1 | // The board.h header file defines which IO ports pheripherals like
2 | // Switches and LEDs are connected to.
3 | #include "../board.h"
4 |
5 | // Setup for different compilers
6 | #include "../avr_compiler.h"
7 |
8 | // ADC Drivers
9 | #include "../adc_driver.h"
10 |
11 | // Defines what you want to connect to the ADC.
12 | // Light sensor (XMEGA-A1-Xplained)
13 | #define ADC_INPUT ADC_CH_MUXPOS_PIN3_gc
14 | //#define ADC_INPUT
15 |
16 | //NTC
17 | //#define ADC_INPUT ADC_CH_MUXPOS_PIN0_gc
18 |
19 | volatile uint16_t ADC_result;
20 |
21 | int main( void )
22 | {
23 | // Variable for use when we read the result from an ADC channel
24 | int8_t offset;
25 |
26 | LEDPORT.DIR = 0xFF; //Set as ouput, the 8 MSB of the result is output here
27 | LEDPORT.OUT = 0xFF; //Default off for LED
28 |
29 | // ntc_enable(); //Pulls a pin low to enable the NTC.
30 |
31 | /* Move stored calibration values to ADC B */
32 | ADC_CalibrationValues_Load(&ADCA);
33 |
34 |
35 |
36 | /* Set up ADC B to have signed conversion mode and 12 bit resolution. */
37 | ADC_ConvMode_and_Resolution_Config(&ADCA, ADC_ConvMode_Signed, ADC_RESOLUTION_8BIT_gc);
38 |
39 | // The ADC has different voltage reference options, controlled by the REFSEL bits in the
40 | // REFCTRL register. Here the internal reference is selected
41 | ADC_Reference_Config(&ADCA,ADC_REFSEL_INT1V_gc);
42 |
43 | // The clock into the ADC decide the maximum sample rate and the conversion time, and
44 | // this is controlled by the PRESCALER bits in the PRESCALER register. Here, the
45 | // Peripheral Clock is divided by 8 ( gives 250 KSPS with 2Mhz clock )
46 | ADC_Prescaler_Config(&ADCA, ADC_PRESCALER_DIV8_gc);
47 |
48 | // The used Virtual Channel (CH0) must be set in the correct mode
49 | // In this task we will use single ended input, so this mode is selected
50 |
51 | /* Setup channel 0 to have single ended input. */
52 | ADC_Ch_InputMode_and_Gain_Config(&ADCA.CH0,
53 | ADC_CH_INPUTMODE_SINGLEENDED_gc,
54 | ADC_CH_GAIN_1X_gc);
55 |
56 | //ADCA.CH0.MUXCTRL = ADC_CH_MUXINT_SCALEDVCC_gc;
57 | // Setting up the which pins to convert.
58 | // Note that the negative pin is internally connected to ground
59 | ADC_Ch_InputMux_Config(&ADCA.CH0, ADC_INPUT, ADC_CH_MUXNEG_PIN0_gc);
60 |
61 | // Before the ADC can be used it must be enabled
62 | ADC_Enable(&ADCA);
63 |
64 | // Wait until the ADC is ready
65 | ADC_Wait_8MHz(&ADCA);
66 |
67 | // In the while(1) loop, a conversion is started on CH0 and the 8 MSB of the result is
68 | // ouput on the LEDPORT when the conversion is done
69 |
70 | /* Get offset value for ADC B. */
71 | offset = ADC_Offset_Get_Signed(&ADCA, &(ADCA.CH0), true);
72 |
73 | //Read the ADC forever...
74 | while (1) {
75 | // Start a single conversion
76 | ADC_Ch_Conversion_Start(&ADCA.CH0);
77 |
78 | // Wait for the conversion to complete
79 | while(!ADC_Ch_Conversion_Complete(&ADCA.CH0));
80 |
81 | // Get the result
82 | ADC_result = ADC_ResultCh_GetWord_Signed(&ADCA.CH0, offset);
83 |
84 | // The result is a 12 bit value, 4 rightshifts maps MSB to LED7
85 | // invert as the LED is on when pin is low
86 | LEDPORT.OUT = ~(ADC_result >> 4);
87 | }
88 | }
