DOGS102 und Atmega32
Gast #2823649
verwende den Beispielcode aus folgendem Link:
http://basteln-mit-avr.de/Download/atmega644_DOGS102.zip
Folgende Parameter habe ich schon angepaßt:
- Makefile
LCD = 0
# MCU name
MCU = atmega32
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     Typical values are:
#         F_CPU =  1000000
#         F_CPU =  1843200
#         F_CPU =  2000000
#         F_CPU =  3686400
#         F_CPU =  2000000
#         F_CPU =  7372800
         F_CPU =  8000000
- spi.c
#include "tools.h"
// SPI-Bus initialisieren
#define LCD_A0      0     // PB0 (PIN1)  = Display A0      ->    PIN 38
#define LCD_RST     3     // PB1 (PIN2)  = Display Reset      ->    PIN 39
#define LCD_CS      1     // PB4 (PIN5)  = Select          ->     PIN 40
#define SPI_MOSI    5     // PB5 (PIN6)  = SPI MOSI        ->    PIN 36
#define SPI_MISO    6     // PB6 (PIN7)  = SPI MISO        ->
#define SPI_SCK     7     // PB7 (PIN8)  = SPI SCK        ->    PIN 37
void SPI_PORT_Init(void)
  // === PORT-B CONFIG ===
  DDRB  = (1 << LCD_RST) | (1 << LCD_A0) | (1 << SPI_MOSI) | (1 << SPI_SCK) | (1 << LCD_CS);
  PORTB &=~(1<<SPI_MISO);
  PORTB = (1<<SPI_MISO);
- dogm-graphic.h
// PORT - DEFINITIONEN
// == PORT C ==
#define LCD_A0      0    // PC1 (Pin 16) = Display A0      ->    PIN 38
#define LCD_RST     3     // PC2 (Pin 17) = Display Reset    ->    PIN 39
#define LCD_CS      1     // PC4 (Pin 19) = Display Chip-Select ->     PIN 40
#define SPI_MOSI    5     // PC5 (Pin 20) = SPI MOSI      ->    PIN 36
#define SPI_MISO    6     // PC6 (Pin 21) = SPI MISO      ->     leer
#define SPI_SCK     7     // PC7 (Pin 22) = SPI SCK        ->    PIN 37
#define MEM_FLASH     0
#define MEM_RAM       1
#define MEM_EEPROM    2
24
25
 * BEGIN CONFIG BLOCK
26
27
//Select the display type: DOGS102: 102, DOGM128/DOGL128: 128, DOGM132: 132
28
#define DISPLAY_TYPE  102
29
30
//Should chip select (CS) be used?
31
#define LCD_USE_CHIPSELECT  1
32
//Use Backlight?  (0: no backlight, 1: backlight (on when pin is high), 2: backlight (on when pin is low))
33
#define LCD_USE_BACKLIGHT   0
34
35
#define PORT_A0  PORTB
36
#define DDR_A0   DDRB
37
#define PIN_A0   0
38
39
//Reset Port
40
#define PORT_RST PORTB
41
#define DDR_RST  DDRB
42
#define PIN_RST  3
43
44
//Backlight Port
45
#if LCD_USE_BACKLIGHT != 0
46
  #define PORT_LED PORB
47
  #define DDR_LED  DDRB
48
  #define PIN_LED  0
49
#endif
50
51
//Chip select
52
#if LCD_USE_CHIPSELECT == 1
53
  #define PORT_CS  PORTB
54
  #define DDR_CS   DDRB
55
   #define PIN_CS   1
56
#endif
Das DOGS102 ist wie folgt an dem Atmega angeschlossen:
Display:     Atmega32
SDA/SI ----->PB5 MOSI
SCK/SCL ---->PB7 SCK
CD/A0   ---->PB0
CSO/CS ----->PB1
Reset/RST -->PB3
Was könnte die Ursache sein, dass auf dem Display nichts angezeigt wird?
Gru0
Rik
Gast #2824114
Hallo G.G.,
hab genau diesen Beitrag vorhin gelesen....habs ergänzt und
funktioniert.
Hast Du ein Beispiel, wie man mit Jan.M 's Library z.b einen Rahmen
zeichnet oder einen Kreis...bzw. einzelne Pixel setzt oder löscht....
leider nein.
http://www.basteln-mit-avr.de/atxmega128a3.html#dogm128_gr
Ich  versuche mal  eine Version von dieser Software für einen
Atmega644/32
zu erstellen.Die hat alle Funktionen die du brauchst.
Melde mich nochmals
