Hardware PWM auf ATmega8
OP #2833052
ich bin in dem Gebiet der µCs noch Neueinsteiger und versuche mich zZ an
einer Hardware PWM. Verwendet wird ein Atmega8 mit 8MHz.
Als Vorlage habe ich diese Seite genommen:
http://extremeelectronics.co.in/avr-tutorials/pwm-signal-generation-by-using-avr-timers-part-ii/
Ich hab den Code soweit auf mein Atmega8 angepasst
#include <avr/io.h>
#include <util/delay.h>
void InitPWM()
   TCCR0 - Timer Counter Control Register (TIMER0)
   BITS DESCRIPTION
   NO:   NAME   DESCRIPTION
   BIT 7 : FOC0   Force Output Compare [Not used in this example]
   BIT 6 : WGM00  Wave form generartion mode [SET to 1]
   BIT 5 : COM01  Compare Output Mode        [SET to 1]
   BIT 4 : COM00  Compare Output Mode        [SET to 0]
   BIT 3 : WGM01  Wave form generation mode [SET to 1]
   BIT 2 : CS02   Clock Select               [SET to 0]
   BIT 1 : CS01   Clock Select               [SET to 0]
   BIT 0 : CS00   Clock Select               [SET to 1]
23
24
   The above settings are for
25
26
27
   Timer Clock = CPU Clock (No Prescalling)
28
   Mode        = Fast PWM
29
   PWM Output  = Non Inverted
30
31
32
33
   //Set OC2 PIN as output. It is  PB3 on ATmega16 ATmega32/Atmega8; PortD6 Kontrolle
34
   DDRD  =  0b01000000;
35
   DDRB  =  0b00001000;
36
   //TCCR0|=(1<<WGM00)|(1<<WGM01)|(1<<COM01)|(1<<CS00);
37
  TCCR2=01101001;
38
39
40
41
42
Sets the duty cycle of output.
43
44
Arguments
45
46
duty: Between 0 - 255
47
48
0= 0%
49
50
255= 100%
51
52
The Function sets the duty cycle of pwm output generated on OC0 PIN
53
The average voltage on this output pin will be
54
55
         duty
56
 Vout=  ------ x 5v
57
         255
58
59
This can be used to control the brightness of LED or Speed of Motor.
60
61
62
void SetPWMOutput(uint8_t duty)
63
64
   OCR2=duty;
65
66
67
68
69
Simple Wait Loop
70
71
72
73
void Wait()
74
75
 _delay_loop_2(62000);
76
77
78
void main()
79
80
   uint8_t brightness=0;
81
82
   //Initialize PWM Channel 0
83
   InitPWM();
84
85
   //Do this forever
86
87
   while(1)
88
89
      //Now Loop with increasing brightness
90
91
      for(brightness=0;brightness<255;brightness++)
92
93
         //Now Set The Brighness using PWM
94
95
         SetPWMOutput(brightness);
96
97
     //Kontrolllampe
98
    PORTD^=0b01000000;
99
         //Now Wait For Some Time
100
         Wait();
101
102
103
      //Now Loop with decreasing brightness
104
105
      for(brightness=255;brightness>0;brightness--)
106
107
108
109
110
111
112
         Wait();
113
114
115
Leider kann ich am PortB3 kein oszillieren messen. Vielleicht könnt ihr
ja einen Fehler finden...
Achja am PortD6 hängt ne LED, die mir bestätigt das beide For
Anweisungen durchlaufen werden...
Bin für jede Antwort Dankbar!
#2833089
Dein Hauptfehler besteht darin, dass du auf bescheuerter Syntax
bestehst.
Das hier
  TCCR2=01101001;
tut nicht das, was du denkst das es tun sollte.
01101001
ist keine Binärzahl sondern eine Oktalzahl.
Und darf man erfahren, warum du diese Schreibweise, der einfach zu
lesenderen, einfacher zu analysierenden und zumindest in dieser Hinsicht
WESENTLICH weniger fehleranfälligen Schreibweise
   TCCR2 |= (1<<WGM20) | (1<<WGM21) |    // Fast PWM
            (1<<COM21) |                 // Clear when Up, Set when down
            (1<<CS20);                   // Prescaler 1
vorziehst?
Da sieht man auf einen Blick, welche Bits gesetzt werden und kann mit
den Bitnamen im Datenblatt vergleichen. Schreibst du das binär, muss man
erst mal die Bits auseinander dröseln, ehe man feststellen kann, was du
da überhaupt alles einschaltest.
Benutze die Bitnamen aus dem Datenblatt! Dazu wurden die Header Files
entsprechend gepimpt, damit du das machen kannst!
Hier
   DDRB  =  0b00001000;
ist es zwar prinzipiell richtig, aber von der Schreibweise genau das
gleiche:
Wenn du Bit 3 (PB3) auf 1 setzen willst, dann schreib das auch so:
   DDRB |= ( 1 << PB3 );
Jetzt kann der Blindenhund eines Blinden auf 15 Meter Entfernung
erkennen, dass das Bit für PB3 auf 1 gesetzt wird. Kein Mensch muss dazu
irgendwelche Bits zählen (und sich 3 mal verzählen) oder irgendwelche
Prefixe für Binärzahlen benutzen (und manchmal darauf vergessen).
OP #2833111
Vielen Dank für deine sehr belustigende Antwort ;-).
Grund warum ich es so schreibe steht vermutlich gleich in der ersten
Zeile meines Beitrages oben.
Ich habe auch erst seit heute deine Schreibweise kennengelernt, werde
mich aber nun darrauf umstellen (versprochen!).
Die PWM läuft nun auch, Vielen Dank!
