1 | /*
2 | * AVR_Dimmer.c
3 | *
4 | * Created: 30.09.2012 13:26:59
5 | * Author:
6 | */
7 |
8 | // interner Oszillator 9,6 Mhz
9 | #define F_CPU 9600000UL
10 |
11 | #include <avr/io.h>
12 | #include <avr/interrupt.h>
13 |
14 | #define PWM_Output_Port PORTB
15 | #define PWM_Output_Bit 0
16 | #define PWM_Output_DDR DDRB
17 |
18 | #define POTI_Input_Port PORTB
19 | #define POTI_Input_Bit 4
20 | #define POTI_Input_DDR DDRB
21 |
22 | #define set_bit(var, bit) var |= (1 << bit)
23 | #define clr_bit(var, bit) var &= ~(1 << bit)
24 |
25 | void ADC_Init(); // ADC Inititialisierung
26 | uint16_t ADC_Read(uint8_t channel); // ADC Einzelmessung
27 |
28 | uint8_t pwm_counter = 0;
29 | uint8_t volatile pwm_value;
30 | uint16_t volatile adc_in;
31 | uint8_t adc_percent;
32 |
33 | int main(void)
34 | {
35 |
36 | // Initialisierung
37 |
38 | // PWM Output definieren
39 | set_bit(PWM_Output_DDR, PWM_Output_Bit);
40 | // ADC Input definieren
41 | set_bit(POTI_Input_DDR, POTI_Input_Bit);
42 |
43 | // ADC initialisieren
44 | ADC_Init();
45 |
46 | // Timer definieren
47 | TIMSK0 = (1 << TOIE0); // Timer0 Overflow Input Enable
48 | TCCR0B = (1 << CS01); // Prescaler 8
49 | TCNT0 = 0; // Timer Anfangswert 0
50 | sei(); // Interrupts aktivieren
51 |
52 | while(1)
53 | {
54 | adc_in = ADC_Read(2); // ADC auslesen
55 | adc_percent = adc_in / 1024 * 100;
56 |
57 | pwm_value = adc_percent / 100 * 255;
58 | }
59 | }
60 |
61 | // ISR Timer0 Overflow
62 | ISR(TIMER0_OVF_vect) {
63 |
64 | pwm_counter++;
65 |
66 | if (pwm_value <= pwm_counter) {
67 | set_bit(PWM_Output_Port, PWM_Output_Bit);
68 | } else {
69 | clr_bit(PWM_Output_Port, PWM_Output_Bit);
70 | };
71 |
72 | }
73 |
74 | // ADC Initialisierung
75 | void ADC_Init(void) {
76 |
77 | uint16_t result;
78 |
79 | // VCC als Referenz
80 | ADMUX = ~(1 << REFS0);
81 |
82 | // Frequenzvorverteiler 128
83 | ADCSRA = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
84 |
85 | // ADC aktivieren
86 | ADCSRA |= (1 << ADEN);
87 |
88 | // Dummy Readout
89 |
90 | ADCSRA |= (1 << ADSC); // eine ADC Wandlung
91 | while (ADCSRA & (1 << ADSC)) {;}; // auf Abschluss warten
92 | result = ADCW; // Ergebnis muss einmal gelesen werden sonst wird die nächste Wandlung nicht übernommen
93 |
94 | }
95 |
96 | // ADC Einzelmessung
97 | uint16_t ADC_Read(uint8_t channel) {
98 |
99 | // Kanal wählen
100 | ADMUX = (ADMUX & ~(0x1F)) | (channel & 0x1F);
101 | ADCSRA |= (1 << ADSC); // eine Wandlung
102 | while (ADCSRA & (1 << ADSC)) {;}; // auf Ergebnis warten
103 |
104 | return ADCW; // Ergebnis zurückgeben
105 |
106 | }
