1 | //-----------------------------------------------------------------------------
2 | // Includes
3 | //-----------------------------------------------------------------------------
4 | #include <c8051f310.h> // SFR declarations
5 |
6 | unsigned long ms;
7 |
8 | //-----------------------------------------------------------------------------
9 | // 16-bit SFR Definitions for 'F33x
10 | //-----------------------------------------------------------------------------
11 |
12 | sfr16 TMR2RL = 0xca; // Timer2 reload value
13 | sfr16 TMR2 = 0xcc; // Timer2 counter
14 | //-----------------------------------------------------------------------------
15 | // Global CONSTANTS
16 | //-----------------------------------------------------------------------------
17 |
18 | #define SYSCLK 24500000 // SYSCLK frequency in Hz
19 |
20 | sbit LED = P0^3; // LED='1' means ON
21 |
22 | //-----------------------------------------------------------------------------
23 | // Function PROTOTYPES
24 | //-----------------------------------------------------------------------------
25 | void SYSCLK_Init (void);
26 | void PORT_Init (void);
27 | void Timer2_Init (void);
28 | void Timer2_ISR (void);
29 | void ADC0_Init (void);
30 | void ADC0_ISR (void);
31 |
32 | //-----------------------------------------------------------------------------
33 | // MAIN Routine
34 | //-----------------------------------------------------------------------------
35 | void main (void) {
36 |
37 | unsigned long wait;
38 |
39 | ms=0;
40 | wait=0;
41 |
42 | // disable watchdog timer
43 | PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer
44 | // enable)
45 |
46 | SYSCLK_Init (); // Initialize system clock to
47 | // 24.5MHz
48 | PORT_Init (); // Initialize crossbar and GPIO
49 | Timer2_Init (); // Init Timer2
50 |
51 | EA = 1; // enable global interrupts
52 | while (1) { // spin forever
53 | if( (ms-wait) < 1000 ) {
54 | LED=~LED;
55 | wait=ms;
56 | }
57 |
58 | }
59 | }
60 |
61 | //-----------------------------------------------------------------------------
62 | // SYSCLK_Init
63 | //-----------------------------------------------------------------------------
64 | //
65 | // This routine initializes the system clock to use the internal 24.5MHz
66 | // oscillator as its clock source. Also enables missing clock detector reset.
67 | //
68 | void SYSCLK_Init (void)
69 | {
70 |
71 | OSCICN = 0xC3; // configure internal oscillator for
72 |
73 | RSTSRC = 0x04; // enable missing clock detector
74 | }
75 |
76 | //-----------------------------------------------------------------------------
77 | // PORT_Init
78 | //-----------------------------------------------------------------------------
79 | //
80 | // Configure the Crossbar and GPIO ports.
81 | // P0.3 - LED (push-pull)
82 | //
83 | void PORT_Init (void)
84 | {
85 |
86 | XBR0 = 0x00; // no digital peripherals selected
87 | XBR1 = 0x40; // Enable crossbar and weak pull-ups
88 | P0MDOUT |= 0x08; // enable LED as a push-pull output
89 | }
90 |
91 | //-----------------------------------------------------------------------------
92 | // Timer2_Init
93 | //-----------------------------------------------------------------------------
94 | //
95 | // Configure Timer2 to 16-bit auto-reload and generate an interrupt
96 | //
97 | void Timer2_Init (void)
98 | {
99 | TMR2CN = 0x00; // Stop Timer2; Clear TF2;
100 | // use SYSCLK/12 as timebase
101 | CKCON &= ~0x20; // Timer2 clocked based on T2XCLK;
102 |
103 | TMR2RL = -SYSCLK/12/1000; // Init reload values
104 | TMR2 = 0xffff; // set to reload immediately
105 | ET2 = 1; // enable Timer2 interrupts
106 | TR2 = 1; // start Timer2
107 | }
108 |
109 |
110 | //-----------------------------------------------------------------------------
111 | // Interrupt Service Routines
112 | //-----------------------------------------------------------------------------
113 |
114 | //-----------------------------------------------------------------------------
115 | // Timer2_ISR
116 | //-----------------------------------------------------------------------------
117 | // This routine changes the state of the LED whenever Timer2 overflows.
118 | //
119 | void Timer2_ISR (void) interrupt 5
120 | {
121 | TF2H = 0; // clear Timer2 interrupt flag
122 | ms++;
123 | }
