon
153 |
154 | # source directories (all *.c, *.cpp and *.s files included)
155 | DIRS := $(SRCDIR)
156 | # DIRS += $(COMMON)
157 | DIRS += $(RTOS_ROOT)/Source
158 | DIRS += $(RTOS_ROOT)/Source/portable/GCC/ARM_CM4F
159 | DIRS += $(RTOS_ROOT)/Source/include
160 | # DIRS += ../MyARMLib/STM32/STM32F103_Pinboard_II
161 | # DIRS += $(RTOS_ROOT)/Demo/Common/Minimal
162 | DIRS += $(RTOS_ROOT)/Demo/Common/include
163 | # DIRS += $(RTOS_ROOT)/Demo/Common/ethernet/uIP/uip-1.0/uip
164 | # DIRS += $(RTOS_ROOT)/Source/portable/GCC/ARM_CM3_MPU
165 |
166 | #STM32F1_DISCOVERY_DRIVER_DIR=../MyARMLib/STM32/STM32F4_discovery
167 | DIRS += $(CMSIS_DRIVER_DIR)
168 | DIRS += ../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/CMSIS/Include
169 | # DIRS += ../MyARMLib/STM32/STM32F10x/include
170 | # DIRS += ../MyARMLib/STM32/STM32F10x_StdPeriph_Driver/inc
171 | # DIRS += ../MyARMLib/STM32/STM32F10x_StdPeriph_Driver/src
172 | DIRS += ../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/CMSIS/Device/ST/STM32F4xx/Include
173 | # DIRS += ../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/STM32/STM32F4_discovery
174 | DIRS += ../stm32f4-discovery/Utilities/STM32F4-Discovery
175 | DIRS += ../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/STM32F4xx_StdPeriph_Driver/src
176 | DIRS += ../STM32F4xx_DSP_StdPeriph_Lib_V1.0.0/Libraries/STM32F4xx_StdPeriph_Driver/inc
177 |
178 |
179 | # DIRS += ../MyARMLib/FreeRTOS
180 |
181 | # includes
182 | INCS := $(patsubst %, -I "%", $(DIRS))
183 |
184 | # individual source files
185 | SRCS :=
186 |
187 | #calc obj files list
188 | OBJS := $(SRCS)
189 | OBJS += $(wildcard $(addsuffix /*.cpp, $(DIRS)))
190 | OBJS += $(wildcard $(addsuffix /*.c, $(DIRS)))
191 | OBJS += $(wildcard $(addsuffix /*.S, $(DIRS)))
192 |
193 | #OBJS += $(RTOS_ROOT)/Source/tasks.c
194 | #/port.c
195 |
196 | # OBJS += ../MyARMLib/STM32/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.c
197 | # OBJS += ../MyARMLib/STM32/STM32F10x_StdPeriph_Driver/src/stm32f10x_rcc.c
198 | # OBJS += $(RTOS_ROOT)/Source/tasks.c
199 | # OBJS += $(RTOS_ROOT)/Source/list.c
200 | # OBJS += $(RTOS_ROOT)/Source/timers.c
201 | # OBJS += $(RTOS_ROOT)/Source/queue.c
202 | # OBJS += $(RTOS_ROOT)/Source/tasks.c
203 | # OBJS += $(RTOS_ROOT)/Source/portable/GCC/ARM_CM3/port.c
204 | # OBJS += $(RTOS_ROOT)/Source/portable/MemMang/heap_2.c
205 | OBJS := $(notdir $(OBJS))
206 | OBJS := $(OBJS:.cpp=.o)
207 | OBJS := $(OBJS:.c=.o)
208 | OBJS := $(OBJS:.S=.o)
209 | OBJS := $(patsubst %, $(OBJDIR)/%, $(OBJS))
210 |
211 | #files to archive
212 | ARCFILES = \
213 | $(SRCDIR) \
214 | $(PRJDIR) \
215 | $(SCMDIR) \
216 | $(BASE)/makefile \
217 | $(BASE)/.cproject \
218 | $(BASE)/.project
219 |
220 | # flags
221 | FLAGS = -mcpu=$(MCU) -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=softfp
222 | FLAGS += $(INCS)
223 | FLAGS += -MD
224 | #-DGCC_ARMCM3
225 | FLAGS += $(DEFS) -DUSE_STDPERIPH_DRIVER
226 | FLAGS += -Wa,-adhlns=$(addprefix $(LSTDIR)/, $(notdir $(addsuffix .lst, $(basename $<))))
227 |
228 | AFLAGS = $(FLAGS)
229 |
230 | CFLAGS = $(FLAGS)
231 | CFLAGS += $(OPTIMIZE)
232 | CFLAGS += -std=gnu99
233 | CFLAGS += -D GCC_ARMCM3
234 | CFLAGS += -g
235 | CFLAGS += -ffunction-sections -fdata-sections
236 | # CFLAGS += -Wall -Wextra
237 | # CFLAGS += -Wimplicit -Wcast-align -Wpointer-arith -Wredundant-decls
238 | # CFLAGS += -Wshadow -Wcast-qual -Wcast-align -Wnested-externs -pedantic
239 |
240 | CXXFLAGS = $(FLAGS)
241 | CXXFLAGS += $(OPTIMIZE)
242 | CXXFLAGS += -g
243 | CXXFLAGS += -fno-exceptions -fno-rtti
244 | CXXFLAGS += -ffunction-sections -fdata-sections
245 | CXXFLAGS += -fno-threadsafe-statics
246 | CXXFLAGS += -funsigned-bitfields -fshort-enums
247 | CXXFLAGS += -Wall -Wextra
248 | CXXFLAGS += -Winline
249 | CXXFLAGS += -Wpointer-arith -Wredundant-decls
250 | CXXFLAGS += -Wshadow -Wcast-qual -Wcast-align -pedantic
251 |
252 | LD_FLAGS = -mcpu=$(MCU)
253 | LD_FLAGS += -mthumb
254 | LD_FLAGS += -nostartfiles
255 | LD_FLAGS += -Wl,-Map="$(MAP)",--cref
256 | LD_FLAGS += -Wl,--gc-sections
257 | LD_FLAGS += -T$(LD_SCRIPT)
258 |
259 | ifeq ($(USE_LTO),YES)
260 | CFLAGS += -flto
261 | CXXFLAGS += -flto
262 | LD_FLAGS += -flto $(OPTIMIZE)
263 | endif
264 |
265 | #openocd command-line
266 |
267 | # debug level (d0..d3)
268 | oocd_params = -d3
269 | # interface and board/target settings (using the OOCD target-library here)
270 | # oocd_params += -c "fast enable"
271 | oocd_params += -f interface/arm-usb-ocd.cfg
272 | oocd_params += -f board/stm32f10x_128k_eval.cfg
273 | oocd_params += -c init -c targets
274 | oocd_params_program = $(oocd_params)
275 | # commands to prepare flash-write
276 | oocd_params_program += -c "halt"
277 | # flash-write and -verify
278 | oocd_params_program += -c "flash write_image erase $(ELF)"
279 | oocd_params_program += -c "verify_image $(ELF)"
280 | # reset target
281 | oocd_params_program += -c "reset run"
282 | # terminate OOCD after programming
283 | oocd_params_program += -c shutdown
284 |
285 | oocd_params_reset = $(oocd_params)
286 | oocd_params_reset += -c "reset run"
287 | oocd_params_reset += -c shutdown
288 |
289 | .SILENT :
290 |
291 | .PHONY: all start dirs build clean program reset archive
292 |
293 | ############# targets
294 |
295 | all : start dirs $(AXF) $(ELF) $(HEX) $(BIN) $(LSS) $(OK)
296 |
297 | build: clean all
298 |
299 | start:
300 | @echo --- building $(TARGET) $(OBJS)
301 |
302 | $(LSS): $(ELF) makefile
303 | @echo --- making asm-lst...
304 | # @$(OBJDUMP) -dStC $(ELF) > $(LSS)
305 | @$(OBJDUMP) -dC $(ELF) > $(LSS)
306 |
307 | $(OK): $(ELF)
308 | @$(SIZE) $(ELF)
309 | @echo "Errors: none"
310 |
311 | $(AXF): $(OBJS) $(STARTUP).o makefile
312 | @echo --- linking... axf
313 | $(LD) $(OBJS) $(STARTUP).o $(LIBS) $(LD_FLAGS) -o "$(AXF)"
314 |
315 | $(ELF): $(OBJS) makefile
316 | @echo --- linking...
317 | $(LD) $(OBJS) $(LIBS) $(LD_FLAGS) -o "$(ELF)"
318 |
319 | $(HEX): $(ELF)
320 | @echo --- make hex...
321 | @$(OBJCOPY) -O ihex $(ELF) $(HEX)
322 |
323 | $(BIN): $(ELF)
324 | @echo --- make binary...
325 | @$(OBJCOPY) -O binary $(ELF) $(BIN)
326 |
327 | program: $(ELF)
328 | @echo "Programming with OPENOCD"
329 | $(FLASHER) $(oocd_params_program)
330 |
331 | reset:
332 | @echo Resetting device
333 | $(FLASHER) $(oocd_params_reset)
334 |
335 | VPATH := $(DIRS)
336 |
337 | $(OBJDIR)/%.o: %.cpp makefile
338 | @echo --- compiling $<...
339 | $(CXX) -c $(CXXFLAGS) -o $@ $<
340 |
341 | $(OBJDIR)/%.o: %.c makefile
342 | @echo --- compiling $<...
343 | $(CC) -c $(CFLAGS) -o $@ $<
344 |
345 | $(OBJDIR)/%.o: %.S makefile
346 | @echo --- assembling $<...
347 | $(AS) -c $(AFLAGS) -o $@ $<
348 |
349 | $(OBJDIR)/%.o: %.s makefile
350 | @echo --- assembling $<...
351 | $(AS) -c $(AFLAGS) -o $@ $<
352 |
353 |
354 | dirs: $(OBJDIR) $(EXEDIR) $(LSTDIR) $(BAKDIR)
355 |
356 | $(OBJDIR):
357 | -@$(MD) $(OBJDIR)
358 |
359 | $(EXEDIR):
360 | -@$(MD) $(EXEDIR)
361 |
362 | $(LSTDIR):
363 | -@$(MD) $(LSTDIR)
364 |
365 | $(BAKDIR):
366 | -@$(MD) $(BAKDIR)
367 |
368 | clean:
369 | -@$(RM) $(OBJDIR)/*.d 2>/dev/null
370 | -@$(RM) $(OBJDIR)/*.o 2>/dev/null
371 | -@$(RM) $(LSTDIR)/*.lst 2>/dev/null
372 | -@$(RM) $(ELF)
373 | -@$(RM) $(HEX)
374 | -@$(RM) $(LSS)
375 | -@$(RM) $(MAP)
376 |
377 | archive:
378 | @echo --- archiving...
379 | 7z a $(BAKDIR)/$(TARGET)_`date +%Y-%m-%d,%H-%M-%S` $(ARCFILES)
380 | @echo --- done!
381 |
382 | # dependencies
383 | ifeq (,$(findstring build,$(MAKECMDGOALS)))
384 | ifeq (,$(findstring clean,$(MAKECMDGOALS)))
385 | ifeq (,$(findstring dirs,$(MAKECMDGOALS)))
386 | -include $(wildcard $(OBJDIR)/*.d)
387 | endif
388 | endif
389 | endif
