EEPROM beim Atmega168 ärgert mich!
Gast #2796504
Ich habe ein Programm für ein PWM-Modul geschrieben, bei dem verschedene
Lernwerte im EEPROM gesichert werden sollen. Dazu benutze ich die
AVR-GCC-EEPROM-Bibliothek.
Das sind die EEPROM Variablen und die enstprechenden SRAM Daten:
uint16_t *ee_pwm_value = (uint16_t*) 0x01;// = {0,63,127,127,195,195,195,195,255,255,255,255,255,255,255,255};
uint16_t *ee_pwm_freq = (uint16_t*) 0x21;
uint16_t *ee_water_value = (uint16_t*) 0x25;
uint16_t pwm_value[16] = {0,255,511,511,786,786,786,786,1023,1023,1023,1023,1023,1023,1023,1023}; //preset for four concrete stages
uint16_t pwm_freq = 32000;
uint16_t water_value = 65;
Diese Funktion liest die Daten aus dem EEPROM und prüft sie auf
Plausibilitat:
void load_pwm_values(void){
  uint16_t temp_pwm_value[16];
  eeprom_read_block(temp_pwm_value,ee_pwm_value,sizeof(pwm_value));
  if(test_eeprom_string(temp_pwm_value,sizeof(pwm_value))){
    for(i=0;i<16;i++){
      pwm_value[i] = temp_pwm_value[i];
  }else{
    pwm_value[0] = 0;
    pwm_value[1] = 255;
    pwm_value[2] = 511;
    pwm_value[3] = 511;
    pwm_value[4] = 786;
    pwm_value[5] = 786;
    pwm_value[6] = 786;
    pwm_value[7] = 786;
    pwm_value[8] = 1023;
    pwm_value[9] = 1023;
    pwm_value[10] = 1023;
    pwm_value[11] = 1023;
    pwm_value[12] = 1023;
23
    pwm_value[13] = 1023;
24
    pwm_value[14] = 1023;
25
    pwm_value[15] = 1023;
26
27
  uint16_t temp_pwm_freq = eeprom_read_word(ee_pwm_freq);
28
  if(temp_pwm_freq<32768){
29
    pwm_freq = temp_pwm_freq;
30
  }else{
31
    pwm_freq = 32768;
32
33
  uint8_t temp_water_value = eeprom_read_word(ee_water_value);
34
  if(temp_water_value<101){
35
    water_value = temp_water_value;
36
  }else{
37
    water_value = 65;
38
39
40
41
Diese Funktion schreibt die alktuellen Werte in das EEPROM:
void save_pwm_values(void){ // write pwm_values into eeprom if they changed ;)
  uint16_t temp[16];
  eeprom_read_block(temp,ee_pwm_value,16);
  //_delay_ms(5);
  uint16_t temp_freq = eeprom_read_word(ee_pwm_freq);
  //_delay_ms(5);
  //_delay_ms(5);
  if(!compare_string(temp,pwm_value,16)){
    eeprom_write_block(pwm_value,ee_pwm_value,(size_t) 16);
    //_delay_ms(5);
  if(temp_freq != pwm_freq){
    eeprom_write_word(ee_pwm_freq,pwm_freq);
    //_delay_ms(5);
  if(temp_water_value != water_value){
    eeprom_write_word(ee_water_value,water_value);
    //_delay_ms(5);
Kommentiere ich bei
save_pwm_values()
 einzelne eeprom-Funktionen aus, kompiliert das Programm fehlerfrei,
wenn ich aber alles drin habe, kommt mehrfach - jedoch für mich nicht
nachvollziehbar dieser fehler:
Error: R_AVR_13_PCREL against symbol `__eerd_block_m168' defined in
.text.avr-libc section in c:/program files/atmel/avr studio 5.0/avr
toolchain/bin/../lib/gcc/avr/4.5.1/../../../../avr/lib/avr5\libc.a(eerd_
block_atmega168.o)
F:\Documents\AVRStudioFiles\PWM_V1.2\PWM_V1.2\Debug/.././PWM_V1.2.c
Ich benutze AVR-Studio5 und das aktuelle WinAVR. Weder im Datenblatt
noch im GCC-Tutorial habe ich irgendeine Lösung gefunden und ich glaube
nicht, dass es ein Bug im GCC ist.
Ich danke euch schonmal für eure Hilfe.
Gast #2797204
Klaus Wachtler schrieb:
> 1. Fehlt da was in der Fehlermeldung?
> z.B. ein "relocation truncated to fit"
Nein, die Fehlermeldung habe ich direkt aus dem Studio rauskopiert.
> 2. Hilft vielleicht ein Hinzufügen der math-lib?
Nein, falls du damit die math.h meinst, nicht.
> 3.
> http://www.avrfreaks.net/index.php?name=PNphpBB2&f...
Das hat mir 'weitergeholfen'. Ich habe die in der Fehlermeldung
angegebene libc.a mit gelinked (das schreibt man sicher anders). Jetzt
geht's.
Danke Klaus.
#2797230
Die math.h wird per #include beim Compilieren eingefügt.
Ich sprach dagegen vom Linken, dort ist das eine libm.a, die dazu
gelinkt werden kann.
Das geht je nach Umgebung z.B. durch Anklicken in der IDE irgendwo bei
den Linkeroptionen oder auf Kommandozeilenebene durch die Option -lm.
Bei Verwendung eines Makefiles halt irgendwo bei den Linkeroptionen, so
daß -lm an den Linker mit übergeben wird.
Gast #2798148
Es gibt diesen fehler jetzt nichtmehr.
Aber ich habe nochmal eine (vermutlich dämliche) Frage:
Lege ich eine Variable im EEPROM mit
uint16_t variable EEMEM;
 an, wird die EEPROM Speicherzelle dann schon geschrieben oder nur der
Speicherort gemerkt?
