1 | #undef DEBUG
2 |
3 | #include "EtherShield.h"
4 |
5 | // please modify the following three lines. mac and ip have to be unique
6 | // in your local area network. You can not have the same numbers in
7 | // two devices:
8 | static uint8_t mymac[6] = { 0x54,0x55,0x58,0x10,0x20,0x35};
9 | static uint8_t myip[4] = { 192,168,1,98};
10 |
11 | // listen port for tcp/www (max range 1-254)
12 | #define MYWWWPORT 80
13 |
14 | #define BUFFER_SIZE 800
15 | static uint8_t buf[BUFFER_SIZE+1];
16 | #define STR_BUFFER_SIZE 22
17 | static char strbuf[STR_BUFFER_SIZE+1];
18 |
19 | EtherShield es=EtherShield();
20 |
21 | uint16_t http200ok(void)
22 | {
23 | return(es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n")));
24 | }
25 |
26 | uint16_t http404(void)
27 | {
28 | return(es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 404 OK\r\nContent-Type: text/html\r\n\r\n")));
29 | }
30 |
31 | // prepare the webpage by writing the data to the tcp send buffer
32 | uint16_t print_webpage(uint8_t *buf)
33 | {
34 | uint16_t plen;
35 | plen=http200ok();
36 | plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<html><body><h1>Error 404</h1><p>Diese Seite existiert nicht</body></html>"));
37 |
38 | return(plen);
39 | }
40 |
41 |
42 | #define CMDBUF 50
43 |
44 | int16_t process_request(char *str)
45 | {
46 | int8_t r=-1;
47 | int8_t i = 0;
48 | char clientline[CMDBUF];
49 | int index = 0;
50 | int plen = 0;
51 |
52 | #ifdef DEBUG
53 | // Serial.println( str );
54 | #endif
55 |
56 | char ch = str[index];
57 |
58 | while( ch != ' ' && index < CMDBUF) {
59 | clientline[index] = ch;
60 | index++;
61 | ch = str[index];
62 | }
63 | clientline[index] = '\0';
64 |
65 | #ifdef DEBUG
66 | Serial.println( clientline );
67 | #endif
68 |
69 | // convert clientline into a proper
70 | // string for further processing
71 | String urlString = String(clientline);
72 |
73 | // extract the operation
74 | String op = urlString.substring(0,urlString.indexOf(' '));
75 |
76 | // we're only interested in the first part...
77 | urlString = urlString.substring(urlString.indexOf('/'), urlString.indexOf(' ', urlString.indexOf('/')));
78 |
79 | // put what's left of the URL back in client line
80 | urlString.toCharArray(clientline, CMDBUF);
81 |
82 | // get the first two parameters
83 | char *pin = strtok(clientline,"/");
84 | char *value = strtok(NULL,"/");
85 |
86 | // this is where we actually *do something*!
87 | char outValue[10] = "MU";
88 | //outValue = "MU";
89 | // String jsonOut = String();
90 | char jsonOut[50];
91 |
92 | if(pin != NULL){
93 | if(value != NULL){
94 |
95 | // set the pin value
96 | #ifdef DEBUG
97 | Serial.println("setting pin");
98 | #endif
99 |
100 | // select the pin
101 | int selectedPin = pin[0] -'0';
102 | #ifdef DEBUG
103 | Serial.println(selectedPin);
104 | #endif
105 |
106 | // set the pin for output
107 | pinMode(selectedPin, OUTPUT);
108 |
109 | // determine digital or analog (PWM)
110 | if(strncmp(value, "HIGH", 4) == 0 || strncmp(value, "LOW", 3) == 0){
111 |
112 | // digital
113 | #ifdef DEBUG
114 | Serial.println("digital");
115 | #endif
116 |
117 | if(strncmp(value, "HIGH", 4) == 0){
118 | #ifdef DEBUG
119 | Serial.println("HIGH");
120 | #endif
121 | digitalWrite(selectedPin, HIGH);
122 | }
123 |
124 | if(strncmp(value, "LOW", 3) == 0){
125 | #ifdef DEBUG
126 | Serial.println("LOW");
127 | #endif
128 | digitalWrite(selectedPin, LOW);
129 | }
130 |
131 | } else {
132 |
133 | // analog
134 | #ifdef DEBUG
135 | Serial.println("analog");
136 | #endif
137 |
138 | // get numeric value
139 | int selectedValue = atoi(value);
140 | #ifdef DEBUG
141 | Serial.println(selectedValue);
142 | #endif
143 |
144 | analogWrite(selectedPin, selectedValue);
145 |
146 | }
147 | // return status
148 | return( http200ok() );
149 |
150 | } else {
151 |
152 | // read the pin value
153 | #ifdef DEBUG
154 | Serial.println("reading pin");
155 | #endif
156 |
157 | // determine analog or digital
158 | if(pin[0] == 'a' || pin[0] == 'A'){
159 |
160 | // analog
161 | int selectedPin = pin[1] - '0';
162 |
163 | #ifdef DEBUG
164 | Serial.println(selectedPin);
165 | Serial.println("analog");
166 | #endif
167 |
168 | sprintf(outValue,"%d",analogRead(selectedPin));
169 |
170 | #ifdef DEBUG
171 | Serial.println(outValue);
172 | #endif
173 |
174 | } else if(pin[0] != NULL) {
175 |
176 | // digital
177 | int selectedPin = pin[0] - '0';
178 |
179 | #ifdef DEBUG
180 | Serial.println(selectedPin);
181 | Serial.println("digital");
182 | #endif
183 |
184 | pinMode(selectedPin, INPUT);
185 |
186 | int inValue = digitalRead(selectedPin);
187 |
188 | if(inValue == 0){
189 | sprintf(outValue,"%s","LOW");
190 | //sprintf(outValue,"%d",digitalRead(selectedPin));
191 | }
192 |
193 | if(inValue == 1){
194 | sprintf(outValue,"%s","HIGH");
195 | }
196 |
197 | #ifdef DEBUG
198 | Serial.println(outValue);
199 | #endif
200 | }
201 |
202 | // assemble the json output
203 | sprintf( jsonOut, "%s", outValue );
204 | #ifdef DEBUG
205 | Serial.println( jsonOut );
206 | #endif
207 | // return value
208 | plen=http200ok();
209 | plen=es.ES_fill_tcp_data(buf,plen,jsonOut);
210 | return(plen);
211 | }
212 | } else {
213 |
214 | // error
215 | #ifdef DEBUG
216 | Serial.println("erroring");
217 | #endif
218 | plen = http404();
219 | }
220 |
221 | return plen;
222 | }
223 |
224 |
225 |
226 | void setup(){
227 | // Init SPI
228 | es.ES_enc28j60SpiInit();
229 |
230 | // initialize enc28j60
231 | es.ES_enc28j60Init(mymac); //, 8);
232 |
233 | //init the ethernet/ip layer:
234 | es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
235 |
236 | #ifdef DEBUG
237 | Serial.begin(19200);
238 | Serial.println("ENC28J60 RESTduino");
239 |
240 | Serial.print( "ENC28J60 version " );
241 | Serial.println( es.ES_enc28j60Revision(), HEX);
242 | if( es.ES_enc28j60Revision() <= 0 )
243 | Serial.println( "Failed to access ENC28J60");
244 | #endif
245 |
246 | #ifdef DEBUG
247 | Serial.println("Ready");
248 | #endif
249 |
250 | }
251 |
252 | void loop(){
253 | uint16_t plen, dat_p;
254 | int8_t cmd;
255 |
256 | while(1) {
257 | // read packet, handle ping and wait for a tcp packet:
258 | dat_p=es.ES_packetloop_icmp_tcp(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
259 |
260 | /* dat_p will be unequal to zero if there is a valid http get */
261 | if(dat_p==0){
262 | // no http request
263 | continue;
264 | }
265 |
266 | // tcp port 80 begin
267 | if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
268 | // head, post and other methods:
269 | dat_p = print_webpage(buf);
270 | goto SENDTCP;
271 | }
272 |
273 | // just one web page in the "root directory" of the web server
274 | if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
275 | #ifdef DEBUG
276 | Serial.println("GET / request");
277 | #endif
278 | dat_p=print_webpage(buf);
279 | goto SENDTCP;
280 | }
281 | dat_p = process_request((char *)&(buf[dat_p+4]));
282 |
283 | SENDTCP:
284 |
285 | es.ES_www_server_reply(buf,dat_p); // send web page data
286 | // tcp port 80 end
287 | }
288 |
289 | }
