1 | Library UNISIM;
2 | use UNISIM.vcomponents.all;
3 | -- RAMB18: 16k+2k Parity Paramatizable True Dual-Port BlockRAM
4 | -- Virtex-5
5 | -- Xilinx HDL Libraries Guide, version 13.4
6 | RAMB18_inst : RAMB18
7 | generic map (
8 | DOA_REG => 0, -- Optional output register on A port (0 or 1)
9 | DOB_REG => 0, -- Optional output register on B port (0 or 1)
10 | INIT_A => X"00000", -- Initial values on A output port
11 | INIT_B => X"00000", -- Initial values on B output port
12 | READ_WIDTH_A => 0, -- Valid values are 1, 2, 4, 9, or 18
13 | READ_WIDTH_B => 0, -- Valid values are 1, 2, 4, 9, or 18
14 | SIM_COLLISION_CHECK => "ALL", -- Collision check enable "ALL", "WARNING_ONLY",
15 | -- "GENERATE_X_ONLY" or "NONE"
16 | SIM_MODE => "SAFE", -- Simulation: "SAFE" vs "FAST", see "Synthesis and Simulation
17 | -- Design Guide" for details
18 | SRVAL_A => X"00000", -- Set/Reset value for A port output
19 | SRVAL_B => X"00000", -- Set/Reset value for B port output
20 | WRITE_MODE_A => "WRITE_FIRST", -- "WRITE_FIRST", "READ_FIRST" or "NO_CHANGE"
21 | WRITE_MODE_B => "WRITE_FIRST", -- "WRITE_FIRST", "READ_FIRST" or "NO_CHANGE"
22 | WRITE_WIDTH_A => 0, -- Valid values are 1, 2, 4, 9, or 18
23 | WRITE_WIDTH_B => 0, -- Valid values are 1, 2, 4, 9, or 18
24 | -- The following INIT_xx declarations specify the initial contents of the RAM
25 | INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
26 | INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
27 | INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
28 | INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
29 | INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
30 | INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
31 | INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
32 | INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000",
33 | INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000",
34 | INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000",
35 | INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000",
36 | INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000",
37 | INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000",
38 | INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000",
39 | INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000",
40 | INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000",
41 | INIT_10 => X"0000000000000000000000000000000000000000000000000000000000000000",
42 | INIT_11 => X"0000000000000000000000000000000000000000000000000000000000000000",
43 | INIT_12 => X"0000000000000000000000000000000000000000000000000000000000000000",
44 | INIT_13 => X"0000000000000000000000000000000000000000000000000000000000000000",
45 | INIT_14 => X"0000000000000000000000000000000000000000000000000000000000000000",
46 | INIT_15 => X"0000000000000000000000000000000000000000000000000000000000000000",
47 | INIT_16 => X"0000000000000000000000000000000000000000000000000000000000000000",
48 | INIT_17 => X"0000000000000000000000000000000000000000000000000000000000000000",
49 | INIT_18 => X"0000000000000000000000000000000000000000000000000000000000000000",
50 | INIT_19 => X"0000000000000000000000000000000000000000000000000000000000000000",
51 | INIT_1A => X"0000000000000000000000000000000000000000000000000000000000000000",
52 | INIT_1B => X"0000000000000000000000000000000000000000000000000000000000000000",
53 | INIT_1C => X"0000000000000000000000000000000000000000000000000000000000000000",
54 | INIT_1D => X"0000000000000000000000000000000000000000000000000000000000000000",
55 | INIT_1E => X"0000000000000000000000000000000000000000000000000000000000000000",
56 | INIT_1F => X"0000000000000000000000000000000000000000000000000000000000000000",
57 | INIT_20 => X"0000000000000000000000000000000000000000000000000000000000000000",
58 | INIT_21 => X"0000000000000000000000000000000000000000000000000000000000000000",
59 | INIT_22 => X"0000000000000000000000000000000000000000000000000000000000000000",
60 | INIT_23 => X"0000000000000000000000000000000000000000000000000000000000000000",
61 | INIT_24 => X"0000000000000000000000000000000000000000000000000000000000000000",
62 | INIT_25 => X"0000000000000000000000000000000000000000000000000000000000000000",
63 | INIT_26 => X"0000000000000000000000000000000000000000000000000000000000000000",
64 | INIT_27 => X"0000000000000000000000000000000000000000000000000000000000000000",
65 | INIT_28 => X"0000000000000000000000000000000000000000000000000000000000000000",
66 | INIT_29 => X"0000000000000000000000000000000000000000000000000000000000000000",
67 | INIT_2A => X"0000000000000000000000000000000000000000000000000000000000000000",
68 | INIT_2B => X"0000000000000000000000000000000000000000000000000000000000000000",
69 | INIT_2C => X"0000000000000000000000000000000000000000000000000000000000000000",
70 | INIT_2D => X"0000000000000000000000000000000000000000000000000000000000000000",
71 | INIT_2E => X"0000000000000000000000000000000000000000000000000000000000000000",
72 | INIT_2F => X"0000000000000000000000000000000000000000000000000000000000000000",
73 | INIT_30 => X"0000000000000000000000000000000000000000000000000000000000000000",
74 | INIT_31 => X"0000000000000000000000000000000000000000000000000000000000000000",
75 | INIT_32 => X"0000000000000000000000000000000000000000000000000000000000000000",
76 | INIT_33 => X"0000000000000000000000000000000000000000000000000000000000000000",
77 | INIT_34 => X"0000000000000000000000000000000000000000000000000000000000000000",
78 | INIT_35 => X"0000000000000000000000000000000000000000000000000000000000000000",
79 | INIT_36 => X"0000000000000000000000000000000000000000000000000000000000000000",
80 | INIT_37 => X"0000000000000000000000000000000000000000000000000000000000000000",
81 | INIT_38 => X"0000000000000000000000000000000000000000000000000000000000000000",
82 | INIT_39 => X"0000000000000000000000000000000000000000000000000000000000000000",
83 | INIT_3A => X"0000000000000000000000000000000000000000000000000000000000000000",
84 | INIT_3B => X"0000000000000000000000000000000000000000000000000000000000000000",
85 | INIT_3C => X"0000000000000000000000000000000000000000000000000000000000000000",
86 | INIT_3D => X"0000000000000000000000000000000000000000000000000000000000000000",
87 | INIT_3E => X"0000000000000000000000000000000000000000000000000000000000000000",
88 | INIT_3F => X"0000000000000000000000000000000000000000000000000000000000000000",
89 | -- The next set of INITP_xx are for the parity bits
90 | INITP_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
91 | INITP_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
92 | INITP_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
93 | INITP_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
94 | INITP_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
95 | INITP_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
96 | INITP_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
97 | INITP_07 => X"0000000000000000000000000000000000000000000000000000000000000000")
98 | port map (
99 | DOA => DOA, -- 16-bit A port data output
100 | DOB => DOB, -- 16-bit B port data output
101 | DOPA => DOPA, -- 2-bit A port parity data output
102 | DOPB => DOPB, -- 2-bit B port parity data output
103 | ADDRA => ADDRA, -- 14-bit A port address input
104 | ADDRB => ADDRB, -- 14-bit B port address input
105 | CLKA => CLKA, -- 1-bit A port clock input
106 | CLKB => CLKB, -- 1 bit B port clock input
107 | DIA => DIA, -- 16-bit A port data input
108 | DIB => DIB, -- 16-bit B port data input
109 | DIPA => DIPA, -- 2-bit A port parity data input
110 | DIPB => DIPB, -- 2-bit B port parity data input
111 | ENA => ENA, -- 1-bit A port enable input
112 | ENB => ENB, -- 1-bit B port enable input
113 | REGCEA => REGCEA, -- 1-bit A port register enable input
114 | REGCEB => REGCEB, -- 1-bit B port register enable input
115 | SSRA => SSRA, -- 1-bit A port set/reset input
116 | SSRB => SSRB, -- 1-bit B port set/reset input
117 | WEA => WEA, -- 2-bit A port write enable input
118 | WEB => WEB -- 2-bit B port write enable input
119 | );
120 | -- End of RAMB18_inst instantiation
