1 | #include <p33FJ64GS606.h>
2 | #include <stdlib.h>
3 | #include <delay.h>
4 |
5 | // Select Internal FRC at POR
6 | _FOSCSEL(FNOSC_FRC & IESO_OFF);
7 | // Enable Clock Switching and Configure Primary Oscillator in XT mode
8 | _FOSC(FCKSM_CSECMD & OSCIOFNC_OFF & POSCMD_NONE);
9 |
10 | _FWDT(FWDTEN_OFF) //disable the watchdog timer
11 | _FICD(JTAGEN_OFF & ICS_PGD1);//disable JTAG, enable debugging on PGx1 pins
12 |
13 | void configureOscillator(void);
14 | void initTimer1(void);
15 | void __attribute__((__interrupt__, no_auto_psv)) _T1Interrupt(void);
16 | void enableInterrupts(void);
17 | void disableInterrupts(void);
18 |
19 |
20 | int main(void) {
21 | configureOscillator();
22 | initTimer1();
23 | enableInterrupts();
24 |
25 | //outputs to 0
26 | _LATB12 = 0;
27 | _LATB13 = 0;
28 | _LATB14 = 0;
29 |
30 | // led outputs
31 | _TRISB12 = 0;
32 | _TRISB13 = 0;
33 | _TRISB14 = 0;
34 |
35 |
36 | while (1) {
37 |
38 | _LATB12 = 1;
39 | _LATB13 = 0;
40 |
41 | //Warteschleife
42 | int i = 0;
43 | for(i=0; i<30;i++)
44 | {
45 | int o = 0;
46 | for(o=0; o<10000;o++) {}
47 |
48 | }
49 | _LATB12 = 1;
50 | _LATB13 = 1;
51 |
52 | //Warteschleife
53 | for(i=0; i<30;i++)
54 | {
55 | int o = 0;
56 | for(o=0; o<10000;o++) {}
57 | }
58 |
59 | }
60 | }
61 |
62 |
63 | void configureOscillator(void)
64 | {
65 | // Configure PLL prescaler, PLL postscaler, PLL divisor
66 | PLLFBD=150; // M=152
67 | CLKDIVbits.PLLPOST=0; // N2=2
68 | CLKDIVbits.PLLPRE=5; // N1=7
69 |
70 | // Initiate Clock Switch to Primary Oscillator with PLL (NOSC=0b011)
71 | __builtin_write_OSCCONH(0x01);
72 | __builtin_write_OSCCONL(OSCCON | 0x01);
73 |
74 | // Wait for Clock switch to occur
75 | while (OSCCONbits.COSC!= 0b001);
76 | // Wait for PLL to lock
77 | while (OSCCONbits.LOCK!= 1);
78 | return;
79 | }
80 |
81 | void initTimer1(void)
82 | {
83 | T1CONbits.TON = 0;// Disable Timer
84 | T1CONbits.TCS = 0;// Select internal instruction cycle clock
85 | T1CONbits.TGATE = 0;// Disable Gated Timer mode
86 | T1CONbits.TCKPS = 0b11;// Select 1:256 Prescaler
87 | //11 = 1:256 prescale value
88 | //10 = 1:64 prescale value
89 | //01 = 1:8 prescale value
90 | //00 = 1:1 prescale value
91 |
92 | TMR1 = 0x00; // Clear timer register
93 | PR1 = 20000; // Load the period value
94 |
95 | IPC0bits.T1IP = 1;// Set Timer1 Interrupt Priority Level
96 | IFS0bits.T1IF = 0;// Clear Timer1 Interrupt Flag
97 | IEC0bits.T1IE = 1;// Enable Timer1 interrupt
98 | T1CONbits.TON = 1;// Start Timer
99 | return;
100 | }
101 |
102 |
103 | void __attribute__((__interrupt__, no_auto_psv)) _T1Interrupt(void)
104 | {
105 | /* Clear Timer1 interrupt */
106 | IFS0bits.T1IF = 0;
107 |
108 | LATBbits.LATB14 = ~LATBbits.LATB14;
109 | }
110 |
111 | void enableInterrupts(void)
112 | {
113 | /* Set CPU IPL to 0, enable level 1-7 interrupts */
114 | /* No restoring of previous CPU IPL state performed here */
115 | SRbits.IPL = 0;
116 | //SRbits.IPL = 0 funktioniert nur in Release .... in Debug wird bei einem Wert von 0 der PIC "halted"
117 | //SRbits.IPL = 1 (=IPC0bits.T1IP) funktioniert sowohl im Debug als auch im Release
118 | return;
119 | }
120 |
121 |
122 | void disableInterrupts(void)
123 | {
124 | /* Set CPU IPL to 7, disable level 1-7 interrupts */
125 | /* No saving of current CPU IPL setting performed here */
126 | SRbits.IPL = 7;
127 | return;
128 | }
