1 | /*******************************************************************************
2 | *
3 | * MODULE : main.c
4 | *
5 | * COMPILER : TI 4.10
6 | *
7 | * LANGUAGE : ANSI-C
8 | *
9 | * DESCRIPTION : (fill in a detailed description of the module’s
10 | * function here).
11 | *
12 | * SYSTEM : MSP430G2553
13 | *
14 | * AUTHOR :
15 | *
16 | * HISTORY :
17 | *
18 | *******************************************************************************/
19 |
20 | /*
21 | * EA DOGM162E-A MSP430G2553
22 | * __________ __________
23 | * | | | |
24 | * | RS |----------------| P1.3 |
25 | * | CSB |----------------| P1.4 |
26 | * | | | |
27 | * | | | |
28 | * | | | |
29 | * | | | |
30 | * | D6 |----------------| P1.5 |
31 | * | D7 |----------------| P1.7 |
32 | * |__________| |__________|
33 | *
34 | * Angeschlossen am Display
35 | * 3,3V = D5, D4, D3, D2, D1, D0, E, /Reset, RW, Vin (Pin 25), Vdd
36 | * GND = Vss, PSB
37 | */
38 |
39 | /*******************************************************************************
40 | * INCLUDE SECTION
41 | *******************************************************************************/
42 | /*
43 | * ======== Standard MSP430 includes ========
44 | */
45 | #include <msp430.h>
46 | //#include <ti/mcu/msp430/csl/CSL.h>
47 | #include <stdint.h>
48 | #include <stdio.h>
49 |
50 | /*******************************************************************************
51 | * DEFINE AND MACRO SECTION
52 | *******************************************************************************/
53 |
54 | /*******************************************************************************
55 | * GLOBAL VARIABLES SECTION
56 | *******************************************************************************/
57 |
58 | /*******************************************************************************
59 | * FUNCTION SECTION
60 | *******************************************************************************/
61 | void lcd_write(char command, char daten);
62 |
63 | void delay_30us(void);
64 | void delay_50ms(void);
65 | void delay_2ms(void);
66 | void delay_200ms(void);
67 | void delay_100ms(void);
68 | void init_msp(void); // Initialize MSP430 2553
69 | void dogm_init5V(void); // Initialize LCD
70 | void dogm_init3V(void); // Initialize LCD
71 | void dogm_putc(char); // Write character to display
72 | void dogm_puts(char *); // Write string to display
73 | void dogm_gotoxy(uint8_t, uint8_t); // Go to position
74 |
75 | /*******************************************************************************
76 | * Function name : void main(void)
77 | * return : void
78 | * arg1 : void
79 | * Author :
80 | * History : date and event
81 | * Description : none
82 | * Notes : none
83 | *******************************************************************************/
84 | void main(void){
85 | //CSL_init();
86 | init_msp();
87 | volatile unsigned int i; // Use volatile to prevent removal
88 | volatile unsigned int k;
89 |
90 | P1OUT |= BIT0; //LED ON;
91 | //Init char buffer for text message
92 | char buffer[16]=" ";
93 | unsigned int loop = 0;
94 |
95 | // initialise Display
96 | dogm_init3V();
97 | dogm_puts("Hallo Welt !");
98 | //Loop to count up a number on second display line
99 | while(1){
100 | loop++;
101 | P1OUT ^= BIT0; // toggle LED
102 |
103 | sprintf(buffer, "Loop %d", loop);
104 | dogm_gotoxy(0, 1);
105 | dogm_puts(buffer);
106 |
107 | // Verzögerung um etwas auf dem Display zu sehen...
108 | for (k = 0; k < 100; k++){
109 | for (i = 0; i < 100; i++);
110 | }
111 | }
112 | }
113 |
114 | // ************************************************************
115 | // INIT DOGM162 Functions
116 | //************************************************************
117 |
118 | void dogm_init5V(void)
119 | {
120 | delay_200ms(); // 200ms delay
121 |
122 | lcd_write(0x38,0); // switch back to instrcution table 0
123 | delay_30us(); // 30us delay
124 |
125 | lcd_write(0x39, 0); // 8-bit modus
126 | delay_30us(); // 30us delay
127 |
128 | lcd_write(0x1C, 0); // 2 line LCD
129 | delay_30us(); // 30us delay
130 |
131 | lcd_write(0x74, 0); // Contrast Set: C3=1, C2=C1=C0=0
132 | delay_30us(); // 30us delay
133 |
134 | lcd_write(0x52, 0); // booster off
135 | delay_30us(); // 30us delay
136 |
137 | lcd_write(0x69, 0); // voltage follower and gain
138 | delay_2ms(); // 30us delay
139 |
140 | lcd_write(0x0F, 0); // display, cursors and blink ON
141 | delay_30us(); // 30us delay
142 |
143 | lcd_write(0x01, 0); // delete display
144 | delay_50ms(); // 50ms delay
145 | }
146 |
147 | void dogm_init3V(void)
148 | {
149 | delay_200ms(); // 200ms delay
150 |
151 | lcd_write(0x39,0); // 8-bit modus
152 | delay_30us(); // 30us delay
153 |
154 | lcd_write(0x14, 0); // 2 line LCD
155 | delay_30us(); // 30us delay
156 |
157 | lcd_write(0x55, 0); // booster on
158 | delay_30us(); // 30us delay
159 |
160 | lcd_write(0x6D, 0); // voltage follower and gain
161 | delay_30us(); // 30us delay
162 |
163 | lcd_write(0x78, 0); // Contrast Set: C3=1, C2=C1=C0=0
164 | delay_30us(); // 30us delay
165 |
166 | lcd_write(0x38, 0); // switch back to instrcution table 0
167 | delay_2ms(); // 30us delay
168 |
169 | lcd_write(0x0F, 0); // display, cursors and blink ON
170 | delay_30us(); // 30us delay
171 |
172 | lcd_write(0x01, 0); // delete display, cursor @ home
173 | delay_50ms(); // 50ms delay
174 |
175 | lcd_write(0x06, 0); // cursor auto increment
176 | delay_30us(); // 30us delay
177 | }
178 |
179 | void lcd_write(char command, char daten)
180 | {
181 | volatile uint8_t i;
182 |
183 |
184 | if (daten==0){
185 | P1OUT &= ~(BIT3); // RS = LOW, es handelt sich um ein Kommando
186 | }
187 |
188 | if (daten==1){
189 | P1OUT |= BIT3; // RS = HIGH, es handelt sich um Daten
190 | }
191 |
192 | P1OUT &= ~BIT4; // /ChipSelect enable, LCD is listening
193 |
194 | UCB0TXBUF = command;
195 |
196 | while (!(IFG2 & UCB0TXIFG)); // Wait for TX to finish (NOT WORKING)!
197 |
198 | //delay to make sure all data transimmte during cs on, works for 256 kbps
199 | __delay_cycles( 30UL );
200 |
201 | P1OUT |= BIT4; // /CS disable, LCD not anymore listening
202 | }
203 |
204 |
205 | // ************************************************************
206 | // INIT MSP430F2553
207 | // ************************************************************
208 |
209 | void init_msp(void){
210 | /* Stop watchdog timer from timing out during initial start-up. */
211 | WDTCTL = WDTPW + WDTHOLD;
212 | /*Basic Clock System Control 2*/
213 | BCSCTL2 = SELM_0 + DIVM_0 + DIVS_0;
214 |
215 | if (CALBC1_1MHZ != 0xFF) {
216 | /* Follow recommended flow. First, clear all DCOx and MODx bits. Then
217 | * apply new RSELx values. Finally, apply new DCOx and MODx bit values.
218 | */
219 | DCOCTL = 0x00;
220 | BCSCTL1 = CALBC1_1MHZ; /* Set DCO to 1MHz */
221 | DCOCTL = CALDCO_1MHZ;
222 | }
223 | BCSCTL1 |= XT2OFF + DIVA_0;
224 | BCSCTL3 = XT2S_0 + LFXT1S_0 + XCAP_1;
225 | /* Disable USCI */
226 | UCB0CTL1 |= UCSWRST;
227 | UCB0CTL0 = UCCKPL + UCMSB + UCMST + UCMODE_0 + UCSYNC;
228 | UCB0CTL1 = UCSSEL_2 + UCSWRST;
229 | /* Bit Rate Control Register 0 */
230 | UCB0BR0 = 4; //256kbps
231 | /* Enable USCI */
232 | UCB0CTL1 &= ~UCSWRST;
233 | /* Port 1 Output Register */
234 | P1OUT = 0;
235 | /* Port 1 Port Select Register */
236 | P1SEL = BIT5 + BIT7;
237 | /* Port 1 Port Select 2 Register */
238 | P1SEL2 = BIT5 + BIT7;
239 | /* Port 1 Direction Register */
240 | P1DIR = BIT0 + BIT2 + BIT3 + BIT4;
241 | /* Port 1 Interrupt Edge Select Register */
242 | P1IES = 0;
243 | /* Port 1 Interrupt Flag Register */
244 | P1IFG = 0;
245 | /* Port 2 Interrupt Edge Select Register */
246 | P2IES = 0;
247 | /* Port 2 Interrupt Flag Register */
248 | P2IFG = 0;
249 | __bis_SR_register(GIE);
250 |
251 | }
252 |
253 | // ************************************************************
254 | // Write single character to display
255 | // ************************************************************
256 |
257 | void dogm_putc(char c)
258 | {
259 | lcd_write(c, 1);
260 | }
261 |
262 |
263 | // ************************************************************
264 | // Write string to display
265 | // ************************************************************
266 |
267 | void dogm_puts(char * str)
268 | {
269 | while(*str != '\0')
270 | dogm_putc(*str++);
271 | }
272 |
273 |
274 | // ************************************************************
275 | // Go to position xy
276 | // ************************************************************
277 |
278 | void dogm_gotoxy(uint8_t x, uint8_t y)
279 | {
280 | uint8_t addr;
281 |
282 | addr = (y * 0x40) + x;
283 | lcd_write(0x80 | addr, 0);
284 | }
285 |
286 | void delay_30us(void)
287 | {
288 | __delay_cycles( 50UL );
289 | }
290 |
291 |
292 | void delay_2ms(void)
293 | {
294 | __delay_cycles( 2000UL );
295 | }
296 |
297 |
298 | void delay_50ms(void)
299 | {
300 | __delay_cycles( 50000UL );
301 | }
302 |
303 |
304 | void delay_200ms(void)
305 | {
306 | __delay_cycles( 200000UL );
307 | }
308 |
309 | void delay_100ms(void)
310 | {
311 | __delay_cycles( 100000UL );
312 | }
313 |
314 | /*******************************************************************************
315 | * END OF FILE
316 | *******************************************************************************/
